Old 09-22-2008, 06:17 PM   #1 (permalink)
Jonfish490
jonfish490's Avatar
Drives: on jack stands
jonfish490 is an unknown quantity at this point
Default Outer tie rod problem
Another issue with getting my car all pack together and everything is that the threads on my one outer tie rod end is stripped. I tried to find a die for it but can't seem to find one. I know the pitch is 1.25 and I'm pretty sure that it is 12 for the die. Also I do not want to replace the whole tie rod end because it is still in good shape. Anyone else ever have this issue?
Will be done VERY soon...
92 Stealth TT
4 Bolt block
Forged crank
3SX rods
Wiseco pistons .030" over CR 8.3:1
"Ebay" FMIC
Valves and seats cut
New OEM springs
99 Lifters
Heads and block painted with Glyptal
15g's
3SX's oil line kit
IPS's oil cooler kit
ABS delete
Cruise delete
EGR delete
AC delete
Modified alternator belt
Fidanza Flywheel
Spec Stage 4+ Clutch
Vacuum reduction
Gutted cats
3 inch full exhaust
Greddy Pro Spec B Boost controller
TurboXS Type H-RFL BOV
jonfish490 is offline   Reply With Quote
Old 09-22-2008, 06:25 PM   #2 (permalink)
Curmudgeon
Steve '93ES's Avatar
Drives: '93 ES, '92 TT
Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7
Default Re: Outer tie rod problem
For the $35 bucks or so a new one cost I don't think I'd mess with it.
A die like that will probably cost you that much anyway...
Steve '93ES is online now   Reply With Quote
Old 09-22-2008, 06:31 PM   #3 (permalink)
Black Beast Rebuild 94%
TT4ME's Avatar
Drives: 94 TT, 92 ES, 92 TT
Trader Rating: (11)
TT4ME Level 7TT4ME Level 7TT4ME Level 7TT4ME Level 7TT4ME Level 7TT4ME Level 7TT4ME Level 7TT4ME Level 7
1st off.. how did it end up stripped???
2nd Buy a new one, they are cheap.
TT4ME is online now   Reply With Quote
Old 09-22-2008, 06:57 PM   #4 (permalink)
***** User
Tricky222's Avatar
Drives: 91 VR4
Trader Rating: (63)
Tricky222 Level 5Tricky222 Level 5Tricky222 Level 5Tricky222 Level 5Tricky222 Level 5Tricky222 Level 5
I agree, just replace it.
However if you dont want to, im sure changing the pitch to something more common wouldnt hurt anything
Tricky222 is online now   Reply With Quote
Old 09-23-2008, 08:19 AM   #5 (permalink)
Bob
Class of '60
Bob's Avatar
Drives: 1994 3000GT
Trader Rating: (8)
Bob is an unknown quantity at this point
2nd.. Buy a new one, they are cheap.
I ditto that.
Bob
3si member #362
'94 3000GT
Bob is offline   Reply With Quote
