Old 07-05-2008, 03:36 PM   #1 (permalink)
Drives: 94 Stealth RT
DaReaper7 is an unknown quantity at this point
Default Need help with this one guys...
Ok guys I know this isnt an honda thread but i dont know who else to ask then the poeple up in here this is whats up, This engine was completly build from the ground up and this is the owners description of it:
Up for sale is a professionaly built turbocharged H22 V-tec prelude motor. It has been built from the ground up. It has been hot tanked, honed, bored, and sleeved. It was also decked, ported and polished. It has brand new turbo AE Pistons, new rings, new rods. It has custom made turbo camshafts and all of the internals of the engine have been polydyne coated. Every thing you can think of has been done to this engine. It has red adujstable SKUNK2 cam gears and red AEM pulleys. It has a custom built T3/T4 turbo, DRAG turbo manifold, TIAL wastegate, BLITZ blowoff valve, GREDDY intercooler pipe kit, front mount intercooler, and it also comes with a HONDATA S200 engine management system. Comes with downpipe and wastegate dump tube. I have all receipts. The engine has been dyno tuned for break in, it has 1,000 miles on it from break in period. Needs to be final tuned and should have 350-400whp with 12 pounds of boost, maybe more if you up the boost.
I talked to owner and he said that when in the dyno it gave out a 250whp rating and a 300hp. He also said that he has never raced teh car in the 1/4 so he doesnt now the time that it does and he said that the shop said that the max the engine would produce is 500hp NOT whp I dunno what to do hes selling me this with his h22a manual tranny with a stage 3 clucth for $5900 shipped. what should i do guys?
DaReaper7 is offline   Reply With Quote
Old 07-05-2008, 04:53 PM   #2 (permalink)
oohnoo's Avatar
Trader Rating: (203)
oohnoo Level 1oohnoo Level 1oohnoo Level 1
Default Re: Need help with this one guys...
Never buy a car/motor if you gotta ask what to do. Otherwise go ask the Honda forum guys......
----------------[2007 Ride of the Year.................................. 3.5 Stroker I did. w/DBB DR1000's
oohnoo is offline   Reply With Quote
Old 07-05-2008, 05:32 PM   #3 (permalink)
Damaged Goods
HumanVr4's Avatar
Drives: 97 & 92 3000GT VR4
Trader Rating: (8)
HumanVr4 Level 2HumanVr4 Level 2HumanVr4 Level 2HumanVr4 Level 2
I have built 3 fully built H22A1, but I don't know what you are asking, Are you trying to find out if it can have 500WHP? or if that is a good price or what?
What are you trying to say with this? ''250whp rating and a 300hp.''
1992 Silver 3000GT VR4 BPU
1997 Black 3000GT VR4 630 AWHP with 571 foot pounds of torque
For sale http://www.3si.org/forum/f10/1997-vr...t-sale-464325/
Fast Stuff: IPS Stage 3 block with Pauter forged rods and CP pistons , DR Stage 3 heads with High Rev Valve Spring Kit and Titanium Retainers AND Rays head lift fix , IPS EVO 3 kit with turbo porting and Ceramic coating, IPS 272 Cams, IPS Fuel rails, fuel rail loop, IPS Setrab core oil cooler kit, Aeromotive A1000 FPR, PET 780CC Injectors, South Bend Stage 4 FE clutch, IPS NO-MAF intake pipes, 2 AEM Dry flow filters, AEM EMS, AEM map sensor, AEM IAT sensor, IPS intercooler kit w 750hp Spearco core, RPS flyweel, 2 HKS BOV, MSD 8.5MM wires, MSD Coils, Stillen downpipe, 3 inch custom exhaust W Apexi N1 tip, 3sx aluminum crank pulley, Twin Walbro fuel pump, hotwire fuel pump kit, solid motor mounts, EGR block off Kit, red top Optimia battery, Flexalite twin 12" fans, Koyo aluminum radiator, polished front/back valve covers, polished plenum, polished throttle body, IPS polished coolant pipes, manifold / downpipe turbo hot side polished ceramic coating, Turbo intake side polished.
