Old 05-07-2008, 07:50 PM   #1 (permalink)
Paid Member
Alt0id's Avatar
Drives: '94 3000GT SL
Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7
Default Odd noise front left wheel
Problem I just noticed a few weeks ago, not a huge deal, but annoying.
When I am driving at any speed there is a rotational noise coming from the front left tire. I have changed the brakes and it is still there so it isn't them rubbing or anything (rotors too..).
If I had a guess I would say it is just uneven tread wear (my tires are so in the tread department)
I will be doing a rotation then, eventually, putting new ones on.
But, I just want to know what else could be the cause of this.
I just broke the 100k mark so I am not thinking it is any bearings, but you all know more than I.
As I said, my first guess it just treadwear being uneven, but I want to know what I could be dealing with here.
Alt0id is online now   Reply With Quote
Old 05-07-2008, 07:55 PM   #2 (permalink)
q2418130103p's Avatar
Drives: 1993 Mits 3000gt VR4
q2418130103p Level 1q2418130103p Level 1
Default Re: Odd noise front left wheel
i dont really think this is it, but check the dust shield for the front brakes, ive accidently bent it into the rotor a couple times....
Want to Buy:
  • Door Interior with no bubbles
q2418130103p is offline   Reply With Quote
Old 05-07-2008, 08:00 PM   #3 (permalink)
Paid Member
Alt0id's Avatar
Well, I didn't think about that but this noise comes in and out based in the rotation of the tire it sounds like. So its on off, on off etc. like lets say something was warped, you rotated it, sometimes it would hit other times it wouldn't.
Sorry, not a very good explanation, but I wouldn't think the dust shield would hit sometimes and not others, could be wrong and will definitely look, thanks for the quick response!
Old 05-07-2008, 09:22 PM   #4 (permalink)
Kelgalis's Avatar
Drives: '92 3000GT SL
Trader Rating: (7)
Kelgalis is an unknown quantity at this point
Try jacking up the car and see if the wheel has any play.
- Kyle
'94 3000GT Base ATX - Sold
'94 Stealth RT/TT - Sold
'92 3000GT SL Pearl White
Xbox Live Gamertag: | 3STwinTurbo |
Kelgalis is online now   Reply With Quote
Old 05-07-2008, 09:43 PM   #5 (permalink)
3s in florida!
Driftersdr's Avatar
Drives: 95 3k, 04 cbr600
Driftersdr Level 4Driftersdr Level 4Driftersdr Level 4Driftersdr Level 4Driftersdr Level 4
Wheel bearings can go early..parents had an 01 impala where the tranny went and then soon after the wheel bearings in the front both went at 57k. Sounds like you need to check your bearings!
Looking for:
17/18inch rims with good tires (prefer 5zigen! or another 5spoke)
NA Testpipe
Passport x50 blue
junker 2nd gen lexan headlights any color
2g cf hood
Driftersdr is offline   Reply With Quote
Old 05-08-2008, 07:33 AM   #6 (permalink)
Super Asurada SA-01
Prime12's Avatar
Drives: 97 VR-4
Prime12 Level 3Prime12 Level 3Prime12 Level 3Prime12 Level 3
+1 for wheel bearing. I had that kind of odd noise coming from my right front wheel, and I didn't believe it was wheel bearing either. But it indeed was...
Prime12 is offline   Reply With Quote
Old 05-08-2008, 08:05 AM   #7 (permalink)
I ♥ JDM Hoes Too!
10CentGT's Avatar
10CentGT is an unknown quantity at this point
I had such a problem and it turn out that my wheels were not tied down to spec, 100Ib. Check that too.
Originally Posted by Trevor View Post
Like a f-ing rocket ship. The thing is absolutely rude and completely uncalled for. Usually with the E316G's I'd do a little mental prep before romping on it and have at it...no fear. With this thing I can't seem to prepare enough to overcome the anxiety I have during a pull. It pulls so hard it really kicks in your "holy s^#t I'm going to die" response.
10CentGT is online now   Reply With Quote
Old 05-08-2008, 08:35 AM   #8 (permalink)
My Stealth is Confused...
Stealth_E's Avatar
Drives: w/o a front plate OH
Trader Rating: (6)
Stealth_E Level 1Stealth_E Level 1
If it's a wheel bearing on one side, you should notice the sound come and go as you turn left or right the slightest amount, in essence "loading" and unloading the bad bearing. If it doesn't vary w/ that, then I would stick w/ the treadwear idea.
P.S. - I just replaced my driver's side bearing at 75k
Garage queen for a bit, but will return lower and sexier soon enough
93 Stealth/GT Hybrid http://www.3si.org/forum/showthread.php?t=393736
Stealth_E is offline   Reply With Quote
Old 05-08-2008, 08:56 AM   #9 (permalink)
2 + 2 is CHICKEN!
TwIzTeD_3kGt's Avatar
Drives: 1997 VR4 / 1994 SL
Trader Rating: (11)
TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7
Bearings can go at any mileage. +1 for wheel bearing.
TwIzTeD_3kGt is offline   Reply With Quote
Old 05-08-2008, 10:00 AM   #10 (permalink)
evoxmr is an unknown quantity at this point
I think it is your wheel bearing. Is it like a humming rotational sound?? Had my left front bearing replaced 3 weeks ago. Now my right side bearing is starting to go.
evoxmr is offline   Reply With Quote
