LinkBack (1) Thread Tools
Old 04-16-2008, 08:22 AM   #11 (permalink)
wrecked is an unknown quantity at this point
Default Re: Oil change disaster....lol
ahh the old double gasket mod.
wrecked is offline   Reply With Quote
Old 04-16-2008, 08:43 AM   #12 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Happened to me with a Fram filter once! Fram FTL! Check your filters before installing!
R.I.P.
Old 04-16-2008, 12:36 PM   #13 (permalink)
3SNY - HondaTurtleFTW
FluffyCow's Avatar
Drives: 91 ES, 91 R/T TT
Trader Rating: (6)
FluffyCow is an unknown quantity at this point
At least nobody here has done an oil change, and went to fire the engine up with the drain plug still out...
1991 Dodge Stealth ES
- The car that started the 3S obsession
Mods: Open air filter, "resonator" bottle removed, Off the road, deciding on selling or parting out :'(
1991 Fiji/Mystic Blue R/T TT 1 of 235(paint/R/T TT only, can't find more info, VIN is a 1 of none number)
Show: First-gen VR-4 rims, Dual illuminite speakers. Soon: second-gen rear bumper
Mods: RPS full face clutch, Fidanza flywheel, ATR downpipe, TurboXS dual stage boost controller(10 PSI and 13-15(need tuning device)), K+N fipk, Kormex 25 spline, recall transfercase. 180k service done thanks Clint. EGR Blockoff and Vac Reduction. Soon: Fix hot-start issues(Bigger injectors ftw) and coolant/oil temp issues, water/meth injection, some sort of real tuning device, Aluminum stock pulley, DSM Sidemounts, solid motor mounts.
1987 Dodge Ramcharger - The back-up plan. Mods: Non-computerized timing, custom white gauge faces and red LED illumination, cat-back straight pipe, Chevy seats, Ford running boards, and Mopar everything else.
FluffyCow is offline   Reply With Quote
Old 04-16-2008, 01:28 PM   #14 (permalink)
Paid Member
NoBrakes's Avatar
Drives: 92 VR4
Trader Rating: (7)
NoBrakes is an unknown quantity at this point
Yup, this must be a trend with Fram filters. Happened more than once on my last Mustang, now out of habit I always check the old filter to make sure that gasket is still on the old filter.
93 Mustang GT, white 5spd- broke tranny, traded for:
91 Galant VR4, belize green 1189/2000 - broke tranny, sold
02 Focus SVT, black 3 door - drove it like I stole it for a month and traded for:
00 Mustang GT, dark red 5spd - a year of burnouts and donuts, sold
92 3000GT VR4 - garage queen wearing out its welcome
97 Ranger...bought an extra vehicle cause I needed to get to work on monday when the garage queen broke
NoBrakes is offline   Reply With Quote
Old 04-16-2008, 01:36 PM   #15 (permalink)
Boosted :D
Gushers248's Avatar
Drives: S-10, 2 '95 turbos
Gushers248 is an unknown quantity at this point
Every time I change my oil I always check that. My shop teacher back in high school told me about that happening to one of his cars.
Thats pretty funny that she fired it up to put it in neutral though.
'91 VR-4 (sold) '01 A6 2.7t (sold) '95 R/T TT (project in the building)
Originally Posted by 3KGT2NV View Post
if my car had boobs i wouldnt need my wife anymore.
Gushers248 is offline   Reply With Quote
Old 04-16-2008, 01:43 PM   #16 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 is an unknown quantity at this point
Been there!!!
Jeff W.
www.xpauto.net
Red '92 VR4 226,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy
Big 16G Turbos w/IPS headers and pre-cat eliminators, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS Stage 5 clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PowerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 04-16-2008, 02:56 PM   #17 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (13)
SkortchGT Level 1SkortchGT Level 1
This happens to me almost everytime I change the oil on my Malibu. I use only the best filters on the Malibu - Fram or SuperTech
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, cat back & CFDS, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, PST 1pc CFDS, Borla Catback, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, engine dress up kit, Bigtyla ground wire kit, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset.
--Waiting for me to install: ARC2 w/ 92mm MAS
--Daily Driver: 2000 Malibu, 6cyl, auto
SkortchGT is offline   Reply With Quote
Old 04-16-2008, 05:24 PM   #18 (permalink)
Dutch by nature!
Drives: 3000GT VR4
Climber is an unknown quantity at this point
Originally Posted by GTO Assassin View Post
Cleaning oil up sucks ballz!
Scotty
My biggest gripe regarding working on cars myself. That and the melted rubber from burning out bushings
Double gasket never happened to me, but I read that this happened a lot on the Honda Elements and since their oil filter is above the exhaust, this resulted in a nice number of fires.
Come to think of it, the first time I replaced the filter on my wife's element it was a b**ch to get off.
Man, I love K&N filters with the built in hex "nut".
Climber
Life's too short to go slow.
Climber is offline   Reply With Quote
Old 04-16-2008, 06:15 PM   #19 (permalink)
Drives: 1992 vr4
leadfoot is an unknown quantity at this point
Changed my oil yesterday, don't have to worry about gaskets anymore. I have a life time filter of T6 billet aluminum housing, T 304 Stainless Steel filter and Viton seals. I can remove the canister and the filter at any time for inspection and or cleaning.
leadfoot is offline   Reply With Quote
Old 04-16-2008, 06:48 PM   #20 (permalink)
Dutch by nature!
Drives: 3000GT VR4
But you have to clean the filter?
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/oil-change-disaster-lol-415834/
Posted By For Type Date
Oil change disaster....lol - 3000GT/Stealth International Message Center This thread Refback 04-17-2008 08:57 AM
