Old 05-18-2008, 08:51 PM   #1 (permalink)
Lurch4's Avatar
Drives: 1991 3kGT SL
Lurch4 is an unknown quantity at this point
Default Need help with a weird noise!
I have a 91' 3GT SL with auto trans, and for the past couple weeks I have noticed somewhat of a grinding noise (Sounds like rubbing 2 metal discs together) .
The noise occurs very briefly just after I start the engine(spit second after). I only notice this on cold starts.
The noise ALSO occurs just after I start to take off from a stop(it occurs a little louder in this situation).. this seems to be worse when i'm turning at the same time and also it goes away after is been drove for a while (like 20 min. or so).
Now from what i know, the starter would explain when the engine starts, and the CV boots would explain the other noise situation when taking off.
Any ideas???
I'm just wanting to get to the bottom of this noise cuz it is driving me crazy. So any help you guys can give me would be greatly appreciated!
Lurch4 is offline   Reply With Quote
Old 05-18-2008, 10:24 PM   #2 (permalink)
Yank in Yorkshire
bjmsam's Avatar
Drives: 94 Stealth TwinTurbo
Trader Rating: (12)
bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7
Default Re: Need help with a weird noise!
If turning the A/C on eliminates the noise, then the A/C compressor clutch may need to be reshimed or replaced.
Jim's Stealth in the Bavarian Alps, 2001Jim Matthews - Yorkshire, England, UK
Team3S, 3SI #30, GTOUK #155
http://www.the-matthews.com/stealth.html
Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd
Active Suspension Damping, Active Exhaust Delete, 5300K HIDs
Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual
A'PEXi SAVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe
A'PEXi SAFC 5-knob, 450cc Black Tops, MirageCorp Logger, DSM SMICs
Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR
SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves
Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17
Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17
Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17
My reliable daily driver since Feb 1997!
bjmsam is online now   Reply With Quote
Old 05-18-2008, 10:38 PM   #3 (permalink)
Lurch4's Avatar
Ok, well i am at work all night but i will def. try that tomorrow morning when i get off..
Old 05-19-2008, 01:55 AM   #4 (permalink)
EVO Terminator
ramnakhle's Avatar
Drives: '97 3000GT VR-4
ramnakhle is an unknown quantity at this point
Can't help but suspect the accessory belts (AC/PS) check them for tension & wear... I don't know that's what i got from your description... If all else fails post a video with the sound...
best of luck
Where's the 3K ????
ramnakhle is offline   Reply With Quote
Old 05-19-2008, 02:40 AM   #5 (permalink)
Lurch4's Avatar
best of luck
Well i checked them for tension and wear yesterday and everything checked out ok that I could see. they're nice and snug with no noticable wear on them
and somewhat of an update.. the grinding noise is related to rpm. noise occurs when i am in gear and give it a just a little gas.
Could this possibly be a pulley vibration?
Old 05-19-2008, 05:29 AM   #6 (permalink)
Lurch4's Avatar
bump..
Old 05-19-2008, 05:57 AM   #7 (permalink)
2 + 2 is CHICKEN!
TwIzTeD_3kGt's Avatar
Drives: 1997 VR4 / 1994 SL
Trader Rating: (11)
TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7
If you could get a sound/video clip of it we would have a lot better chance of telling you what it is.
It does sound like a drive belt though.
TwIzTeD_3kGt is offline   Reply With Quote
Old 05-19-2008, 02:04 PM   #8 (permalink)
EVO Terminator
ramnakhle's Avatar
Here's a little trick i tried once and it worked:
It's gonna sound weird but it worked for me; It's up to you if you wanna try it.
Do a cold start, and while the noise is audible, poor some clean water onto your serpentine belts. If they're the culprits, the noise should stop completely, and immediately, but only for a short while as the wetting allows the belts to find some grip on the pulleys (like when you wet your finger tips to flip a slippery page in a book).
Make sure you don't go hosing down your engine bay when you do this, a few milliliters will do just fine, as long as it creates a thin film of water on the surface of the belts in contact with the pulleys.
From your description, i'm leaning towards the power steering belt.
Anyways, hope this helps, If the water does nothing, i don't know what else it may be... maybe a pulley like you said...
cheers
Old 05-19-2008, 09:39 PM   #9 (permalink)
Lurch4's Avatar
cheers
ok thanx for the interesting tip! The only problem with that is the noise only occurs for a split second after i start her.
and as for the video/audio, if i do that, it'll take be probably a day or so to get a hold of a camera to use (from a friend). So Wednesday night, ill maybe get a video posted for help.
Old 05-19-2008, 10:58 PM   #10 (permalink)
j sin
gltasn's Avatar
Drives: 95 mitz 3kgt vr4
gltasn Level 4gltasn Level 4gltasn Level 4gltasn Level 4gltasn Level 4
motor mounts comming apart? mine made a weird squeak when it was bad. j sin
"If I was as slow as you, they'ed bury me!" terry canfield(dad)
gltasn is offline   Reply With Quote
