Old 04-13-2008, 07:47 PM   #21 (permalink)
Forum user
mojo3120's Avatar
Drives: like a maniac
Trader Rating: (7)
mojo3120 Level 2mojo3120 Level 2mojo3120 Level 2mojo3120 Level 2mojo3120 Level 2
Default Re: Part # Help Thread! If you have CAPS, help someone out!
Bob: Thanks for the quick help!
I meant the big O-ring between the lower plenum and injectors ... I think that "injector O-ring" part refers to the smaller o-rings that go on the top of the injectors to seal in the fuel rail. I wonder if there's anything else in CAPS?
Thanks!
-Ryan
the big ones on the left=MD087060
small ones on the right=1465A18
mojo3120 is offline   Reply With Quote
Old 04-13-2008, 09:35 PM   #22 (permalink)
Automotive Geek
Drives: 1993 3000GT VR-4
SpikeyGG is an unknown quantity at this point
Default Part Number Request and Q
Anyone have the part number for:
1) Rear head to exhaust manifold gasket.
2) Crush washers for coolant lines on the rear turbo.
My rear exhaust manifold gasket is like 4 seperate pieces of flat metal with a couple of small metal grommets at either end holding them all together. Should I replace it or is that normal? Also, I've removed the rear turbo and I'm getting ready to re-install, is there anything besides the copper crush washers that I *should* replace while slapping it all back together?
Thanks,
-Greg
93 VR-4 K&N FIPK, Eibach Pro Sport springs, MSD 8.5mm wires, NGK iridium plugs, solid polyurethane motor mounts, Sumitomo HTR+ tires, gutted precats, adjustable rear control arms, 99 lifters, underhood and console shifter bushings, aluminum dash vents, clutch vacuum assist delete, GM boost logging, full set of Defi gauges. Always a work in progress...
SpikeyGG is offline   Reply With Quote
Old 04-13-2008, 09:45 PM   #23 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Awesome. Thanks guys!
R.I.P.
Old 04-13-2008, 10:02 PM   #24 (permalink)
Now with 100% more meth
sublime_whatigo's Avatar
Drives: reliable car (nissan
Trader Rating: (25)
sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3sublime_whatigo Level 3
Default Re: Part Number Request and Q
Thanks,
-Greg
Exhaust manifold gasket, ya thats normal, replace it if you want. MD168115
Coolant crush washers MF660064
Oil return line gasket MR258477
The other 2 turbo gaskets you should get are
MD168266 Manifold to turbo
MR188537 turbo to o2 housing
And if your turbo studs are broke/old you can replace those MD050074
92 3000GT VR4
Black Wheel Mafia - Member 002
Matt
sublime_whatigo is offline   Reply With Quote
Old 04-14-2008, 01:08 AM   #25 (permalink)
Automotive Geek
Thanks man! I'm on it!
Old 04-14-2008, 01:23 AM   #26 (permalink)
Bolt Speedman
75blackray's Avatar
Drives: 92TT,75vette,07sv650
Trader Rating: (7)
75blackray Level 175blackray Level 1
Hey, if someone gets the chance i need the PN for 3rd gear blocking ring and the o-ring that goes on the fuel pump.
75blackray is offline   Reply With Quote
Old 04-30-2008, 01:43 AM   #27 (permalink)
Automotive Geek
Can someone supply the part numbers for the seals / gaskets between the rear active aero spoiler and the trunk? There are three seals two of them may be the same (left and right), I'm not sure. This is for my '93.
Thanks,
-Greg
Old 04-30-2008, 10:31 AM   #28 (permalink)
Former ROTY :-}
OhioSpyderman's Avatar
Drives: Back and Forth :)
Trader Rating: (51)
OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3
MR358264 (2) (left and right are the same)
MR358263 Center
Bob.
95 Caracus Red Spyder VR4
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
SBC-iD Boost Controller (in both!!!)
OhioSpyderman is offline   Reply With Quote
Old 04-30-2008, 11:41 AM   #29 (permalink)
Wannabe
stealthxtreme4's Avatar
Drives: 91' Sable Black VR-4
Trader Rating: (28)
stealthxtreme4 is an unknown quantity at this point
I need the rubber boot that goes on the outside of the front turbo for the intake pipe to fit on right...
and the hose that goes from the brake booster to the driver side of the intake plenum. It has the checkvalve in it for the brake booster.
1991 3000GT VR-4
2002 Nissan Xterra SE/SC
stealthxtreme4 is offline   Reply With Quote
Old 04-30-2008, 01:10 PM   #30 (permalink)
Former ROTY :-}
Trader Rating: (51)
Matt, the brake booster hose says "**NO DATA** and I can't find that rubber thing for the life of me!!!
Sorry,
Bob.
