#12 (permalink) | |
NG09: The Comeback Tour
From the top. I could not get it from the bottom.
NG07 T-Shirts For Sale * NG08 T-Shirts For Sale
NG08 Stuff from Cafepress Custom 12x18 poster/photo prints
#14 (permalink) |
Former DSMer - now VR-4er
I think I pried mine out from the bottom, but I tried going from above too. I had free run at it since so much stuff was removed at the time.
Oh yeah, make sure to inspect the seal on the trans while you have the axle out & replace if necessary... now is the best time to do it. The passenger side one was actually pretty easy, I had much more "fun" separating the driver side axle from the intermediate shaft. Stupid question, but the outer portion of the CV axle is loose (i.e. totally disconnected & removed from the hub), correct? Has to be totally out of the hub before you can think about getting the inner portion out of the trans.
#16 (permalink) |
Mod O' Day Pron
Yes, totally removed from the hub. I'm going to give it (here in a minute) another go from the bottom, doesn't work, I'll start ripping shit out of the top. What a pain in the rear.
Up-dates to come. Thnx again for the advice folks.
#18 (permalink) | |
never a dull moment
Coop
![]() To many mods to list. |
#19 (permalink) |
There is no keying of any kind on the axle splines (i.e. it does not have to be aligned at any particular position when installing). You just have to mate up the splines and stick it in there...
Give it a good shove into the trans to get the c-clip engaged (remember to be careful of the seal!), then get the outer splines into the hub and start putting stuff back together. |
| Thread Tools | |
