hey guys. while of course finishing up working on my stealth today i noticed a connector not plugged in anywhere and another spot where nothing was connected to it. i gave a look in the area and couldnt find any other plugs that matched them.
i attached pictures. thanks guys.
1st pic - notice top center above ECS cap that there is a an empty connector nothing plugged into it
2nd pic - close up of said connector
3rd pic - connector hanging down that i found tucked under battery tray. and no it doesnt go into the other, l tried
lol pardon my lack of knowledge but im in the usa . im assuming RHS means right hand steering??? if not i apologize im still kinda learning acronyms.
only a couple times i have had my ABS light come on while driving but it hasnt done it in a looooong time....id say at least since the beginning of the year.
dont really care if the reservoir tank sensor isnt working honestly. just trying to figure if this is a big deal or not. never had any problems with the car since ive had it
You didn't show the bottle in the pics, but now that I look at it, I can see the mounting studs in the battery tray...
The connector you found under the battery tray goes to the washer pump. There is a harness coming off the fluid level sensor on the bottom of the bottle that snakes over to the fenderwell and plugs into the other connector.
You'll need to pull the battery tray and bottle to get to either one...
Pssst.... Right Hand SIDE means the same in any hemisphere.....
(and is always from the driver's seat, over here it's the passenger side over there it's the driver's.)
come to think of it i dont think i cant remember if i have ever actually used my washer fluid jets to clean my windshield since i clean it so often by hand. ill try it tomorrow when its daytime and also check those connectors again.
ill also do what you recommended aus3gt and check it its the ABS connector.
Related Threads
6.6M posts
62K members
Since 1999
