#31 (permalink) |
Automotive Geek
Can someone supply the part numbers for the seals / gaskets between the rear active aero spoiler and the trunk? There are three seals two of them may be the same (left and right), I'm not sure. This is for my '93.
Thanks, -Greg
93 VR-4 K&N FIPK, Eibach Pro Sport springs, MSD 8.5mm wires, NGK iridium plugs, solid polyurethane motor mounts, Sumitomo HTR+ tires, gutted precats, adjustable rear control arms, 99 lifters, underhood and console shifter bushings, aluminum dash vents, clutch vacuum assist delete, GM boost logging, full set of Defi gauges. Always a work in progress...
#32 (permalink) | ||
Former ROTY :-}
MR358264 (2) (left and right are the same)
MR358263 Center Bob. ![]()
#33 (permalink) |
Wannabe
I need the rubber boot that goes on the outside of the front turbo for the intake pipe to fit on right...
and the hose that goes from the brake booster to the driver side of the intake plenum. It has the checkvalve in it for the brake booster.
![]() 1991 3000GT VR-4 1992 3000GT VR-4: Work in Progress |
#36 (permalink) | |
Puts Out On 1st Date !
According to caps the brake booster hose with the chack valve goes from the metal line on the fire wall to the nipple by the throttle body on the back of the plenum. It is part #MB857312
Driver of Turbo Dodges. A '92 Stealth RT/TT and an '03 Ram 2500.
Stealth - 15G's,FMIC,E-Manage Ultimate and other supporting goodies Ram 2500 - Single turbo, FMIC and 4" exhaust (aka-stock) |
#37 (permalink) |
Here for the tuna.
Just an FYI, part # MB621817 has been discontinued. This is the metal 'protector' for the rubber fuel tank filler hose. Crap.
2002 WJ -- 1994 VR-4 -- 1993 ZJ --Canon Rebel XTi ![]() |
#38 (permalink) |
RTBOOST
As the title implies, I'm trying to figure out the part numbers for gaskets (three in total) for my Stealth's rear spoiler. Thanks!
![]() I'm also trying to find the factory coin holder (gray in color) as well as the reverse light switch gasket (3SX wants $17.89 S+H for those two items). Thanks again!!
'73 Dodge Challenger 340.............................(X)
'91 Firestorm Red Stealth R/T TT...................(X) ![]() Last edited by Street_Chally73 : 05-22-2008 at 07:29 AM. Reason: Updated Information |
#39 (permalink) | |
Former ROTY :-}
Sorry. Bob. |
#40 (permalink) |
If I have a part # could someone tell me which models the part will fit?
The part # is MR147669. Its a compressor and clutch assy. Its a 4 bolt for a dohc. Its a mitsu part made for an install by dodge dealers. Some of the other parts in the kit I have matched already. Oh and its made in Japan. Thanks Joe.
![]() Some people are alive simply because it's illegal to kill them!! If I help you out, please help make the community better and pay it forward. Last edited by mugs : 06-02-2008 at 05:10 PM. Reason: Added info and a Thank-you. |
