Old 07-10-2008, 07:16 AM   #51 (permalink)
mbentley's Avatar
Drives: '98 3000gt sl
mbentley Level 1mbentley Level 1
Default Re: Part # Help Thread! If you have CAPS, help someone out!
one other thing i am looking for...
i am looking for the driver and passenger side "door ajar" sensors/switches. i looked around CAPS for a while but i really couldn't find them... i am probably just looking in the wrong location but if anyone could help me out, that would be appreciated.
*edit: the closest thing that i can find is MB698713 which has been replaced by MR124303
norco mitsubishi shows the following info:
Code:
Item Number  	MSRP  	Core Price  	Price
MR124303  	$7.02  	$0.00  	$5.62
Electrical - Chassis electrical - Switches - Door jamb switch
Door jamb switch, 3000 gt 1995 - 1999
is this the correct one?
1998 mitsubishi 3000gt sl
mbentley is offline   Reply With Quote
Old 07-10-2008, 09:51 AM   #52 (permalink)
Former ROTY :-}
OhioSpyderman's Avatar
Drives: Back and Forth :)
Trader Rating: (44)
OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7
I believe those to be correct.
You may want to check in the parts for sale section. Anyone parting out a car may have those switches for WAY less than the dealer....
Bob.
95 Caracus Red Spyder VR4
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
SBC-iD Boost Controller (in both!!!)
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
OhioSpyderman is offline   Reply With Quote
Old 07-10-2008, 10:02 AM   #53 (permalink)
mbentley's Avatar
Bob.
thanks for checking on that. i still couldn't find it on any of the diagrams. i'm looking to get new ones though since the reason i am buying them is because mine are wearing out. i normally just keep my lights in the on position as i think it is safer to always drive with lights on because you can be more visible and when i get out, i leave them in the on position as well. the door sensors are supposed to automatically turn the lights off... well if it doesn't sense that the door is open, it never shuts the lights off which leads to a dead battery
Old 07-23-2008, 11:18 AM   #54 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (62)
If your windows rattle in your doors:
Originally Posted by BBBBill View Post
OK. Here's what I've got for numbers.
Striker, glass (2 per side) R MB641370 / L MB641369 $1.48
Retainer (4 per side) MB364450 $2.05
Cushion, glass * (8 per side) MB364453 $1.71
* note says order by application
Slider, glass R MB641302 / L MB641301 $18.43
Guide, glass front R MB641346 / L MB641345 $38.72
Guide, glass rear R MB641352 / L MB641351 $38.33
Weatherstrip, glass outer R MB641312 / L MB641311 $52.22
Weatherstrip, glass inner R MR153920 / L MR153919 $36.23
That's more than you asked for, but you might get into the door and find out you want to replace some of the other stuff. That is everything inside the door related to your glass except the regulator items. The prices are out of date by a few years, but shouldn't be terribly different.
I have no clue what the note on the cushions means. Call Mentor, Rockville or one of the other supporting dealers to order. I got very good prices from Rockville on weatherstripping last year.
Window glass is listed at ~$250 per window, but that is way higher than it should cost you to replace. For example, windshields are listed at ~$600, but I had one installed a few months back for $240 and they came to my place of business to do it. If you decide to do this, pull your glass and polish it with one of those glass kits you get at Auto Zone, etc. Might do well enough to save replacing the glass.
Wiper switch number is MB852131 for 91-96 $30.75, MR243536 for 97-99 $59.88.
Did you try grounding your wiper motor?
Wiper motor part # is MB622910 $225.65
Again, all prices are old.
FWIW, you are getting more help from me than I've ever gotten around here with one exception. I guess because I'm one of the newer members that I'm not "in the clubhouse" yet.
Sour grapes off. Back to business.
Thanks BBBBill.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 07-29-2008, 05:44 PM   #55 (permalink)
back to it!
Drives: '95 VR4 Pearl White
Trader Rating: (6)
aeveret2 is an unknown quantity at this point
can someone please give me the part# for a ignition coil and the a/c dual pressure switch?
thanks.
____
bpu+
aeveret2 is offline   Reply With Quote
Old 07-30-2008, 06:42 PM   #56 (permalink)
Jason_99ozGS's Avatar
Drives: 94 3000GT VR-4
Trader Rating: (9)
Jason_99ozGS is an unknown quantity at this point
Can someone please get me the part # for the steering lines that run to the back of the car for the all wheel steering? I'm looking for the ones on the passenger side. It's the rubber one labeled 4 in this pic, but it might come as an assembly (two rubber parts and a hard line in the middle). I need this # bad because my car is leaking close to 1 quart a day!
Also what are some good Mitsubishi dealerships to call? I'd like to get this part ASAP.
Edit: I think I found it, MB631976
1994 Mitsubishi 3000GT VR-4
1990 Plymouth Laser RS Turbo
Jason_99ozGS is offline   Reply With Quote
Old 07-30-2008, 07:35 PM   #57 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (62)
Coil pack is MD152648, sold as a unit.
The A/C pressure switch, I have no idea what it is and CAPS isn't giving my anything that looks like it.
Those rear steering tubes actually do have different part #'s, here's what I came up with: MB631976; MB631975. Some confirmation on that would be awesome.
I order all my OEM stuff through Cherry Hill Triplex - Dodge Jeep Mitsubishi Kia and Preowned Cars - Serving Philadelphia New Jersey Pennsylvania Delaware South Jersey, Trenton, Pleasantville, Vineland, Sicklerville and Williamstown - awesome prices, great service, etc etc.
Looks like it's $55/hose for those AWS hoses.
Old 07-31-2008, 02:47 PM   #58 (permalink)
back to it!
Trader Rating: (6)
thanks a whole bunch.
I'm ordering the coils through the site provided as well. Great advice.
Old 08-26-2008, 12:21 PM   #59 (permalink)
varicella's Avatar
Drives: Black '98 VR4
varicella is an unknown quantity at this point
Default "wiring rail" that covers front fuel injector wires
Neither I nor a couple dealers can seem to find the part number to this annoying little plastic piece: http://www.supercar-engineering.com/...WiringRail.jpg that bolts to the plenum and holds the wires to the fuel injectors. It cracks easily and is hard to get open and breaks and I'd like to get a new one but can't find it. Does anyone know the real name or part number or anyone who sells this aftermarket? Thanks.
I thought I deleted this post.. I found this part that day by calling cherryhill, they were able to find it.
varicella is offline   Reply With Quote
Old 09-04-2008, 06:16 AM   #60 (permalink)
Drives: 92 VR-4
QSpectre Level 1QSpectre Level 1
I need the part number for a Crank Pulley Bolt for a 92 VR4. I don't know if they are different for the SOHC or for different years. But I need to find one pretty fast please.
1992 Fiji Blue VR-4
Working on getting it going for now!
Past Cars:
2003 Cobra (475 rwhp)
1999 BMW M3
1998 BMW 328is
1988 BMW 325xi
QSpectre is online now   Reply With Quote
