#12 (permalink) |
To verify, this is black carpet number? I looked it up it just says Item Number MSRP Core Price Price
Mr751594 $565.48 $0.00 $424.11 MAT,FLOOR Ugh. Thats from mentor.
Go:DR650's, Stage 3 heads, webcam street/strip cams, ferrara 1mm oversized valves w/high rev kit, built block, 550cc injectors, MAP ECU, IPS FMIC kit, koyo radiator, twin flexalite fans, IPS radiator pipes, Dejon twin intake, kormex output shaft, RPS street max, e2k xfer case bracket, fidanza flywheel, stillen cross drilled/ slotted rotors (front & rear), eibach prosport lowering springs (1 & 1.5drop), atr dp, custom dual 2.5" catback, gutted precats,hks ssbov,hks boost controller, maximal solid motor mounts, setrab oil cooler, 3sx SS clutch line, ohio seattle throw shifter w/ solid bushings
Show: Cianci pillar, cobalt boost guage, cobalt air/fuel ratio guage, cobalt oil pressure gauge, cusco rear struct bar, 99 conversion (complete), deftspyer CF hood, clear turn signals, momo steering wheel, battery relocation, tint, momo shift knob/shift boot, 3sx engine dress up kit, 5zigen FN01RC's, Sparco Torino seats Weight reduction: Rims, seats, exhaust, cf hood, DELETE: Egr, vac reduction, AC, cruise control, both washer fluid resevoirs, battery tray and bracket, SRS system, Active exhaust+all wiring, active aero+all wiring, all heat shields, both impact beams, fog lights, rear seats, front and rear seatbelts, clutch booster canister and lines, hood latch, stock alarm, hood pistons And much, much more. --> |
#13 (permalink) | |
I'm really just going to suck it up and get the OEM piece this time around. |
#14 (permalink) | |
most people SUCK at life
#15 (permalink) | |
1995 VR-4
Even at 450, I'd consider getting it new from Mitsu, can't beat OEM fit/finish/quality and ease of install. |
#16 (permalink) |
cherry hill mitsubishi has it for
395.84 not bad
15g, M's fuzzy logic boost controller, Blitz sus filter, Blitz custom cat back, 660cc inj , DN downpipe, gutted precats, test pipe,hotwire fuel pump, Ek2 fuel rail loop,255 supra pump MSD dis solid motor mounts
td05 adapter plates 2 mitsubishi evo 16g turbos act max street clutch aem wideband o2 msd wires Greddy EMU with all the goodies front mount intercooler |
#17 (permalink) |
Here for the tuna.
Rejuvenating that old rug…with pictures
![]() In the future, can we try to use the part # thread stickied at the top? Thanks guys.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts ![]() |
#18 (permalink) | |
Thanks for the heads up on cherry hill as well. |
#19 (permalink) |
1995 VR-4
I went through mentor, and i went back through my order history with them. It was 360 when I purchased it in 06. But unfortuneatly, it just says OEM carpet Black, it doesn't list the part numbers in my order history. I dont know what the number is.
