My 1992 3000GT VR-4 Rebuild. - Page 24 - 3000GT/Stealth International Message Center
Old 01-24-2013, 09:40 PM   #231 (permalink)
Djmba's Avatar
Drives: 1992 3000GT VR-4
Djmba is an unknown quantity at this point
Feedback Score: 15 reviews
Default Re: Re: My 1992 3000GT VR-4 Rebuild.
Originally Posted by Lunchbox View Post
Yeah, I have a few other projects to finish before I can go any further on this one money-wise. If I get to it before you I will report back
I'm starting to think more and more that it is the FPR. I used to have slow starts (crank for about 5 seconds and then it lazily starts) probably once or twice a week. For about the past 2 weeks it has done it damn near every time. I think this makes sense when you take into account the leaking sound I was hearing coming from the plenum that I posted in the other thread. Since my FPR is tied into the plenum, I think it is bleeding off between starts.
I had some spare time so I decided to clean my wheels. I haven't really cleaned them in probably 2.5 months or more. Since they are black, it really looked like crap. Lol. They almost looked grey.
Before:
I took off a quality control sticker so you could really see just how dirty they were.
I forgot to get a pic of the front. Lol.
After:
It isn't much of an update, but it's better than nothing
Daily driven 1992 3000GT VR-4. Check out my rebuild and progress thread: http://www.3si.org/forum/f1/my-1992-...ebuild-543314/
Modifications as of 3/21/13:
3.1L, 0.050" oversized pistons, forged crank, 3SX lightweight crank pulley, K&N intake, CX Racing pre turbo pipes. SS Y-pipe, SS oil feed/return lines, DNP precat deletes, test pipe, ESP downpipe, DSM SMICs, Ninja Performance boost controller set to 13 psi, vacuum reduction, 6 puck clutch, Drweldin custom spark plug cover, Depo Racing gauges, custom leather seats, and MMCdroid OBDI-Bluetooth datalogging adapter. Everything built and done by me. More to come soon.
Currently building/on the shelf:
3.01L, 0.020" oversized pistons, forged crank, NA block, 13T turbos, KYB GR-2 struts, Tein S-Tech lowering springs.
Djmba is online now   Reply With Quote
Old 01-24-2013, 10:18 PM   #232 (permalink)
NOTELLN
westcott's Avatar
Drives: 1991 Stealth ES
westcott is an unknown quantity at this point
Feedback Score: 1 reviews
Default Re: My 1992 3000GT VR-4 Rebuild.
Pull the vacuum line and see if any fuel spits\leaks out. It may take several minutes before you see a leak so be patient.
Ride of the Month-March 2013, Original Owner,
My Garage
westcott is offline   Reply With Quote
Old 01-24-2013, 10:49 PM   #233 (permalink)
Djmba's Avatar
When would the best time to do this be? Right after shutting it off I assume?
Old 01-24-2013, 11:51 PM   #234 (permalink)
NOTELLN
westcott's Avatar
At normal operating temperature and the vehicle is running. The diaphragm inside the FPR goes weak with heat. That is when you should find the problem.
Old 01-25-2013, 12:11 AM   #235 (permalink)
Djmba's Avatar
If it is bad, could I replace it with something like this?
Fuel Pressure Regulator Eclipse 3000gt Talon Lancer EVO | eBay
Or this
GTE Fuel Pressure Regulator Universal JDM Adjustable Turbo Fuel 140PSI (FPR-R) : Amazon.com : Automotive GTE Fuel Pressure Regulator Universal JDM Adjustable Turbo Fuel 140PSI (FPR-R) : Amazon.com : Automotive
They seem to be the same exact thing to me actually.
Because it is adjustable, it will support the 15gs I plan to install.
Old 01-25-2013, 11:16 PM   #236 (permalink)
NOTELLN
westcott's Avatar
Or this
I am sure the FPR's would work, but I am not so sure about the accompanied fittings. I would buy fittings from someone like 3SX to make sure they will adapt. Just double check the AN fitting sizes provided.
Old 01-25-2013, 11:19 PM   #237 (permalink)
Djmba's Avatar
I have the adapters to the rails. All I would need is SS hose, and banjo fittings I think.
Old 01-26-2013, 04:35 PM   #238 (permalink)
One fix at a time
TurboSinceBirth's Avatar
Drives: 95 RT/TT
TurboSinceBirth Level 1TurboSinceBirth Level 1TurboSinceBirth Level 1
Feedback Score: 32 reviews
I didn't read the rest of the thread but if you haven't already changed the fuel filter a clogged one will cause the same slow starts to happen.
TurboSinceBirth is offline   Reply With Quote
Old 01-26-2013, 05:55 PM   #239 (permalink)
Djmba's Avatar
Thanks for your input. The filter has about 10k on it. I planned on changing it when/if I did the FPR. I haven't even looked to see if the FPR is leaking because I have been busy with physics homework. I might do it tomorrow. If the FPR isn't bad, I will take a look at the filter.
On a side note, I passed 5000 miles on the rebuild today I also went to drop off the flywheel for the other engine to get it balanced, but realized that it would be best to resurface it first before it was used to balance the engine. I wound up leaving with the flywheel and dropping off the front turbo exhaust housing that had the hole welded shut for him to fix. I will get the flywheel resurfaced and drop it off at the machinist probably Monday.
Old 01-29-2013, 09:58 PM   #240 (permalink)
NOTELLN
westcott's Avatar
I smell money burning in someone's pocket!!!!!!!
Just got back in town. Hope Physics has not popped your cork!!!
Let us know what you find on the FPR.
