» Site Navigation
» Related Sites
» Buyers Guide
» Network Links
3si.org is the premier 3000GT/Stealth International Forum on the internet.
Registered Users do not see the above ads.
03-23-2008, 01:00 AM
#11 (permalink )
Damage Control
Drives: 1994 Stealth
Re: Part # Help Thread! If you have CAPS, help someone out!
I guess I need some assistance too.
I need the part numbers for the nuts, washers, and bolts that are used to bolt the front subframe up in place.
I somehow misplaced both sets I had and need to get this RT back together.
Thanks
03-24-2008, 11:03 AM
#12 (permalink )
Drives: 1994 stealth base
Parts # needed
i am in extreme need of the mits parts number for the thermostat housing on my sohc 1994 stealth base the on on it has no filler neck soo i cant fill it thanks in advanced.
Was going to be built and boosted... nissans are addicting it is for sale>
[/IMG]
04-01-2008, 03:07 PM
#13 (permalink )
I've been here way too long
Drives: Like an Idiot
wheel stud p/n?
Hi guys has anyone any ideas of the part number for wheel studs on 3s/gto?
my mainstealer is numb!
04-01-2008, 08:25 PM
#14 (permalink )
Re: wheel stud p/n?
Originally Posted by
Colt45_GTO
MB911495
about $2 / ea.
Engine / Drivetrain / Performance:
2 Bolt block with Forged Crank
TD04 16G - HL Turbos
CX Racing Dual core FMIC (homemade piping)
PTE 550cc Injectors, MAFT-Gen2, GM MAF (Blow Thru), Dejon Twin Intakes, Greddy Type S, Greddy Profec EBC, Apexi SITC, Innovate LC-1 Wideband, 3SX SS Downpipe, 3" DR ATR SS Single Shot Cat-back, Upgraded 19 row oil cooler...
Southbend Stage 3 OFE
Exterior:
Cianci Victory Hood, 5-Zigen 17x9, 2nd Gen Rear crash bar and bumper, amplified shark antenna...
Rear tint - 15%, Front - 35%
Deletes:
ABS, AWS, Airbag, PS, Cruise/Vac
3400 lbs.
04-02-2008, 04:15 AM
#15 (permalink )
Re: wheel stud p/n?
Drweldin
MB911495
about $2 / ea.
cheers bro
04-13-2008, 01:36 PM
#16 (permalink )
Here for the tuna.
Drives: Crutches
I need part #'s for the upper and lower intake plenum gaskets, lower injector o-rings, and throttle body gasket.
Thanks!
04-13-2008, 02:07 PM
#17 (permalink )
Former ROTY :-}
Drives: Back and Forth :)
lawdogg
Thanks!
Ryan,
Upper intake gasket = MD143791
Lower intake gasket = MD164701
Throttle body gasket = MD180361
Not sure what you mean by "lower" injector o-rings, but "O-RING, FUEL INJECTOR" = MD614813
Bob.
95 Caracus Red Spyder VR4
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
SBC-iD Boost Controller (in both!!!)
04-13-2008, 02:15 PM
#18 (permalink )
Here for the tuna.
Drives: Crutches
Bob: Thanks for the quick help!
I meant the big O-ring between the lower plenum and injectors ... I think that "injector O-ring" part refers to the smaller o-rings that go on the top of the injectors to seal in the fuel rail. I wonder if there's anything else in CAPS?
Thanks!
-Ryan
04-13-2008, 02:17 PM
#19 (permalink )
Former ROTY :-}
There's an "INSULATOR, FUEL INJECTOR" that appears to be at the bottom of the injector. Part # = MD087060
04-13-2008, 03:25 PM
#20 (permalink )
Drives: 94 Panama Pearl VR-4
Maybe this will help
PNC# 07802P - MD087060
PNC# 07892 - MD614813
PNC# 07811 - MD614805
Go here and enter part#'s in for best prices
http://www.trademotion.com/partlocat...?siteid=214619
