Old 06-05-2008, 09:13 PM   #11 (permalink)
Fhsballin21
Fhsballin21's Avatar
Drives: 3000GT SL, Talon
Fhsballin21 is an unknown quantity at this point
Default Re: Need Help Asap!!!
K It's just so dark out here???
Fhsballin21 is offline   Reply With Quote
Old 06-05-2008, 09:16 PM   #12 (permalink)
Ahhh. La Fee Verte.
Beau_Jester's Avatar
Drives: 94 3kGT base
Trader Rating: (9)
Beau_Jester Level 1Beau_Jester Level 1
Maybe you loosened a connection somewhere when you changed the battery. Check MAF, TPS, etc... Also check fuel pressure and flow. Try unplugging the battery for 15-20 minutes to reset ECU. Are the spark plugs sparking after the car dies and you try to turn over the engine? Air leak around MAF leaning engine?
Just brain storming quick engine checks
Red 94 Base 3000GT:
TK Eaton supercharger @ 8psi, 360cc injectors, SAFC II, 3SX downpipe, Magnaflow w/2.5" pipes, Dyno tuned @ 223 WHP, Quaife LSD, double synchro 3/4 gears, 10% over 5th gear.
93 Black RT/TT Stealth:
Newest project. Engine to be rebuilt, 15g turbos, RC 550cc, MAFT Gen-II, GM 3.5" MAF, Dejon blow-thru intake.
Beau_Jester is offline   Reply With Quote
Old 06-05-2008, 09:17 PM   #13 (permalink)
Fhsballin21
K gotcha
Old 06-05-2008, 09:25 PM   #14 (permalink)
Fhsballin21
K unplugged the battery I'm now waiting 20 minutes for the reset so we'll see
Old 06-05-2008, 09:27 PM   #15 (permalink)
My N/A is faster.
windsma's Avatar
Drives: Wrangler,missmy 3kgt
windsma Level 4windsma Level 4windsma Level 4windsma Level 4windsma Level 4
are the terms clean, use some sandpaper to expose clean metal. Mine were so bad i had to replace them, the stockers are crappy thin copper.
there is a process to reset w/ the com. port the ECU, ill try to find it. Or it maybe a Fuse that you have to pull.
Q: How do I reset the ECU?
a: Generally, there is no need to rest the ECU. Installation of a hi-flow air filter should not require you to reset the ECU. The ECU will "re-learn" and automatically adjust for any change in airflow. The only time you may want to reset the ECU is if an engine code appears. You can then reset the ECU by unplugging the negative battery cable for approx. 10 seconds.
Originally Posted by GenericVR4owner View Post
Just get a vr4 and be done with it.
windsma is offline   Reply With Quote
Old 06-05-2008, 09:29 PM   #16 (permalink)
Fhsballin21
K sandpapering
Old 06-05-2008, 09:42 PM   #17 (permalink)
Damage Control
Dark-Hawk's Avatar
Drives: `92 240SX
Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7
My first thought was a MAF issue, or possibly a vacuum leak.
SOLD
Walbro 255, 450CC injectors, S-AFC, 300M output shaft, SPEC II clutch, RPS flywheel, ATR single shot exhaust, ATR downpipe, saner sway bars, PRM 3 pt strut bar, Greddy Type-S BOV, stillen cross drilled rotors, stillen brake pads, koyo rad
Dark-Hawk is online now   Reply With Quote
Old 06-05-2008, 09:48 PM   #18 (permalink)
Fhsballin21
Vacuum leak eh?
Old 06-05-2008, 09:49 PM   #19 (permalink)
My N/A is faster.
windsma's Avatar
Have you washed your engine compartment recently?
I was so anal about keeping my car clean. I had a crack in the plastic lid on the MAF and about 1/4in of water had gotten in and ZAP!
I know and remember well the "O $hit" look you had but, thats the fun of a 3000GT
Old 06-05-2008, 09:54 PM   #20 (permalink)
Fhsballin21
No haven't power-washed the compartment lately the MAF is disconnected right now and I will continue workin on it tomarrow before work
