My car squeaks when it bounces, why? - 3000GT/Stealth International Message Center
Old 09-14-2009, 07:53 PM   #1 (permalink)
I'm a fn glock fanboy.
RebelExtrm02's Avatar
RebelExtrm02 is an unknown quantity at this point
Feedback Score: 9 reviews
Default My car squeaks when it bounces, why?
I cannot for the life of me figure this out. I thought at first it was struts, but it's making the sound on both sides of the front end now and the ECS strut on the drivers side is new, so that's out.
Basically, when the car experiences any bouncing movement, whether going over a bump or accelerating/decelerating, it makes a squeak like an old farm truck. It only emits from the front end, equally from each side.
Does anyone have a checklist of places to look? I've tried myself but it's hard to get under the car enough to tell since it has to be on the ground to make it squeak obviously.
RebelExtrm02 is offline   Reply With Quote Quick reply to this message
Old 09-14-2009, 08:26 PM   #2 (permalink)
Too stubborn to quit
boostedgt's Avatar
Drives: 93 VR-4
boostedgt is an unknown quantity at this point
Feedback Score: 25 reviews
Default Re: My car squeaks when it bounces, why?
bushings
Shortblock: 4-bolt 0.040" over (92mm) with nitrided forged crank, wiesco forged pistons, trend tool steel wrist pins, crower rods, clevite bearings, arp main studs, IJ windage tray, billet oil pump gears, fully balanced, deck micro polished.
Heads: Professionally ported and built heads w/ new oem valves, early 1g cams, Fidanza cam gears (degreed +1,-3), new guides, mitsu seals, Kiggly racing beehive springs, titanium retainers, and new keepers w/ Ray P's headlift fix, L19 headstuds, OEM headhaskets, DR ported lower intake manifold.
Drivetrain: Pampena built 5spd, Bellhousing brace, 300M 25 Spline OP shaft, Maximal T-case brace, Tilton OT2 7.25" twin disc clutch with hydraulic throw out bearing and Erron’s custom chromoly flywheel.
Cooling: FFdynamics rad and fans, IPS Setrab Oil cooler.
Fuel: Hotwired Walbro 400lph fuel pump, -6AN feed/OEM feed as return line, 3SX Fuel Rail Loop, PTE 680's, Aeromotive AFPR.
Ignition: New OEM coils with HKS DLI, MSD wires and NGK coppers.
Goodies: 3SX TD05 16G kit, AEM EMS V1, Modified CX Racing FMIC, Innovate Wideband/boost controller, ATR Exhaust with 3" electronic cutout.
Suspension/Brakes: Megan Coilovers, Addco rear swaybar, AWS delete, ajustable control arms, extended balljoints front and rear, upgraded swaybar endlinks, SS brake lines, IPS slotted rotors, Hawk Pads.
Misc: Maximal Solid Motor Mounts, EGR Blockoffs, Carputer Running AEM Pro, full sound system with 2 Alpine Type R's and lots more...
boostedgt is offline   Reply With Quote Quick reply to this message
Old 09-14-2009, 08:43 PM   #3 (permalink)
Quit while you're ahea
green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2
Feedback Score: 45 reviews
Megans?
"Ask not what you can do for your country - ask what your country can do for you." - The gimme generation
green-lantern is offline   Reply With Quote Quick reply to this message
Old 09-14-2009, 09:25 PM   #4 (permalink)
Flasher
TwIzTeD_3kGt's Avatar
Drives: VR4 | VR4 | R/T
TwIzTeD_3kGt Level 2TwIzTeD_3kGt Level 2TwIzTeD_3kGt Level 2TwIzTeD_3kGt Level 2TwIzTeD_3kGt Level 2
Feedback Score: 24 reviews
Originally Posted by boostedgt View Post
bushings
Pretty much.
Sway bar link bushings, sway bar bushings, control arm bushings, sub-frame bushings, rack and pinion bushings...take your pick.
And if it doesn't seem to be any of those, it could be a rusty, ungreased lower ball joint.
'97 VR4 - 19t, Chrome, E85, DD, Since '06
'06 Envoy SLT - Black, clean, DD
'98 Expedition EB- Work/Winter horse
'93 VR4 & '94 R/T - Projects
TwIzTeD_3kGt is offline   Reply With Quote Quick reply to this message
Old 09-14-2009, 10:35 PM   #5 (permalink)
Paid Member
GTwizard's Avatar
Drives: Mitsubishi
GTwizard Level 1GTwizard Level 1
Feedback Score: 5 reviews
You need to torque the foreward bolts of your A arms. Those bolts are about 6" long and the nut faces foreward. You are hearing metal to metal squeek from the steel insert (cruch bushing) to frame. 65 lb.s if I remember correctly. Ten bucks says I'm right. LOL.
GTwizard is offline   Reply With Quote Quick reply to this message
Old 09-14-2009, 10:49 PM   #6 (permalink)
Forum user
grouchycactus's Avatar
Drives: 97 SL
grouchycactus is an unknown quantity at this point
Feedback Score: 1 reviews
haha mine does the exact same thing, squeaks like crazy over road with segments in them
Originally Posted by jeettao
"Gentlemen. I've got it! A grand touring luxury sports car.... that will double as an offroad vehicle!"
"But sir, the wheel gap will have to be horrendou--"
"Takanagi. MAKE IT BE SO."
grouchycactus is offline   Reply With Quote Quick reply to this message
Old 09-14-2009, 10:56 PM   #7 (permalink)
If that is it, I will paypal you 10 duckies. It's driving me crazy that bad lol.
Old 09-14-2009, 11:16 PM   #8 (permalink)
<3's lapping days
R/T93's Avatar
Drives: 93 R/T, 98 VR-4
R/T93 Level 1R/T93 Level 1
Feedback Score: 17 reviews
make sure your sway bar isnt rubbing on the frame (where it goes along horizontally along your steering components), check the clearance
93 R/T - Modded, Full Suspension, Full Exhaust, Quaife Diff., Turbo brakes, Alpine/Boston Sound. One of 25
98 VR-4 - Billet 13t's, Downpipe, EBC, Ohlins, SCE Center Diff, SCE oil pan, Maximal Performance oil cooler, 2" Koyo Rad, SAFC2, Defi Gauges, RC 550's, Supra Pump, Skillard Splitter, Hardpipes, XYZ 355mm 6 piston brakes (Black), Z2 Direzzas, Alpine/Infinity/JL Sound. One of 13
My Garage http://www.3si.org/forum/garage/1057
R/T93 is offline   Reply With Quote Quick reply to this message
Old 09-15-2009, 02:10 AM   #9 (permalink)
Paid Member
GTwizard's Avatar
Drives: Mitsubishi
Some of you may even get thatnoise just by turning the steering wheel a little. And those that go bump when you touch the brakes to slow down, it's really loose.
Old 09-15-2009, 02:33 AM   #10 (permalink)
Talk about a shortshifter
Hard AttacK's Avatar
Drives: 91rttt, 92base3000gt
Hard AttacK Level 1Hard AttacK Level 1
Feedback Score: 22 reviews
GTwizard is a beast.
Originally Posted by fastnelson View Post
went over 250 one time
Originally Posted by ADiggidoyoF View Post
I took her to carmax for an appraisal and after a half hour of compliments and friendly small talk they offered me a grand total of $300. I then asked to use the bathroom and proceeded to fill the back part of the their toilets with full rolls of tp.
Hard AttacK is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
