My full-car build. - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 09-14-2012, 10:57 PM   #1 (permalink)
1PNCHMN
Blue3kGTSL's Avatar
Drives: 1994 VR-4
Blue3kGTSL is an unknown quantity at this point
Feedback Score: 18 reviews
Default My full-car build.
Some of you guys may have read my thread when i first purchased this car, but if not and you feel like reading some (even though i said some dumb stuff in there as i look back on it.. way more knowledgeable now lol) here is the story of how i brought my VR4 back to life.
Blue3kGTSL's Revival Thread
Im going to make a thread for some parts i have for sale to fund this project and post it here
Now to this.. First i will post a current full mod list of everything i purchased/everything on the car right now..
Rebuilt engine with rebuilt heads
Solid engine mounts
3SX Single Pass Radiator with Slim passenger fan
GReddy High Pressure Radiator cap
Mugen S2000/NSX thermostat
Polished spark plug cover
Polished 3SX Plenum harness cover
3SX fuel rails
PTE 680cc fuel injectors
Aeromotive FPR
-6 an fuel line from the tank to an aeromotive filter to the rails
New Cam angle sensor
New Crank angle sensor
New Knock sensor
New Coolant Temp sensor
New Rear o2 sensor
1 Large Krank Vent (I lost the small one )
Special MTC 19T's with larger compressor housings
Homemade Preturbo hardpiping
Braided SS oil feed lines
FMIC
Tial BOV
Surwin products front o2 housing
3SX rear o2 housing
ATR downpipe
Surwin products catback
HKS EVC 5
HKS Type 0 Turbo Timer
Innovate Oil pressure, Water temp, Boost, and wideband gauges
GReddy Emanage Ultimate piggybacked on factory ECU
Rebuilt transmission
Ohiospyderman's short throw shifter
Clutch Masters stage 3 full face clutch
Unorthodox racing lightweight flywheel
Braided SS clutch line
Reman slave cylinder
Braided SS Brake lines
Hawk HPS brake pads
Carbotech slotted rotors
KSport coilovers
3SX rear adjustable upper control arms
Rota P45R's in Time Attack flavor
BFGoodrich GForce KDW T/A tires
99 Front bumper
99 Turn signals
Battery relocate to rear
Trunk plastics/carpet/woodthing removed
Active Aero delete
Cruise control delete
Rear wiper delete
Clutch booster delete
Power antenna swapped for flexible shorter rubber one
Vacuum reduction
Master Elite KIA Technician
Past> Level 3 Chrysler & Bronze level Hyundai
1994 3000GT VR4 - 2012 Lexus IS250 F Sport - 08 BMW 335I
1988 Toyota Supra Turbo - Hers
Full-Car build Part 2!!!! Single Turbo Billet 3.7L stroker!!! CLICK HERE
Blue3kGTSL is offline   Reply With Quote Quick reply to this message
Old 09-14-2012, 11:06 PM   #2 (permalink)
1PNCHMN
Blue3kGTSL's Avatar
Drives: 1994 VR-4
Default Re: My full-car build.
On to the build part of the thread.. Im building it not so much with a power goal in mind, but i guess you can say my dream car? Basically an all around performer good at pretty much everything and can still have the remaining interior, power steering, and A/C, and still be able to function as a "daily driven" car. I say that lightly because i also have a beater/good MPG car so its whatever i feel like driving kind of thing..
The reason why I'm starting this now is because I believe my VCU is shot. It has 140,000 miles on it, seen (what im guessing) multiple launches from DR750 status from the previous owner as well as the launches i have done in it, and is about 20 years old. I was able to turn one of my front tires pretty easily by hand as well.. havent checked with the rest yet though. Also, im not sure if im going to break into the motor or not (yet) but im pulling the engine/tranny combo this weekend and at least addressing some of the oil leaks coming from the engine as well as cleaning up the engine bay. (Possibly painting it a glossy black but unsure of that at this point as well.)
Old 09-14-2012, 11:29 PM   #3 (permalink)
1PNCHMN
Blue3kGTSL's Avatar
Drives: 1994 VR-4
SO. Parts list.. Since my VCU is shot, I'm going to start with the transaxle and build it with these parts all at once so I don't have to break into it again.
-Transmission-
Supercar Engineering Torsen Center Differential with 300M output shaft (on group buy list)
Front LSD (Still deciding between the SCE, OBX/SCE one, or the OBX one)
Broomfield Racing Billet endcase (Not purchased)
That should be it for the internal tranny parts since it was rebuilt once before but if i crack it open and I see something that should be replaced I'll add it to this list.
Here's the things that are not high priority.