Interior&Audio System: Corbeau CR1 Seats In Black, Corbeau Black 3Point Harnesses, Apexi AVC-R Boost Controller, Apexi Turbo Timer, Defi-Link Meter BF Gauges In White, Boost/Psi, Water Temperature, Oil Presure, AEM Wideband, SmokingVR4 Duel 10Inch Sub Box, 2 PPI 1000 Watts RMS Subs, Alpine IVA-D901 In Dash Flip Out Screen With Nav.
Suspension: KYB Struts, Tien S. Tech Springs, 19X9 SSR D5R in bronze with a polished lip, 245/35/19 Toyo Proxes T1R, Proracer Racing Lug Nuts in red, Rear Strut Bar.
Body: Viper alarm system, 8,000k HID.
www.ipsmotorsports.net
www.dynamicracing.com
www.kormextrans.com
HumanVr4 is offline   Reply With Quote
Old 07-05-2008, 05:41 PM   #4 (permalink)
What do you think overall? The owner said that he dynoed the engine and it gave him 250whp and 300hp without tune. Do you seriously think that he would get 250whp with all the mods that he listed? I'm trying to figure out if I should buy the engine or not thats all. whp = actual horsepower to the wheels and hp =is just the hp that it produces because driveterain loss.
Old 07-05-2008, 05:44 PM   #5 (permalink)
HVY HITR
Erick's Avatar
Drives: 94.99 STEALTH TT
Erick is an unknown quantity at this point
I had a Drag Kit on a H23a and at about 12psi it would make about that much power, so Im sure with the right tune it could. but man, you need to learn alot before owning a turbo car or else you'll always be on the wrong forums asking basic questions.
Owned: 91' & 94' Stealth TT
Erick is offline   Reply With Quote
Old 07-05-2008, 06:15 PM   #6 (permalink)
Damaged Goods
HumanVr4's Avatar
Trader Rating: (8)
Well most people don't say 250WHP AND 300HP, most say 250whp and say the wheel torque number, also unless he had the motor on a stand and tested the crank hp that number is off. And yes I know what whp & hp mean.
250WHP seems kinda low to me, but do you know the compression ratio of the pistons? Also do you know if it has forged rods? or new stock rods, if it just has stock rods that have been shot and pinged (Don't know if i spelled that right or not) you are going to be max out at 350WHP cause any more and the rods are going to give out.
Now if you have forged rods you can make 500-600WHP with the right mods as long as the motor is 10;1 or lower, but if it is 11;1 you wont make over 450WHP and that pushing your motor, even if you have rods. I had the best Hondadata tuner tune my car, Tony Palos on 11;1 compression ratio. He would not go over 400WHP cause he said the before the day was over my motor would be siting on his floor.
If it is 10;1 then the motor could make 500hp but if its 11;1 then your are going to be stuck at 400WHP for a safe WHP number.
Just to add the
USDA H22A1 makes 190HP 10;1
JDM H22A makes 200Hp 10;1
and the Red top JDM H22 type S make 220Hp 11;1
Old 07-05-2008, 08:02 PM   #7 (permalink)
AS_gto is an unknown quantity at this point
all stock b18a with t3/t4 turbo kit could make as much as that already with atleast less boost. i know cause my first car was a 92 teg b4 i swith to my supra mk3 and now a vr4, plus im getting another teg for gas saving and its pushing at least 200hp with ls turbo. hondas could make good amount of power but since theyre fwd....they suck in traction.. and as my opinions, you should just build your own!
AS_gto is offline   Reply With Quote
Old 07-05-2008, 09:07 PM   #8 (permalink)
Damaged Goods
HumanVr4's Avatar
Trader Rating: (8)
+1, If you build the motor your self, you will know 100% what it can do and what it will take.
