Old 09-23-2008, 09:52 PM   #1 (permalink)
Drives: 3000GT Base
-ImagiNe is an unknown quantity at this point
Default My transmission.
Ok I have a question for you guys. I found out what was wrong with my transmission today. The differential did break on it but it also has a huge hole going from where the differential is to the area where the clutch is. So basically I have a hole in the case now also and that would explain why my clutch had dings all over the outside and metal pieces everywhere when I drained the transmission out. I got a guy looking at it to let me know if he can repair the case if he can't I'll have to buy a new transmission. My question is though how well will the transmission hold if they do repair that hole or would I be better off with just buying a new one?
-ImagiNe is offline   Reply With Quote
Old 09-23-2008, 09:56 PM   #2 (permalink)
Back on the Road
jstarr427's Avatar
Drives: 98 SOHC Red 5MT
jstarr427 Level 2jstarr427 Level 2jstarr427 Level 2
Default Re: My transmission.
If you're at stock ish power levels I dont think it will be an issue, it really all depends on how well he repairs the hole. assuming he does a good job and obviously cleans/rebuilds the rest, then you should be ok. I'd do either an LSD or an insert.. that may just prevent the same thing from happening in the future.
BUYME!
1998 SOHC "Arrest Me Red" Gutted Pre-cats, 3sx DP, RT High Flow Cat, Borla Catback w/o mufflers, Eibach Springs, K&N Filter, MSD 8.5mm wires, Bosch IR Fusion, Topline Ground Wires, 3sx 02 sims
Exactly Identical 6
Mechanically Identical 43
Same Model+Option Package 379
Same Model+Build Date 201
jstarr427 is offline   Reply With Quote
