Old 06-05-2008, 08:26 PM   #1 (permalink)
Fhsballin21
Fhsballin21's Avatar
Drives: 3000GT SL, Talon
Fhsballin21 is an unknown quantity at this point
Default Need Help Asap!!!
Hey guys I'm a lil freaked out because I needed to be somewhere now and my 3S won't run at all (it's been running very perfect and strong for the past 13 months) I just put a new battery in two weeks ago, when I go to start it 15 minutes ago it starts revs the idle up to about 1500 and then goes right down to zero, now I had it going for a few minutes so I decided to take it around the block and I shift into 2nd and it drops back to zero, tried this 2 more times and just got it going enough to get me back home thank god, can anyone help me please?
-Matt
Fhsballin21 is offline   Reply With Quote
Old 06-05-2008, 08:38 PM   #2 (permalink)
Stealth DD
Carlosrnd's Avatar
Drives: MidKnight Stealth
Carlosrnd is an unknown quantity at this point
Lightbulb Re: Need Help Asap!!!
my old stealth would turn off if i didnt have some gas goin when i found out i had a spun bearing.
It would go down and turn off unless i had the foot on the gas pedal to keep it rev high.
might be you join the spun bearing club!
Photobucket
Currently modding my RT (REP Would Be Appreciated)
Carlosrnd is offline   Reply With Quote
Old 06-05-2008, 08:38 PM   #3 (permalink)
VA 3S
Tool Man's Avatar
Drives: 94 3000GT NA
Trader Rating: (27)
Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7
Default Re: Need Help Asap!!!
Will it run if you keep your foot on the gas?
Pics of my car, click me!_______ August 2006 ROTM
DSM 13Gs, gutted pre-cats, 3" after market downpipe with 3" high flow Cat,Custom 3" stainless steel catback dual exhaust,Modified oil pan & Stainless steel oil return lines,APEXI S-AFC2, Manual Boost Controller, Front and rear Polly mounts. Running waste gate for now ( 7 PSI ) until I get to a Dyno.
Tool Man is offline   Reply With Quote
Old 06-05-2008, 08:56 PM   #4 (permalink)
Fhsballin21
No when I clutch in it stalls out I just took it around the block again and it went until I pulled into my driveway with the clutch in and stalled out...
Old 06-05-2008, 09:00 PM   #5 (permalink)
Fhsballin21
bump...
Old 06-05-2008, 09:01 PM   #6 (permalink)
My N/A is faster.
windsma's Avatar
Drives: Wrangler,missmy 3kgt
windsma Level 4windsma Level 4windsma Level 4windsma Level 4windsma Level 4
First check your batt. terms. Make sure they are tight and clean inside.
i had a similar prob., my MAF was fried.
Unplug it and see if you can go down the road.
If thats the case i would find a new ride for the night.
the MAF cost me $40 at a local JY.
Originally Posted by GenericVR4owner View Post
Just get a vr4 and be done with it.
windsma is offline   Reply With Quote
Old 06-05-2008, 09:02 PM   #7 (permalink)
Who Knows
4N GTO's Avatar
Drives: People to Drinking
Trader Rating: (10)
4N GTO is an unknown quantity at this point
Tps????
92 VR-4
Mod List: Not worth listing.
Wanted Mods: To long to list.
4N GTO is offline   Reply With Quote
Old 06-05-2008, 09:07 PM   #8 (permalink)
Fhsballin21
How do I de-attach, the MAF???
Old 06-05-2008, 09:10 PM   #9 (permalink)
Fhsballin21
bump...
Old 06-05-2008, 09:11 PM   #10 (permalink)
My N/A is faster.
windsma's Avatar
unplug the plug???
post no.3^ in his sig is the engine, you can see the plug.
