Old 07-23-2008, 06:52 PM   #21 (permalink)
Engineering Student
Alex3000GT's Avatar
Drives: 92 3000gt base
Trader Rating: (12)
Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7
Default Re: Oil pan leak: WTF am I doing wrong?
Originally Posted by alex10superman View Post
I'm not using any type of gasket.... as far as I know they don't exist for this car
-I'm using this: Stealth 316 - Oil Pan
-I clean all the surfaces (block and pan)
-Add RTV in equal amount around the entire rim of the pan
-place the pan onto the block and I put one bolt in each corner just enough to hold the pan
- I then go through and put each bolt in finger tight (not really in a patern but not one right after the other either.... just kinda switch sides each time)
- Then I go through and tighten each bolt in the pattern described on stealth316.
That is why you are getting a leak. There is supposed to be a solid gasket in there. The price is $8.99.
AutoZone.com | Vehicle Selection - Year
NG06 - DOHC NA - ATX --- 16.6 --- 85 MPH
NG07 - DOHC NA - MTX --- 15.7 --- 89 MPH 7.78 sec 0-60 3,044 lbs w/out driver
1992 3000GT
1991 Stealth
Alex3000GT is offline   Reply With Quote
Old 07-23-2008, 06:59 PM   #22 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (14)
When I had a leak it was because the pan had been tightened down to the point where the bolt holes had bent inwards/invaginated, causing high/low points on the pan. To fix the problem I took a punch and hammered out the holes from the inside --> out.
DoctorDex is online now   Reply With Quote
Old 07-23-2008, 07:20 PM   #23 (permalink)
oohnoo's Avatar
Trader Rating: (145)
oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7
Ummm there's no gasket for our oil pans. I checked on AutoZone and they don't list one for a '97, but for some reason list one for a '91. I also checked with CAPS and it doesn't list one either. Also checked on steath316 and he doesn't list one also. 3 strikes - Guess who's wrong.
oohnoo is online now   Reply With Quote
Old 07-23-2008, 07:29 PM   #24 (permalink)
Trader Rating: (14)
Canadian Tire lists a cork gasket for Stealth's only (lol) that I wasn't very fond of.
Old 07-24-2008, 08:19 AM   #25 (permalink)
I love my VR-4!!!
alex10superman's Avatar
Drives: 1997 3000GT VR-4
alex10superman Level 4alex10superman Level 4alex10superman Level 4alex10superman Level 4alex10superman Level 4
+1
Plus, isn't the 91 oil pan different than the 97 (2 bolt vs. 4 bolt). So I would imagine that the gasket may be slightly different.
More Pictures of my car here -> Pics
Mod List of my car here -> Mods
alex10superman is offline   Reply With Quote
Old 09-14-2008, 09:05 AM   #26 (permalink)
I love my VR-4!!!
Well, I finally got around to redoing the gasket again (i know its been awhile but two jobs and full time school keeps me pretty busy ). Anyway, I ended up getting a tube of the Mitsu gasket maker, this stuff: Mitsubishi Engine & Transmission Silicone Gasket Sealant*-*Mitsubishi 3000GT*/*Dodge Stealth
for free from the dealership here! So, I figured it was worth a try. I followed the same procedure (as far as what I have read it is the correct one) and guess what? It still leaks
So, I'm 99.9% sure that it is coming from the pan as I can see it dripping down from there and it flows off of the transfer case. Since I have done this 4 times and counting now, is there any other place that you can think of that it could be leaking from other than the pan? I pretty sure its not the Rear Main as the leak only happens after the car shuts off. Thanks for any input!
Old 09-14-2008, 10:02 AM   #27 (permalink)
3SNJ Pres
91STT's Avatar
Drives: 91 Stealth R/T TT
Trader Rating: (14)
91STT level 691STT level 691STT level 691STT level 691STT level 691STT level 6
Try finding someone around you that can take a look at it. Sometimes a fresh pair of eyes helps.
1991 Stealth R/T TT
Mods: Practically stock but not for long
91STT is online now   Reply With Quote
Old 09-14-2008, 01:08 PM   #28 (permalink)
I love my VR-4!!!
LOL, I'm considering taking over to Matt at DR (only like 45 min. away) and having him do it.... but I hate having to pay someone for something that I "should" be able to do. I will have to get a fresh pair of eyes to take a look though.... as mine are burning from the agony
Old 09-15-2008, 01:01 AM   #29 (permalink)
gearheadvr4's Avatar
Drives: Pucking VR4
Trader Rating: (25)
gearheadvr4 Level 3gearheadvr4 Level 3gearheadvr4 Level 3gearheadvr4 Level 3
My vote is for a rear main seal. Regardless of whether you thought it was leaking before or not.
I agree that you need to get a local 3s guy take a look at it with you.
Permanently broke! But her soul will be reborn into another VR4 soon. 92 VR4- Rebuilt engine with forged crank, TD05 manifolds with MHI EVO 3 16g, 6 speed conversion done, Maximal Solid Mounts, front mount 3" w/custom intercooler and intake pipes, OFE Stage 3 Clutch (from Southbend Clutch), SS clutch line, SS brake lines, SS oil and coolant lines, borla exhaust, stillen downpipe, egr block-off plates, LC-1 Wideband, blitz dc2 turbo timer, hks ssbov, Maft Pro speed density, Blitz SBC i-D III boost controller w/ Power Meter, k&n filters & custom intake pipes, gutted cats, 18x9 blitz type 03 wheels wrapped in Nexen N3000 tires, intrax springs, adj. control arms, 97 frontend and side conversion, 99 center tail light piece (<--adds at least 20hp on the dyno )
gearheadvr4 is online now   Reply With Quote
Old 09-15-2008, 05:03 AM   #30 (permalink)
Regulator...
mikes2nd's Avatar
Trader Rating: (31)
mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7
yep rear main seal. did you replace it?
mess with it?
Hijacking semi's with black Civics since 2001...
mikes2nd is offline   Reply With Quote
