Old 05-16-2008, 04:11 PM   #1 (permalink)
Tekime's Avatar
Drives: 1993 Dodge Stealth
Tekime is an unknown quantity at this point
Default New CV Halfshaft - replace motor mounts first?
I have a new driver's side CV axle I need to put it in. I read that the motor & tranny mounts + front end alignment should be in good shape first. I know my motor mounts are getting pretty bad and I plan on replacing them but I'd like to get this halfshaft in right away.
Should I try to replace the motor mounts first? What could happen?
Also a link for some good instructions/discussion on replacing the driver's side CV shaft in a SOHC stealth would be extremely helpful. No luck with search.
Thanks!
1993 Dodge Stealth SOHC
3sx front pipe, Random hi-flow cat, Maximal single shot, Riax 17x8s, Enduro 916s, CAI and slowly rebuilding
3SME // Mitsubishi 3000GT & Dodge Stealth Maine
Tekime is offline   Reply With Quote
Old 05-17-2008, 11:38 AM   #2 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (78)
Default Re: New CV Halfshaft - replace motor mounts first?
Alignment has nothing to do with motor mounts.
Also the CV joint replacement is going to mess with alignment anyway.
Old 05-21-2008, 07:23 PM   #3 (permalink)
Tekime's Avatar
Just reading off the specs sheet that came with the halfshaft - says check your motor mounts and alignment. So I guess it's just generic warning, which I'll proceed to ignore...
Old 05-21-2008, 07:40 PM   #4 (permalink)
Corey3000GT is an unknown quantity at this point
Replacing the axle shouldn't mess with alignment if you do it right. rather than unbolting the strut to knuckle, undo the balljoint and tie rod end if necessary. That should hopefully be enough room to get the axle out. Good luck
Corey3000GT is offline   Reply With Quote
Old 05-22-2008, 06:44 AM   #5 (permalink)
Tekime's Avatar
Thanks.. the service manual says ball joint and tie rod only so I think you're right. Was hoping I wouldn't have to unbolt that strut!
Unrelated but quick question for anyone. I removed the crank pulley with the breaker bar propped on the frame while I hit the ignition a few times... now how do I tighten the crank pulley nut again without a tool?!
Old 05-22-2008, 07:52 AM   #6 (permalink)
Tekime's Avatar
Ok I dropped the car with the wheels on and ebrake on in gear. Can't seem to get it any tighter, it's practically dragging the car.
Old 05-22-2008, 09:55 AM   #7 (permalink)
Damage Control
Stealthee's Avatar
Trader Rating: (78)
The SOHC has slots in the pulley. I usually take some kind of pry bar and slide it in the slot and let it jam against the control arm, sort of opposite how how break the bolt loose, except this time you are using arm power to tighten it.
Old 05-22-2008, 05:51 PM   #8 (permalink)
Tekime's Avatar
Thanks for the tip. The slot is tiny but I'll find something that fits better, the manual says 108-116 ft lbs. and it's nowhere near that yet!
Old 05-22-2008, 06:21 PM   #9 (permalink)
Damage Control
Stealthee's Avatar
Trader Rating: (78)
I have a little bar thats called a lady slipper. It worked perfectly for me.
