LinkBack (1) Thread Tools
Old 04-16-2008, 01:17 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
I see what you did there.
2004formula's Avatar
Drives: 97 Vr-4, 99 T/A
Trader Rating: (7)
2004formula Level 12004formula Level 1
Default Oil change disaster....lol
so im out changing the oil on all the cars today, i was even nice enough to do my gf/s talon...everything was going fine up until i had her warm the car up so i could check the dipstick and find out how much of the fifth qt i had to add...upon starting there were huge slurping sounds or air trying to come up through the oil fill cap...i shrugged it off at first, but then checked the dipstick quick... after finding it dry i told her to shut the car off as i continued to puzzle over this abnormality...anyways, just for shits n giggles (as i knew i had put the screw back in and the filter on tight i realized the gravel underneath the car was covered in new quaker state oil...I sighed, not knowing exactly what happened..i figured maybe i put the wrong filter on as i had to buy 5 one for each car...told the gf to put the car in neutral so we could push it back to a dry spot so i could go under, and the genius fires the engine up to do it.... i scream at her to turn the engine off (luckily nothing happened) and showed her how you put the car in neutral without turning the damn thing on...we get it into position and i get under the car, take the filter off (where it was spewing from, and i mean spewing...oil was everywhere) and match it up to the old filter...size was fine, but upon closer inspection i realized the o-ring gasked was nowhere to be found in the old filter...apparently it had been so long since she changed the oil, the old gasket didnt want to leave, and there really wasnt anyway 2 gaskets were going to hold the oil in the tank...sigh...now im left with a big mess in the driveway and am down 5 qts of oil...i guess it coulda been worse with a shot engine... just thought id share..
2004formula is offline   Reply With Quote
Old 04-16-2008, 01:22 AM   #2 (permalink)
Mitsubishi Junkie
Joel_CA's Avatar
Drives: 2 Pearly Whites
Joel_CA Level 1Joel_CA Level 1
Default Re: Oil change disaster....lol
Common mistake- happens alot with Fram filters where the gasket stays behind unknowingly. Glad you caught it early.
JJ
1992 3000GT VR4 (tastefully modified) & 1996 STEALTH RT/TT #47 (restoration work in progress)
Joel_CA is online now   Reply With Quote
Old 04-16-2008, 01:24 AM   #3 (permalink)
akotten's Avatar
Drives: '06 Ninja 636
akotten is an unknown quantity at this point
I've had that happen to me twice on my Explorer....the first time was when my sister had it....and so eventually, not right away, the oil drained out. She didn't know any better and fried the motor. I caught it the last time though thank god! (both were Fram filters FYI)
akotten is offline   Reply With Quote
Old 04-16-2008, 02:50 AM   #4 (permalink)
Drives: Red 1991 VR-4 (#3)
ZephTheChef is an unknown quantity at this point
This happened to me once changing the oil on my friend's car. I get it all done, we put oil in, and I tell him to fire it up. I peek under the car to look for leaks and it was just spraying out everywhere. Of course the kid decides to rev the engine up to like 5,000rpm immediately after he gets it started and the large oil spray turns into a high pressure oil spray that shot all the way across the shop...covering me in oil along the way. The whole time I'm yelling at him to shut off the car, but of course he can't hear me because he's got the engine revved up, so not until I stand up and he sees me covered from head to foot in oil does he turn off the car.
Don't you love working with friends who don't know anything about cars?
"why its a tubloidial butt noid!" - Ray Pampena, 2006
ZephTheChef is offline   Reply With Quote
Old 04-16-2008, 03:01 AM   #5 (permalink)
RTBOOST
Street_Chally73's Avatar
Drives: '91 Stealth R/T TT
Trader Rating: (8)
Street_Chally73 is an unknown quantity at this point
Don't feel too bad. My dad's friend did the same thing with his motorcycle and fortunately for him, I noticed it before any major damage was done. Let's just say we were able to tell exactly where he turned on the roadways, starting from his driveway to ours.
'73 Dodge Challenger 340.............................(X)
'91 Firestorm Red Stealth R/T TT...................(X)
Street_Chally73 is offline   Reply With Quote
Old 04-16-2008, 03:26 AM   #6 (permalink)
Trader Rating: (7)
lol k, this had never happened to me before so i was a bit worried...actually the gasket left behind was from a pennzoil filter...i replaced with a fram, i've never had a problem with them..then again, im not like my gf and wait 45956045457 miles to replace it...
Old 04-16-2008, 03:47 AM   #7 (permalink)
I've been here way too long
Colt45 GTO's Avatar
Drives: Like an Idiot
Colt45 GTO Level 1Colt45 GTO Level 1
i always wipe the filter housing face with a rag just to make sure the'res no crap gor on there also as an inspection, this is becuase its happened to me in the past but i didnt catch it. cost me a motor! i was younger then i think i was 18 and the car was an old beater so it wasn't too bad. but still its things you learn along the way.
Colt45 GTO is offline   Reply With Quote
Old 04-16-2008, 03:53 AM   #8 (permalink)
Crap - you got me!
GTO Assassin's Avatar
Drives: 1993 Mitsubishi GTO
Trader Rating: (33)
GTO Assassin Level 1GTO Assassin Level 1
Cleaning oil up sucks ballz!
Scotty
GTO Assassin is offline   Reply With Quote
Old 04-16-2008, 03:58 AM   #9 (permalink)
Trader Rating: (7)
ya...good thing for me i was doing it on gravel... lol
Old 04-16-2008, 04:36 AM   #10 (permalink)
Crap - you got me!
Trader Rating: (33)
So, far from the disaster I was anticipating. Could have been so much worse.
Scotty
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/oil-change-disaster-lol-415834/
Posted By For Type Date
Oil change disaster....lol - 3000GT/Stealth International Message Center This thread Refback 04-17-2008 08:57 AM
