Old 05-10-2009, 05:10 PM   #121 (permalink)
johnnylazer's Avatar
Drives: 97 3000 VR4
johnnylazer is an unknown quantity at this point
Default Re: Part # Help Thread! If you have CAPS, help someone out!
Any body know thepart number for the rubber access cover over the opening in the inner drivers front wheelwell that allows you to turn the engine by hand (wrench) to advance the cams and change the lifters? My dog chewed mine, and I need to replace it.
johnnylazer is offline   Reply With Quote
Old 05-12-2009, 12:59 PM   #122 (permalink)
all weather warrior
Drives: 1995 3000GT VR4
northener is an unknown quantity at this point
The rubber plug is part# MU670026 and the left hand cover is MB640781
northener is offline   Reply With Quote
Old 05-18-2009, 04:09 PM   #123 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Looking for the part #'s for the front seat belt buckle bolts. Thanks!
R.I.P.
Old 05-18-2009, 04:21 PM   #124 (permalink)
Combat Tracker
dbest671's Avatar
Drives: 1994 VR-4; 300C SRT8
Trader Rating: (19)
dbest671 Level 1dbest671 Level 1
MB268795 for the bolt
dbest671 is offline   Reply With Quote
Old 05-22-2009, 09:50 AM   #125 (permalink)
Drives: 93 RT/TT, 91 VR-4
Trader Rating: (26)
BA TURBO is an unknown quantity at this point
Can someone help me out with a part number for a TPS, 91 VR-4?
Thanks.
Bob-
BA TURBO is offline   Reply With Quote
Old 05-22-2009, 10:03 AM   #126 (permalink)
Former ROTY :-}
OhioSpyderman's Avatar
Drives: Back and Forth :)
Trader Rating: (51)
OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3
MD614405
Bob.
95 Caracus Red Spyder VR4
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
SBC-iD Boost Controller (in both!!!)
OhioSpyderman is offline   Reply With Quote
Old 05-22-2009, 10:08 AM   #127 (permalink)
Trader Rating: (26)
Thank you Bob. Appreciate you helping out a fellow Buckeye.
Bob-
Old 06-02-2009, 02:53 PM   #128 (permalink)
Trader Rating: (21)
Does anybody have a 2nd gen VIN or the caps codes I can plug in to caps so I can get 2nd gen part numbers? I'm in the process of a 4bolt conversion and it'd make it alot easier if I could go to the dealer with the part number I need rather than having to rely on them (they've screwed up my order countless times).
'91 VR4 - Rebuild in progress: DR900's + meth and other supporting mods.
Old 06-02-2009, 03:00 PM   #129 (permalink)
oohnoo's Avatar
Trader Rating: (203)
oohnoo Level 1oohnoo Level 1oohnoo Level 1
No need to do that, I never put my vid in.
Open CAPS, Double-click the white area next to Model, a "Vehicle Name Code Section" dialog box opens, Double-Click #16 - OK....Another box opens, Double_click #3 for 3000/4WD/4WS or what ever one you want to look up.
----------------[2007 Ride of the Year.................................. 3.5 Stroker I did. w/DBB DR1000's
oohnoo is offline   Reply With Quote
Old 06-02-2009, 03:15 PM   #130 (permalink)
Trader Rating: (21)
Thanks, but no go. I still end up getting pictures of the 2 bolt block no matter what combo I try. I'm using caps v3.41 if that makes a difference.
