Old 10-05-2007, 02:06 PM   #1 (permalink)
Mod O' Day Pron
Sean Johnson's Avatar
Drives: 99 C5
Trader Rating: (13)
Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7
Default Need some CV Joint help
Passenger side. I replacing a bad CV joint, got the hub / brakes disconnected. Someone told me to use a crowbar, so I thought, I need some room, so I took the whole strut out.
Now what? There isn't any room, if so, where on the joint do I hook it to?
Thnx
SJ
Sean Johnson is offline   Reply With Quote
Old 10-05-2007, 02:09 PM   #2 (permalink)
Nireez's Avatar
Drives: 95 3000GT BaseTT
Trader Rating: (13)
Nireez is an unknown quantity at this point
Default Re: Need some CV Joint help
???? Where are you at on removing it? Do you got the axle nut off? If everything is disconnected just put the crowbar at the end of the axle by the transmission and give it a good pry, should come right out.
"The more original a discovery, the more obvious it seems afterwards."
Nireez is online now   Reply With Quote
Old 10-05-2007, 02:13 PM   #3 (permalink)
Mod O' Day Pron
Drives: 99 C5
Trader Rating: (13)
Yep, everything is disconnected. I'll look again. The whole joint is lose, it's looks like it's just sitting in the tranny ready to pull out. I keep hearing the seal sucking in air, then blowing some grease out.
brb
Old 10-05-2007, 02:14 PM   #4 (permalink)
Nireez's Avatar
Trader Rating: (13)
Thats it, just throw your pry bar between the tranny and axle and give it a nice pry and it should be right out.
Old 10-05-2007, 02:18 PM   #5 (permalink)
Former DSMer - now VR-4er
James92TSi's Avatar
Drives: #388 Red
Trader Rating: (11)
James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7
What he said.
Big fat prybar might not fit. I have an xlarge flathead screwdriver that I use for axle removal. Needs to fit between the tranny and the axle cup, then give a sharp pry away from the trans to pop the axle out. It is retained into the front diff by a c-clip, so that is what you are overcoming by prying it out.
You may find it necessary to pry a bit, then turn the axle so you can pry in a different location. Repeat until it pops out.
'91 3000GT VR-4 Down for now, but she will be back.
'03 G35 Sport Coupe Hates daily thunderstorms.
James92TSi is offline   Reply With Quote
Old 10-05-2007, 02:28 PM   #6 (permalink)
Mod O' Day Pron
Drives: 99 C5
Trader Rating: (13)
Oh hell, ok, from underneith the car. I see where there's room. Time to jack the car up higher.
Old 10-05-2007, 02:42 PM   #7 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7
haha I am helping brent with this sun. should of come down, we could of had a cv changing party.
Coop
To many mods to list.
DCIV is online now   Reply With Quote
Old 10-05-2007, 02:49 PM   #8 (permalink)
Mod O' Day Pron
Drives: 99 C5
Trader Rating: (13)
I'll have to get a differen't tool. The one I'm using is a little bulky and doesn't seem to have the right angle.
Old 10-05-2007, 02:50 PM   #9 (permalink)
Curmudgeon
Steve '93ES's Avatar
Drives: '93 ES, '92 TT
Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7
Just a quick reminder, when you get the old axle out MAKE SURE THAT THE "C" CLIP CAME WITH IT! They usually pop right out with the axle but occasionally they get stuck and pop off the back into the differential. If the clip goes missing you WILL have to fish it out or it will get into the gears and trash the diff. Look at the new one to see what we're talking about.
A little paranoid perhaps but all it takes is a glance to make sure..
Steve '93ES is offline   Reply With Quote
Old 10-05-2007, 02:52 PM   #10 (permalink)
soo....cold....
AK Twin Turbo's Avatar
Drives: 69th Stealth
AK Twin Turbo is an unknown quantity at this point
i did mine from the top, with all the hoses and battery and stuff disco'd. had a better angle than i did from the bottom, oddly enough...
Free Boost | Greddy Type-S | Cold Air Intake | MBC @ 12psi | MSD 8mm Heli-Core Wires
'99 Lifters | Autometer Gauges: Boost, Water Temp, Oil Press
AK Twin Turbo is offline   Reply With Quote
