Old 05-26-2008, 02:26 PM   #1 (permalink)
on weekdays.
chrisincobb's Avatar
Drives: SHORT DISTANCES
chrisincobb Level 3chrisincobb Level 3chrisincobb Level 3chrisincobb Level 3
Question odd electrical probelm in drivers door.
ok i have no power going to the door locks, windows, or speakers in that door. but the red light lights up behind the reflector. what doesn't make sense to me is that the speaker stopped working at the same time as the windows and door locks. how are they related?? if anyone has an electrical diagram of the door, radio/ speaker wires or anything i would appreciate a PM or a post. i have checked the fuses and they are all good, at least under the dash anyways. not sure about the fuses/relays under the hood. just wierd. and the speker is brand new (installed today) thats how i came across this anomaly.
chrisincobb is online now   Reply With Quote
Old 05-26-2008, 02:40 PM   #2 (permalink)
daddy's Avatar
Drives: BPU 92TT
Trader Rating: (26)
daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7
Default Re: odd electrical probelm in drivers door.
Check the wiring and connector in door jam. You might need to replace whole thing.
daddy is offline   Reply With Quote
Old 05-26-2008, 02:59 PM   #3 (permalink)
one of the first
BlacktopTT is an unknown quantity at this point
Just like he said above check the connector in door jam...I had my window and door lock stop working on the drivers side and it ended up being 3 wires that go to that connector had broke.
White 94 R/T TT-mono flex coilovers,15g's,Greddy FMIC,complete IPS exhaust with apexi n1's ,99 nose with 99 lights , kaze lip,viper hood, orig 96 wing + many more goodies - weekend car
Green 94 R/T TT-Under Construction-
Yellow 95 3000gt, 92 black es, red 91 R/T TT & white 91 R/T TT-parting out
Drivers-91 sr20 240sx & 94 cobra vert(Both for sale)
SOLD-black 94 3k fwd TT ,blue 94 sl,silver 92 sl,blue 91 sl,red 92 vr4(kia by new owner),green 93 RT TT
BlacktopTT is online now   Reply With Quote
Old 05-26-2008, 04:02 PM   #4 (permalink)
on weekdays.
damn the japanese were really into those hards wires everywhere, weren't they? first the suspension, now this. owning one of these cars means never letting your skills get 'rusty'.
Old 05-27-2008, 07:28 AM   #5 (permalink)
Njohnny's Avatar
Drives: 3000gt
Njohnny is an unknown quantity at this point
I had a problem in my pax door like that before, found a couple of wires broken off near/under fuse box under the hood. I'm not sure which was which, but I just fixed all the broken wires I found and now the door locks/window all works. Hope it helps.
Njohnny is offline   Reply With Quote
Old 05-27-2008, 04:49 PM   #6 (permalink)
on weekdays.
ok it pushed on the connector in the door jam and i got my windows back, but still no speaker or locks. i have a feeling i might need to take the connector apart and clean it.
Old 05-27-2008, 04:51 PM   #7 (permalink)
doing the impossible
lDoomZdaYl's Avatar
Drives: Her Crazy
lDoomZdaYl level 6lDoomZdaYl level 6lDoomZdaYl level 6lDoomZdaYl level 6lDoomZdaYl level 6lDoomZdaYl level 6
haha agreed live and learn
lDoomZdaYl is offline   Reply With Quote
Old 05-27-2008, 11:11 PM   #8 (permalink)
needs boost
91Stealthrt2's Avatar
Trader Rating: (10)
91Stealthrt2 Level 191Stealthrt2 Level 1
I would check the plug into the door, I had mine come unclipped. Easy fix.
1 of 2 WA members at NG06!!!!!
2nd place stock AWD autox(not my car; first time driving a TT)
91 R/T
Mods: SCE 5mm spacers, intrax, rear sway bar, rear camber/toe arms, tp, intake, 18x9.5" fn01rc's in hyperblack with 265/35 Yokohama AVS sports, 2gTT brakes, SS lines, ek2 spacer and goodies, poly motor mouts, Seattle roller-bearing shifter!, Accel wires,'99 lifters, custom stereo, yellowtop, 192K+ miles, m505 w/MMCd, 3500lbs w/driver, and a badass daily driver!
Need to install: ss clutch line, 2g rear brakes, BT ground wires.
Need: CASH, windshield, carpet, antenna, 5 point strut bar
New DD-
91 base stealth- 90k miles, blue, vr4 wheels.
NEEDS LOWERED! Getting r/t body coversion and painted...
91Stealthrt2 is offline   Reply With Quote
