#1 (permalink) |
Black preferably ( I believe first gens are charcoal.. but should all be interchangable correct? ) can't seem to find it.
Also, is cheapest place to get it still mitsupartsdirect ? (Rockville mitsu)
Go:DR650's, Stage 3 heads, webcam street/strip cams, ferrara 1mm oversized valves w/high rev kit, built block, 550cc injectors, MAP ECU, IPS FMIC kit, koyo radiator, twin flexalite fans, IPS radiator pipes, Dejon twin intake, kormex output shaft, RPS street max, e2k xfer case bracket, fidanza flywheel, stillen cross drilled/ slotted rotors (front & rear), eibach prosport lowering springs (1 & 1.5drop), atr dp, custom dual 2.5" catback, gutted precats,hks ssbov,hks boost controller, maximal solid motor mounts, setrab oil cooler, 3sx SS clutch line, ohio seattle throw shifter w/ solid bushings
Show: Cianci pillar, cobalt boost guage, cobalt air/fuel ratio guage, cobalt oil pressure gauge, cusco rear struct bar, 99 conversion (complete), deftspyer CF hood, clear turn signals, momo steering wheel, battery relocation, tint, momo shift knob/shift boot, 3sx engine dress up kit, 5zigen FN01RC's, Sparco Torino seats Weight reduction: Rims, seats, exhaust, cf hood, DELETE: Egr, vac reduction, AC, cruise control, both washer fluid resevoirs, battery tray and bracket, SRS system, Active exhaust+all wiring, active aero+all wiring, all heat shields, both impact beams, fog lights, rear seats, front and rear seatbelts, clutch booster canister and lines, hood latch, stock alarm, hood pistons And much, much more. --> |
#4 (permalink) |
Cyberwwolf!!
I think:
beige: MB772297 / MR740506 RP GRAY: MB766560 / MR740505 RP RED: MB776795 / MB776796 or you can just download CAPS from my site and check it with your VIN to find the black one
1992 Dodge Stealth RT/TT
Engine: K&N open intake, polished plenum, powdercoated valve cover, polished radiator cover, painted timing belt covers, red silicone hoses,cold air intake, chrome oil cap,Polished engine cover kit,... Exhaust:Stainsless steel catback with no mufflers and stock tips look,test pipe. Interior: Stainsless Stell door sills, autometer gauges. Suspensions: Tein S.tech springs, -2° camber... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ---> http://www.dodgestealth.it <--- |
