Need some help installing 2002 Montero Rear View Mirror - Page 2 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 12-13-2012, 12:26 PM   #11 (permalink)
www.cts-racing.com
niterydr's Avatar
Drives: 92 rt/tt-parting,RAM
niterydr is an unknown quantity at this point
Feedback Score: 53 reviews
Default Re: Need some help installing 2002 Montero Rear View Mirror
Looks nice. Am I safe to assume it just slides over the factory windshield mount?
-Josh
new project: white 92 rt/tt - project part out:
http://www.3si.org/forum/f4/1992-ste...9/#post7748297
Last project:
blue 93 rt/tt-SOLD
2005: 11.65@ 127.08mph 92 octane ~ 480awhp
2006: 11.45@ 136mph C-16 ~ 620awhp, traction-less wonder
best dyno: 720.2awhp/592tq (uncorrected).
Dyno numbers were on Dyno Dynamics brand dyno, track times weight: 3780lbs.
niterydr is offline   Reply With Quote Quick reply to this message
Old 12-13-2012, 12:42 PM   #12 (permalink)
General & A/V Moderator
ChargerX3's Avatar
Drives: Twinzies
ChargerX3 Level 2ChargerX3 Level 2ChargerX3 Level 2ChargerX3 Level 2ChargerX3 Level 2
Feedback Score: 16 reviews
Yes. This one has a Torx screw where my 94 had a Phillips. Just use your existing mount.
1967 Dodge Charger (440) 1969 Dodge Charger SE (383) 1972 Dodge Charger (400)
1992 Dodge Stealth R/T TT 1994 Dodge Stealth R/T TT 1996 Dodge Stealth R/T TT
ChargerX3 is offline   Reply With Quote Quick reply to this message
Old 12-26-2012, 02:03 AM   #13 (permalink)
Bob
'94 3000GT original owner
Bob's Avatar
Drives: 1994 3000GT
Bob Level 2Bob Level 2Bob Level 2Bob Level 2Bob Level 2Bob Level 2
Feedback Score: 10 reviews
Did you get everything working on this mirror yet? Just curious. I need a new mirror and after giving it some thought, I'm leaning toward getting a Gentex Self-Dimming.
Bob
Member #0362 (Original 3S Forum)
'94 3000GT
Bob is offline   Reply With Quote Quick reply to this message
Old 12-26-2012, 02:11 AM   #14 (permalink)
ChargerX3's Avatar
Drives: Twinzies
Sort of. Had to leave town for the holidays, so i didnt finish. Was rewiring an ignition power line to the top, so as to not kill the battery with the compass or temp always going. Still need to get the temp sensor off the montero though. Looks to be located in the front bumper. If it proves to be too difficult i may just skip that sensor.
Old 12-26-2012, 09:21 AM   #15 (permalink)
Creator of weird stuff...
drgonzo3000's Avatar
Drives: 93RT/TT & 1/2 92R/T
drgonzo3000 Level 1drgonzo3000 Level 1
Feedback Score: 58 reviews
Most likely it is a Gentex mirror. Pretty much every mirror I have pulled has been a Gentex. The wiring colors will be different for each model bu the wire position will be the same.
First thing I would need to know is how many Pins you have on your connector? Not Wires but pins.
Then what pins have wires on them? "With the connector facing you and the clip at the top"
They make a couple different connectors Most are 7 or 16 pin. & pin is your standard for Autodim w/compass and Temp. I have seen a couple 5 pins out there.
Here are the pin locations, ignore the wire color:
7-pin: (*required connection; **required if you have a temp display)
* PIN 1 = PINK = POWER = +12 volts*
* PIN 2 = BLACK = CHASSIS, GROUND*
* PIN 3 = LIGHT GREEN = BACKUP LIGHTS
* PIN 4 = GRAY = TO AUTO DIM OUTSIDE MIRROR
* PIN 5 = PINK = TO AUTO DIM OUTSIDE MIRROR
* PIN 6 = DARK GREEN/WHITE = TEMP SENSOR**
* PIN 7 = BLACK/WHITE = TEMP SENSOR**
16 pin: (*required; **required if you have a temp display)
* 1 = Grey = not used
* 2 = Bare = Microphone
o OnStar Mirrors
* 3 = = "Passenger Air Bag on" notification
o some GM trucks - ground pin to activate icon
* 4 = = "Passenger Air Bag off" notification
* 5 = = auto day/night signal from LH outside mirror
o If you have a dimmable mirror, the rearview mirror can dim it with this and pin 16
* 6 = Brown = Temp probe connection**
* 7 = Green/Black = Temp probe connection**
* 8 = Black = Ground*
o Common to Pin 9
* 9 = Light Green = Reverse Dim Inhibit
o Common to Pin 8, +12V from reverse lights to disable dimming
* 10 = Gray = Microphone
o OnStar
* 11 = Dark Green/White = keypad signal (out)
o OnStar - multiplexed signal
* 12 = Light Green = keypad +5v supply (in)
o OnStar
* 13 = Yellow = +12V switched (ignition)*
* 14 = Yellow/Black = Green LED signal
o OnStar - apply 12v to light LED.
