Old 05-14-2008, 08:46 AM   #1 (permalink)
j sin
gltasn's Avatar
Drives: 95 mitz 3kgt vr4
gltasn Level 4gltasn Level 4gltasn Level 4gltasn Level 4gltasn Level 4
Default new 6 speed or some grease?
goiing to be putting in new clutch and dont want to have the same little squeak. i have it when at a light or turbo timers cooling engine. i can hear a litlle squeak, squeak, squeak, squeak,ect... it will disapear as soon as clutch is depressed, just the slightest touch makes it gone. i do not want this with my new clutch and want to know if there is a place to put some grease so it wont squeak.
i didnt like 3sx's answer, they say i need new tranny. they said i was sold a bad transmission. it was bought new(not rebuilt) less than 10k miles ago. and installed by dealer(with new tc as well). both my new and old trannys made the sound. so did the new clutch put in at 8k miles ago. clutch or tranny????????
so did i get fucked by the dealer or is there a simple solution? i would grease it all up good but dont want my clutch failing. pulling out my hair! j sin
"If I was as slow as you, they'ed bury me!" terry canfield(dad)
gltasn is offline   Reply With Quote
Old 05-14-2008, 08:51 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Default Re: new 6 speed or some grease?
Did you ever put in a new throwout bearing?
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 05-14-2008, 08:51 AM   #3 (permalink)
Kessel run in 12 parsecs
Broch's Avatar
Drives: Viper...yikes!
Broch Level 7Broch Level 7Broch Level 7Broch Level 7Broch Level 7Broch Level 7Broch Level 7
Sounds like a bit of warping of the flywheel.. not a big deal.
Broch is offline   Reply With Quote
Old 05-14-2008, 10:15 AM   #4 (permalink)
j sin
gltasn's Avatar
new TOB each time. new flywheel and then new surface when rps put in. still squeaked. if its there and wont cause a problem other than annoyance, i can live with it. i dont want to get done and have someone say "oh yeah did you put a dob of grease on the ______? it would never squeak after that."
thanks for ideas, they are being addressed so, any other idea would be great. j sin
Old 05-14-2008, 10:17 AM   #5 (permalink)
Warning: I'm an asshole
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (10)
SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7
I'm just curious, but did they tear down your tranny and inspect it to come to that conclusion?
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit.
--Daily Driver: 98 Malibu, 4cyl, auto
SkortchGT is offline   Reply With Quote
Old 05-14-2008, 11:05 AM   #6 (permalink)
j sin
gltasn's Avatar
phone diagnostic. i just told the guy there that sells me all my parts what my car was doiing he got a sad tone in his voice and said tranny was bad. i was surprised to hear that as it was new from fact, dealer installed(with new tc,alum flywheel,tob) and never trashed on! and it squeaked before and after new tranny??? see why im confused!? j sin
Old 05-14-2008, 11:16 AM   #7 (permalink)
SkortchGT's Avatar
Trader Rating: (10)
Lol, typical 3SX.
I order stuff from them too when I have to, but a quick phone diagnostic cannot determine whether or not you need a new trans. What a bunch of shitheads.
Edit: My tranny did the same thing. You need to slather your TB with grease. Also get a new fulcrum ball and TB fork. Grease those up good too. You'll be set.
Old 05-14-2008, 11:32 AM   #8 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (55)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
I think you need to find a better shop. Where do you live? If you are a little bit further north, Autovelocity (Hagerstown, MD) might be a good option. Toddrs93 is the guy who runs it.
EDIT: After rereading the description, it does sound like the throwout bearing. I'm really surprised the dealership didn't replace this. You may want to check your invoice to see if they charged you for a new TOB.
Old 05-14-2008, 11:32 AM   #9 (permalink)
Spartan for Life!
aaronatstate's Avatar
Drives: A Dodge Import.
Trader Rating: (6)
aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7
Sounds like throw-out bearing chatter to me. My didn't do it till I replaced my clutch, and then it started doing it I assure you my transmission isn't bad.
I have an 18 spline VCU for sale. -375 shipped.
aaronatstate is offline   Reply With Quote
Old 05-14-2008, 06:26 PM   #10 (permalink)
j sin
gltasn's Avatar
thanks for the re-assurance guys! im pretty sure its not tranny but thought i would get input anyway. thx, j sin