-External Driveline/Rear Differential-
2 piece Aluminum/Steel 6 Speed Driveshaft (Not purchased)
KAAZ Rear LSD ( not purchased)
This bottom section is thrown together for now because i need to get some sleep lol..
-Engine- (Need to research most of this stuff)
ARP Headstuds
ARP Main bolts?
Ray Pampena Head Lift Fix (Not sent off)
Cams
99 or Solid lifters
Valves
Springs
Solid lifters
OEM Oil Pump
OEM Water Pump
OEM Hydrolic Tensioner
OEM Tensioner
OEM Idler pulley
New High Quality Timing belt
Bigger Oil cooler
Rods
Pistons
Wrist Pins
Rings
Bearings
Balance engine
New Freeze plugs
Research coolant/oil passages
Gaskets
New IACV
New TPS
Radiator hoses
Coolant Reservoir
Krank Vents
Better radiator fans, a fan shroud, and some ducting to get around the fmic
-Interior/Electronics-
Fix A/C display
New Carpet
New Floor Mats
Bride front seats
5 Point harnesses
Roll cage
More gauges monitoring more things because Im paranoid
Some type of fan controller
-Exterior-
99 Headlights
99 Sail Panels
99 Combat wing
99 Rear garnish
Passenger Side Door Mirror
Probably Pitroad M hood or something similar
Repaint a nice "Supercar" white
Tie rod ends
Replace any bad bushings
Old 09-15-2012, 01:21 AM   #4 (permalink)
Drives: 93 Stealth Stock DD
rymer21280 is an unknown quantity at this point
Feedback Score: 42 reviews
I can repair your A\C display, and make it never blow out again :-)
Nice list!
rymer21280 is offline   Reply With Quote Quick reply to this message
Old 09-15-2012, 02:07 AM   #5 (permalink)
Panther Vr4
Bighoppins's Avatar
Drives: 94 Stealth/black vr4
Bighoppins is an unknown quantity at this point
Feedback Score: 4 reviews
looks like fun. Looks like my rebuild if I had money lol. Previous guy sold me one with fried rings told me it was the turbo. I love the pearl color one of my favorites besides black.
Bighoppins is offline   Reply With Quote Quick reply to this message
Old 09-15-2012, 03:22 AM   #6 (permalink)
Ausgt3's Avatar
Drives: Aug 92' Aust. 3000gt
Ausgt3 is an unknown quantity at this point
Feedback Score: 5 reviews
Good luck with your rebuild!
Slowest car progression in history: (GTOAssassin) - Scotty's 93 GTO - it's time !
Favourite quote: (GTOX) - Apart from the knocking noise it was running 110% and pulling like a champ.
Favourite how to: (RuralGTO) - The shoelace is not in the door. It is a Mitsubishi SST. (Special Service Tool)
Follow this link and subscribe to a once in a lifetime restoration at Complete Restoration
Ausgt3 is offline   Reply With Quote Quick reply to this message
Old 09-15-2012, 07:23 AM   #7 (permalink)
1PNCHMN
Blue3kGTSL's Avatar
Drives: 1994 VR-4
Rymer: I have my display apart right now and it looks pretty bad haha. I can fix it myself but I rather not. Shoot me a PM discussing price and if its good I'll get with you on that.
Old 01-02-2013, 12:05 PM   #8 (permalink)
1PNCHMN
Blue3kGTSL's Avatar
Drives: 1994 VR-4
Ok update time! Motor and tranny are out of the car. I need to pull the trans apart to get to the center diff so that I can have my SCE one sent to me. I'm also going to order a bell housing brace and install it at the same time. I'm going to buy a billet end case later.
The reason I pulled the motor out at the same time was to clean up the engine bay because the engine has been leaking oil for quite some time.. So I'm going to seal up the engine and get the valve cover done.. I noticed some oil coming out the rear main seal area.. But I'm not sure if I want to put all kinds of money into this block if this will be the last season that it will be a 3.0L. Any suggestions?
I'm also going to post some pics up in a little while..
Old 01-02-2013, 01:17 PM   #9 (permalink)
LS3S
MDoe8's Avatar
Drives: LS3S-Stealth LS1 TT
MDoe8 Level 1MDoe8 Level 1
Feedback Score: 9 reviews
Looks like a good build. However, you're missing one vital part....PICTURES!
Project LS3S - '94 Stealth LS1 Twin Turbo
Build Thread
MDoe8 is offline   Reply With Quote Quick reply to this message
Old 01-02-2013, 08:15 PM   #10 (permalink)
1PNCHMN
Blue3kGTSL's Avatar
Drives: 1994 VR-4
As you wish...
Out she comes..
On the stand.
Front before.
Rear before.
Looks like someone had their period. Yuck. Gotta clean this mess up.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
