Old 07-23-2008, 06:52 PM   #21 (permalink)
Engineering Student
Alex3000GT's Avatar
Drives: 92 3000gt base
Trader Rating: (12)
Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7
Default Re: Oil pan leak: WTF am I doing wrong?
Originally Posted by alex10superman View Post
I'm not using any type of gasket.... as far as I know they don't exist for this car
-I'm using this: Stealth 316 - Oil Pan
-I clean all the surfaces (block and pan)
-Add RTV in equal amount around the entire rim of the pan
-place the pan onto the block and I put one bolt in each corner just enough to hold the pan
- I then go through and put each bolt in finger tight (not really in a patern but not one right after the other either.... just kinda switch sides each time)
- Then I go through and tighten each bolt in the pattern described on stealth316.
That is why you are getting a leak. There is supposed to be a solid gasket in there. The price is $8.99.
AutoZone.com | Vehicle Selection - Year
NG06 - DOHC NA - ATX --- 16.6 --- 85 MPH
NG07 - DOHC NA - MTX --- 15.7 --- 89 MPH 7.78 sec 0-60 3,044 lbs w/out driver
1992 3000GT
1991 Stealth
Alex3000GT is online now   Reply With Quote
Old 07-23-2008, 06:59 PM   #22 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (13)
When I had a leak it was because the pan had been tightened down to the point where the bolt holes had bent inwards/invaginated, causing high/low points on the pan. To fix the problem I took a punch and hammered out the holes from the inside --> out.
Old 07-23-2008, 07:20 PM   #23 (permalink)
oohnoo's Avatar
Trader Rating: (137)
oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7
Ummm there's no gasket for our oil pans. I checked on AutoZone and they don't list one for a '97, but for some reason list one for a '91. I also checked with CAPS and it doesn't list one either. Also checked on steath316 and he doesn't list one also. 3 strikes - Guess who's wrong.
oohnoo is offline   Reply With Quote
Old 07-23-2008, 07:29 PM   #24 (permalink)
Trader Rating: (13)
Canadian Tire lists a cork gasket for Stealth's only (lol) that I wasn't very fond of.
Old 07-24-2008, 08:19 AM   #25 (permalink)
I love my VR-4!!!
alex10superman's Avatar
Drives: 1997 3000GT VR-4
alex10superman Level 1alex10superman Level 1
+1
Plus, isn't the 91 oil pan different than the 97 (2 bolt vs. 4 bolt). So I would imagine that the gasket may be slightly different.
More Pictures of my car here -> Pics
Mod List of my car here -> Mods
alex10superman is offline   Reply With Quote
