Old 02-25-2009, 11:29 AM   #111 (permalink)
Former ROTY :-}
OhioSpyderman's Avatar
Drives: Back and Forth :)
Trader Rating: (52)
OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3
Default Re: Part # Help Thread! If you have CAPS, help someone out!
Originally Posted by nawz8r View Post
Thank you Bob, appreciate it!
No problemo
Bob.
95 Caracus Red Spyder VR4
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
SBC-iD Boost Controller (in both!!!)
OhioSpyderman is offline   Reply With Quote
Old 03-14-2009, 03:19 PM   #112 (permalink)
Twin Turbo Owner
97mits3kgtSOHC's Avatar
Drives: 95 Pearl White VR4
Trader Rating: (97)
97mits3kgtSOHC is an unknown quantity at this point
anyone know the part numbers for:
-all the bolts for the driver motor mount to the block...either 3 or 4 bolts there i forget its been so long
-crush washers for fuel filter
thanks!
1995 Mitsubishi 3000gt Vr4 - Pearl White
Dr Stage 2 Heads, Dynamic Racing 16ts, New OEM Shorty...BPU...99 front end, intrax/kybs with chrome saleens....interior - corbeau cr-1's, defi bf's......
97mits3kgtSOHC is offline   Reply With Quote
Old 03-16-2009, 02:21 PM   #113 (permalink)
1fstascar's Avatar
Drives: Just a V6.
1fstascar is an unknown quantity at this point
Anybody have the part number for a ETACS unit for a 98 VR4? Thanks!
She is such a show off.
1fstascar is offline   Reply With Quote
Old 03-16-2009, 03:10 PM   #114 (permalink)
Former ROTY :-}
Trader Rating: (52)
MR238955 - Control Unit, Time and alarm (95-Up)
Bob.
Old 03-16-2009, 04:07 PM   #115 (permalink)
1fstascar's Avatar
Drives: Just a V6.
So any ETACS from 95 and on will work? The dealer quoted me at like 350 bucks for that damn thing said it was special only for a 98. Lying bastards.
Old 03-16-2009, 04:13 PM   #116 (permalink)
Former ROTY :-}
Trader Rating: (52)
My version of CAPS (2.66) lists 9504.1 as the last date for that control, so I was assuming that it was good for all later models.
Maybe someone can either back me up or tell me I'm full of bulltwinkies!!!
Bob.
Old 03-20-2009, 09:59 PM   #117 (permalink)
LIKE WHOA
jnight99's Avatar
Drives: 92' Stealth R/T
jnight99 is an unknown quantity at this point
Can someone run this for me in reverse?
MD190004
I need to know what year/model this ECU is for as it doesn't show up on any of our source sites.
Thanks!!!
92' Stealth R/T - Fiji Blue - ATX
jnight99 is offline   Reply With Quote
Old 03-21-2009, 07:31 PM   #118 (permalink)
Twin Turbo Owner
Trader Rating: (97)
thanks!
anybody?
Old 03-26-2009, 04:18 PM   #119 (permalink)
Not here for the tuna.
lawdogg's Avatar
Drives: junk
Trader Rating: (81)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
FYI ..
Originally Posted by Spamsonite View Post
As far as I can tell by looking at 2 old threads on 3si, mn156478 is the part number for a 25 spline 5 spd TC, the threads list it as the "new TC". But if you look at CAPS, they list an old part number, as well as the new one I gave you. You may have trouble finding anyone on this forum who knows the difference for sure. I don't understand what the $400 difference in price is about between MN156072 and MN156478. Doesn't really make sense.
The only solutions I can think of are to: 1. call some big mitsu dealers and ask them (rockville, mentor, etc) or 2. Just order MN156478 and find out first hand if this is exactly what you need.
Here is a quote from the threads I looked at:
"Someone posted the Mitsu part numbers for the replacement TC's under the current "B17" recall (see this thread).
Mits list three part numbers....
MN156477 5-speed small shaft
MN156478 5-speed large shaft
MN156479 6-speed
MN156006 Reseal kit"
This was from 3 years ago.
Originally Posted by SunDown13X
W5MG1-0-FNBR 3000GT 4WD w/ 4WS, 5spd mfg 4/90-5/92
W5MG1-1-FNCR 3000GT 4WD w/ 4WS, 5spd mfg 11/91-5/92
W5MG1-2-FNBR or FCNR 3000GT 4WD w/ 4WS, 5spd mfg 6/92-9/92
W5MG1-3-FNBR or FCNR 3000GT 4WD w/ 4WS, 5spd mfg 10/92-5/93
W6MG1-0-FNBR 3000GT 4WD w/ or w/o 4WS, 6spd mfg 6/93-end
R.I.P.
Old 04-29-2009, 12:03 AM   #120 (permalink)
Jacked on Crank-shafts
Beau_Jester's Avatar
Drives: supercharged 3kGT
Trader Rating: (15)
Beau_Jester is an unknown quantity at this point
MD141687 12x71
MD141688 10x68
MD149778 10x97
MD660064 fuel filter gasket for banjo fitting Q=4
Red 94 Base 3000GT:
Eaton supercharger 360cc injectors, Quaiffe LSD, 15% over 5th gear.
Black 1993 Stealth RT/TT
12/01/09: Car on jack stands. 3/01/10 Engine bored to 3.1L, Pampena pistons, crank polished and balanced. Heads tanked, new seals and guides, port casting imperfections sanded. Tranny new VCU, bearings, friction rings, 300m output shaft. X-case new sleave, bearings, seals.
Beau_Jester is offline   Reply With Quote
