Re: Part # Help Thread! If you have CAPS, help someone out!
Hi,
Just wondering if JDM GTO's share the same part numbers as 3000GT's. You see I need a part number for the speedometer gear that sits in the VSS. Its for a JDM '96 GTO MR. I found this (Stealth 316 - Speedometer Gear Replacement) and it says that the part number for the 28-teeth gear is MR111502, but thats for a 3000GT and I am not sure if it is the same one for my GTO.
Originally Posted by Tys
Hi,
Any help will be greatly appreciated, thanks.
I went into CAPS under the Z15A (AWD, non-AWS) chassis and did find that part # as the driven speedo gear, PNC 81337.
Upon further digging, it appears there are 5 options for driven speedometer gears. The first applies to all models from 90-93 (so 1st gen) and is part# MB811064 ... 27 teeth. The last 4 each apply to different year second gens but are all the same part #, MR111502 ... 28 teeth. So it seems that would apply to your GTO, from what I can tell.
Hope that helps. The part is only $20 from Cherry Hill so it's worth a shot?
-Ryan
Thanks a lot, will give them a go. Another quick question, do both auto and manual transmission have the same speedo gear?
Originally Posted by Stealthee
Auto and Manual have different speedo gears from what I have found.
So, would a 5 speed have a different speedo gear than a 6 speed? I've got a 6 speed so would this be the right one (MR111502) for a 6 speed trans? I just need to make sure as I'm in Australia and a $20 part might end up costing like $150 to post here.
