Old 01-16-2008, 01:31 PM   #1 (permalink)
Twin Turbo Owner
97mits3kgtSOHC's Avatar
Drives: 95 Pearl White VR4
Trader Rating: (97)
97mits3kgtSOHC is an unknown quantity at this point
Question Part Numbers Help
i called mitsu and they are having a hard time finding what i need...so can someone look up the part numbers for the following things for me
i need:
-the studs or bolts (3 per turbo) that attach the turbos to the exhaust manifolds as well as any nuts that go with it
-the studs that are on the 02 housing side of the turbos...should be 4 per turbo and any nuts that go with it
-the rear turbo oil feed adapter
thanks in advance
sean
1995 Mitsubishi 3000gt Vr4 - Pearl White
Dr Stage 2 Heads, Dynamic Racing 16ts, New OEM Shorty...BPU...99 front end, intrax/kybs with chrome saleens....interior - corbeau cr-1's, defi bf's......
97mits3kgtSOHC is offline   Reply With Quote
Old 01-16-2008, 03:08 PM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Default Part # Help Thread! If you have CAPS, help someone out!
This thread will be for all the people looking for part #'s that don't have CAPS or can't find them.
Please post up what parts you are looking for, with any luck some kind soul who has CAPS will look it up for you and post!
This is for all the people who can't get part #'s and come looking for a place to get them.
-Ryan
R.I.P.
Old 01-16-2008, 05:42 PM   #3 (permalink)
just some guy.
Racer_X's Avatar
Drives: 94 Stealth Turbo
Trader Rating: (9)
Racer_X is an unknown quantity at this point
Default Re: Part Numbers Help
i need:
thanks in advance
sean
Your parts guys are pretty sad . I just typed in "turbo" and got all the parts that you asked for in caps in a matter of seconds. they aren't even year specific.
front 02 housing studs Metric 10x32 MD165887 (you can find these at a good hardware store)
Front o2 housing nuts Metric 10 MD 132930 (also, hardware store)
Front turbo to manifold bolts Metric 10X35 (hardware store) MD168601
Rear O2 housing studs Metric 10x27 (hardware store) MD050074
Rear oil feed fitting MD145960
Rear oil feed crush washer MF660063
rear turbo to manifold studs (same as FRONT O2 studs and nuts)
Pretty good for 2 shot turbos and a boost leak
Racer_X is offline   Reply With Quote
Old 01-16-2008, 07:55 PM   #4 (permalink)
TPW: Promoter
1veryfastvr4's Avatar
Drives: 97 vr4
Trader Rating: (81)
1veryfastvr4 is an unknown quantity at this point
Default Re: Part # Help Thread! If you have CAPS, help someone out!
bout time we have a spot for this
1veryfastvr4 is offline   Reply With Quote
Old 01-24-2008, 03:40 PM   #5 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: '93 3000GT VR-4
Trader Rating: (22)
AdamVR4 Level 2AdamVR4 Level 2AdamVR4 Level 2AdamVR4 Level 2
Random fact...
2-BOLT REAR MAIN SEAL ASSEMBLY (SEAL & HOUSING) : MD125544
For those in the dark, "2-bolt" refers to the number of bolts directly supporting each main of your crank. These were typically found in the '91-'92 model year cars. The only way to be sure? Pull your oil pan.
PEARL WHITE '93 VR-4 // Now running...
E16G's: 10.573 @ 135.01
(Trevor owns me )
E16G's: 11.28 @ 124.7
(Pure pump gas ET record )
14B's: 11.10 @ 127.3
(AWD 14B ET record. Take THAT, Trev! )
9B's: 12.78 @ 107.1
Congrats to the current top 10 members!!
DynamicRacing: US 3S Top 10 Fastest List
10th Amendment: The powers not delegated to the United States by the Constitution, nor prohibited by it to the States, are reserved to the States respectively, or to the people.
GIVE ME LIBERTY, OR GIVE ME DEATH!
AdamVR4 is offline   Reply With Quote
Old 02-18-2008, 10:01 AM   #6 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
For leaking oil cooler "crush washers"!
$1.45/ea. Part # MB033054 - Gasket, Engine Oil Cooler
http://www.rockvillemitsubishi.com/p...vice/parts.jsp
Old 03-07-2008, 02:36 PM   #7 (permalink)
Official Member
BjornRune's Avatar
Drives: The big whale
Trader Rating: (8)
BjornRune is an unknown quantity at this point
I need part # for the two outer covers for the '99 wing. My caps does not carry any part numbers for them.
Anyone?
Black 1994 VR-4
Green 1994 VR-4
Blue 1998 GTO MR
Green 1994 VR-4
15G's, AEM EMS, 550's and the lot.
Originally Posted by 05SDI
The good news is I need a new motor
BjornRune is offline   Reply With Quote
Old 03-09-2008, 12:48 PM   #8 (permalink)
Former ROTY :-}
OhioSpyderman's Avatar
Drives: Back and Forth :)
Trader Rating: (51)
OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3
MR412991, I think it comes only in silver?
Bob.
95 Caracus Red Spyder VR4
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
SBC-iD Boost Controller (in both!!!)
OhioSpyderman is offline   Reply With Quote
Old 03-09-2008, 01:52 PM   #9 (permalink)
Official Member
BjornRune's Avatar
Trader Rating: (8)
Bob to the rescue! Awesome, I need it asap but of course the local mitsu stealership didn't know what the heck I was talking about.
Thanks Bob
Old 03-09-2008, 03:14 PM   #10 (permalink)
Former ROTY :-}
Trader Rating: (51)
Uhhh...MR412992 is the right...sorry, I forgot to mention that
Bob.
