#1 (permalink) |
What do you guys think? The extra weight adds traction that the base is just thirsting for.
![]() In addition, I increased airflow to my driveshaft by over 300%. By removing all grease we ensure maximum friction and minimum safety. Driving a safe car is like driving with a skirt on. You might as well get a minivan and just cut your nuts off, you won't be needing them anymore. ![]() On a more serious note - never let an oil leak go for two years. ![]()
1993 Dodge Stealth SOHC
3sx front pipe, Random hi-flow cat, Maximal single shot, Riax 17x8s, Enduro 916s, CAI and slowly rebuilding 3SME // Mitsubishi 3000GT & Dodge Stealth Maine |
#6 (permalink) |
Here for the tuna.
Mine looks like that too underneath. Same exploded CV boot, and a slow oil leak from somewhere (I think the oil cooler fittings on the oil filter housing) makes for TONS of gooooooo!
Edit: How about a Mobil 1 filter in place of that Fram!? ![]()
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts ![]() |
#7 (permalink) |
RTBOOST
And I thought my lower engine looked dirty...That's a mess man! As for cleaning it, I brought out some Castrol Super Clean degreaser and plenty of cloth rags to clean mine. Then I used some Meguiar's Quik Detailer to replenish the luster. Granted, I had about half as much road grime (if not less) as yours. Good luck.
'73 Dodge Challenger 340.............................(X)
'91 Firestorm Red Stealth R/T TT...................(X) ![]() |
#8 (permalink) | |
Dutch by nature!
I use white gas to clean most things, but need to probably switch to something less cancer causing too. BTW: I would replace that Fram filter with a brand that doesn't fall apart as easily.
Life's too short to go slow.
#9 (permalink) |
Norcal3S.com
Lol looks a lot like the underside of my car.
![]() Get rid of that fram filter, they are junk!
![]() 13T's + Supporting Mods|DSM SMIC's|K-Sport Coilovers|Battery in Trunk Alchy Injection|Saner Sway Bars|Bronze 17x9 FN01R-C's|3" Straight Pipe 1996 Grand Cherokee: My DD, 4" Lift and 31" Tires ![]() 1992 VR-4: My Weekend Warrior ![]() |
