New invention, convert OBD1/MUT into Canbus OBD2 for Torque App, and read Flex Fuel - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
View Poll Results: Do you want one of these?
Yes I am interested, I have money. 22 81.48%
Yes I am interested, no money. 5 18.52%
No thanks. 0 0%
Voters: 27. You may not vote on this poll
Old 02-07-2017, 08:38 AM   #1 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
BlackStealth Level 1BlackStealth Level 1
Feedback Score: 252 reviews
Default New invention, convert OBD1/MUT into Canbus OBD2 for Torque App, and read Flex Fuel
There's a nice app called Torque for android devices, but it requires OBD2 compliant ECU, which most of our cars are not. I have made a converter box, that does the following:
- input Mitsubishi OBD1, Hybrid or MUT (94-95 USA ECU), MUT (94-99 Euro ECUs), MUT (98-99 USA ECU), LCDBC datalog port, or Scanmaster3 port.
- input Flex Fuel sensor
- input Boost Sensor, Fuel Sensor, Oil pressure Sensor, WBO2 Sensor
- outputs data via high speed Canbus OBD2
- output 0-5V flex fuel voltage, to display flex fuel % on LCDBC unit via Ext1, Ext2, Ext3 or Ext4.
The goal of the device is to display useful data on the Torque app, such as:
Knock, RPM, Boost, WBO2, Flex Fuel, etc.
The item will cost about $70. OBD1 or MUT cables are $20 extra. I am trying to figure out how many circuit boards I need to order, so I made a poll.
BlackStealth is offline   Reply With Quote Quick reply to this message
Old 02-07-2017, 09:07 AM   #2 (permalink)
under the knife again
Spankytaco's Avatar
Drives: 93w92engineFWDATX
Spankytaco is an unknown quantity at this point
Feedback Score: 4 reviews
Default Re: New invention, convert OBD1/MUT into Canbus OBD2 for Torque App, and read Flex Fu
To this will make torque work?
I use it on my jeep and Wife a acura...
So is this basically just and elm 237 for obd1?
I'm interested.
Spankytaco is offline   Reply With Quote Quick reply to this message
Old 02-07-2017, 09:15 AM   #3 (permalink)
Drives: 93 RT/TT
Sorry, at this time it is for Mitsubishi OBD1 cars only, such as 3000GT, GTO, Stealth, DSM, EVO, etc. Other OBD1 car manufactures implement OBD1 protocol differently, so they won't work unless I re-write the software to support them too.
So add in a $5 OBD2 Bluetooth ELM327 and you can transmit wireless to android device.
Old 02-07-2017, 09:20 AM   #4 (permalink)
Spankytaco's Avatar
Maybe I wasn't as clear as I should have been. I use a bluetooth elm for my other vehicles...
My 3k is obd1.
I used mmcd to log... Would much rather use torque.
Is your device going to be a basic obd1 to obd2 plug that then the elm will plug into or is it a complete replacement for an elm adaptor?
Old 02-07-2017, 09:24 AM   #5 (permalink)
Drives: 93 RT/TT
This device will have an OBD2 connector much like an OBD2-compliant car would have, so you just plug in your bluetooth elm327 wireless adapter into it.
Old 02-07-2017, 10:49 AM   #6 (permalink)
Drives: 1993 Stealth R/T TT
gawdzinner is an unknown quantity at this point
Feedback Score: 11 reviews
blackstealth, i really like your lcdbc that I have installed. Will the Torque app display more info than I can get on your lcdbc? I know the Torque app is probably prettier, but I like the form factor of the lcdbc.
Built 2nd week of August 1992, 1993 Dodge Stealth R/T twin turbo (6g72 engine with stock TD04-9b turbochargers), pearl white exterior (W29), red leather interior, W5MG1 transaxle.
Mods from stock:
VMS Racing 10.2mm spark plug wires, NGK BKR6EIX-11 spark plugs gapped down to 0.32", Touren TR9 3190 wheels, Maximal high flow main catalytic converter, gutted/deleted precatalytic converters, front & rear slotted & drilled brake rotors from eBay, T-bolt stainless clamps, Curt trailer hitch, 2nd gen rear bumper aluminum reinforcement, LED backup & license plate bulbs, Pioneer AVH-X2500BT with backup camera, DSM SMICs converted by oohnoo, 3S warehouse sidemount oil cooler, EVO 8/9 blow off valve, EGR blockoff plates, Vented hood blister mod, Rebuilt stock throttle body, Stainless bolt kit, LCDBC as an ECU monitor, 3SX Stainless-Steel Braided Brake Lines, 3SX Door Sills, Koyo radiator with brackets, High speed cooling fan mod, Retractable license plate holder, 3SX rear control arms, Snake eye mod, SCE brake caliper stiffening bolts, Pilot WI-HL6A 4656 Head Lamp Conversion Kit, K&N oil filter, Free boost mod, Stant XACTSTAT #48217 thermostat
gawdzinner is online now   Reply With Quote Quick reply to this message
Old 02-07-2017, 11:13 AM   #7 (permalink)
Drives: 93 RT/TT
LCDBC users: Pretty Torque app, new Flex Fuel monitoring, and alternative datalogging besides mmcd, pocketlogger, HHH, and Evoscan.
Non-LCDBC users: Same as above, but now they have a way of interfacing Boost Sensor, Fuel Sensor, Oil Sensor, WBO2 for datalogging / monitoring.
For those of us that have an Android based 7" GPS car radio, this will make your car look cooler. You can youtube Torque app on what it does. Here's one video:
Old 02-07-2017, 12:16 PM   #8 (permalink)
Talk about a shortshifter
Hard AttacK's Avatar
Drives: 91rttt, 95 miata
Hard AttacK Level 1Hard AttacK Level 1
Feedback Score: 22 reviews
Could you use it and lcdbc together?
Originally Posted by fastnelson View Post
went over 250 one time
Originally Posted by ADiggidoyoF View Post
I took her to carmax for an appraisal and after a half hour of compliments and friendly small talk they offered me a grand total of $300. I then asked to use the bathroom and proceeded to fill the back part of the their toilets with full rolls of tp.
Hard AttacK is offline   Reply With Quote Quick reply to this message
Old 02-07-2017, 12:17 PM   #9 (permalink)
Drives: 93 RT/TT
Yes.
Old 02-07-2017, 12:28 PM   #10 (permalink)
Drives: 1991 3000GT VR4
vulture is an unknown quantity at this point
Feedback Score: 0 reviews
I've seen posts where people are selling the old-style Palm data loggers with cables, etc, for OBD1. Am I right that your new invention plus Torque on an Android device is a newer equivalent to that?
vulture is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
« 6g74 oil pan? | - »