* 15 = Brown/White = Red LED signal
* 16 = = day/night signal to LH outside mirror
o If you have a dimmable mirror, the rearview mirror can dim it with this and pin 5
Back up signal wire is used so that the mirror does not dim when you are backing up. Outside mirror signal wires are for those cars equipped with left/right side mirrors that auto dim also. Signal comes from the main center rear view mirror.
You can get a new temp sensor from ebay with the wiring very cheap:
Brand New Gentex Mirror Temp Sensor Fits Ford Chevy GMC | eBay
You can even get the complete wiring kit from ebay also if you need it:
gentex mirror wiring | eBay
I used to pull these from cars and sell them so I have seen plenty of these and can help you get it wired in. Best to test the wiring first before hard wiring it into the car just to be sure you have everything correct.
For the Temp sensor, you want to mount it someplace that does not get consistant airflow when moving and is not to close to the engine as you don't want it reading the engine heat. I mounted mine right above the ABS pump, back side of the headlight bucket. Thats far enough away from the engine and should be far enough up to not be getting air flow from the front bumper inserts.
Check it out on Youtube!!
93 Stealth TT - The Stealth Project
Renegade Tech Works ECS Controller on Intrax Springs
Chrome ECU
Hybrid 13g's
EVO 560cc Injectors
Spec Stage 3 clutch
Ninja Performance Output shaft & Input spool
Ninja Performance Solid Tensioner & Gates racing T-Belt
CX Racing Dual Core FMIC
Megan SS Exhaust
Fidanza Cam Gears and Clear Covers
3rd Gen Lifters
HKS BOV
K&N FIPK
Maximal High flow converter
Walbro FP & FuelLab FPR
Maximal and Seattle Solid Mounts
All -6an Lines
Custom -6AN coolant neck lines
AWS/ABS/Cruise Delete
MP Rear Control Arms
SS Brake Lines
99 Front Conversion
2nd gen Rear Bumper
99 Combat Wing
Complete interior LED Swap
Skillard Fuel channel
Oohnoo FPR Bracket
More to Come......
drgonzo3000 is online now   Reply With Quote Quick reply to this message
Old 12-26-2012, 10:49 AM   #16 (permalink)
ChargerX3's Avatar
Drives: Twinzies
Great info Gonzo! Ill probably try to get the whole harness and sensor on the cheap first. Mine would be a 7 pin model, but cannot recall all of what was populated. Was wondering where to tap into the 4 plug harness up in the top of the unit where it will be hidden away. Also, where did you decide to tap in for acc power?
Old 12-26-2012, 11:04 AM   #17 (permalink)
On mine I ran all new wires. I was hoping to tap into the power on the dom light but it is a constant power source. So I ran new power down to switched source on the fuse block.
So if your is a 7 pin it would be wired like so:
* PIN 1 = POWER = +12 volts*
* PIN 2 = CHASSIS, GROUND*
* PIN 3 = BACKUP LIGHTS
* PIN 4 = Empty
* PIN 5 = Empty
* PIN 6 = TEMP SENSOR**
* PIN 7 = TEMP SENSOR**
I never ran a wire to my backup lights. If I recall it is a ground signal so I either had to ground it or just not connect it. Simple test is to use electrical tape over the rear sensor on the mirror and shine a flash light onto the front photo sensor "Black Dot" With just the power/ground hooked up the mirror should din. If it doesn't then ground the back-up light wire and re-test.
Old 12-26-2012, 02:40 PM   #18 (permalink)
Needs moar boost!
Gray Haze's Avatar
Drives: 87SS 92vr4 94 R/T TT
Gray Haze Level 2Gray Haze Level 2Gray Haze Level 2Gray Haze Level 2Gray Haze Level 2
Feedback Score: 26 reviews
I just saved myself the head ache and bought a home link harness off ebay for like 30 shipped.
1987 Monte Carlo SS.
1992 3000GT VR-4 #15 of 24. The first 99 Sandstone Conversion.
1994 Dodge Stealth R/T TT. Grayish White Pearl.
www.3stech.org <= Where the meaningful results of your search went.
Gray Haze is offline   Reply With Quote Quick reply to this message
Old 01-25-2013, 11:49 PM   #19 (permalink)
ChargerX3's Avatar
Drives: Twinzies
Finally got around to plumbing a power. Works good now. Picked up the temp sensor as well. Will have to install that later.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
