LinkBack (2) Thread Tools
Old 07-06-2008, 08:03 AM   #61 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (24)
Monster Stealth Level 4Monster Stealth Level 4Monster Stealth Level 4Monster Stealth Level 4Monster Stealth Level 4
Default Re: Modified Accessory Belt Routing Complete (PICS)
Originally Posted by Trevor View Post
For future reference....060380 works well with no AC, the timing belt pulley for tensioning, and an unorthodox underdrive.
Thanks! I have been running that same setup with a 5 rib belt or some time and it squeals on me and it getting on my nerves lately.
9b 13.2 w/ 93 Pump
Originally Posted by Ron Burgundy
Lot Lizards Love Salisbury Steaks
Monster Stealth is offline   Reply With Quote
Old 10-05-2008, 08:12 PM   #62 (permalink)
New VR4 Lover!
Lionhearted's Avatar
Drives: 93 3000GT VR4
Trader Rating: (7)
Lionhearted is an unknown quantity at this point
Planning on doing this very soon.
Not having access to a Torch and not knowing where I could rent or borrow one without searching.
Do you think it would be possible to cut the bracket with a dremel? Or would the metal be to hard and tear up the dremel?
Oh and by the way, thanks for making this great write up!
BPU Black - 93 - VR4
Off the Jackstands and running strong!
Lionhearted is offline   Reply With Quote
Old 10-05-2008, 08:15 PM   #63 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7
You could, sure. It'll take a long time using a little Dremel cutoff wheel though.
Do you have access to any air tools? A large cutoff wheel? Even a air-powered cutoff wheel will take a while.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is online now   Reply With Quote
Old 10-05-2008, 08:22 PM   #64 (permalink)
putting up the hat
machV's Avatar
Drives: '91 STEALTH RT/TT
Trader Rating: (14)
machV machV machV machV
i used my air cut off tool on this. Worked better I would thank than a torch. Round off the sharp edges with a grinding wheel.
Great right up. Not so easy doing with motor on stand tho! As I thought it would have made it much simpler, lol it didn't.
BACK ON BORROWED TIME
been screwed around with too long
-Jimmy
machV is offline   Reply With Quote
Old 10-05-2008, 10:16 PM   #65 (permalink)
Nihil's Avatar
Drives: '95 Stealth Base
Trader Rating: (7)
Nihil is an unknown quantity at this point
I used a bench grinder, it didn't take that long, 10 solid minutes maybe? Maybe 20 with a beer near by? ha...you don't need a torch, I'd recommend a grinder of sorts though, dremel would probably be a pain in the ass and take too long, hand cramps...
Nihil is offline   Reply With Quote
Old Yesterday, 06:56 AM   #66 (permalink)
NG '03 6th Floor Crew
lethal_vr4's Avatar
Drives: 92 VR4/ 01 Lightning
Trader Rating: (58)
lethal_vr4 level 6lethal_vr4 level 6lethal_vr4 level 6lethal_vr4 level 6lethal_vr4 level 6lethal_vr4 level 6
I also used a cut-off wheel on my air powered die grinder. Worked great an was my preferred method. Much more control over a torch.
Web log: http://apps.blackflagracing.com/Blog/
The Armada
'93 Sandstone Gray 3000GT VR-4
2006 3SI Ride of the Year
2007 All Mitsu Cookout, 1st Place 1st Gen 3/S
2008 All Mitsu Cookout, 1st Place 1st Gen 3/S
'92 Fiji Blue 3000GT VR-4
2004 All Mitsu Cookout, 1st Place 1st Gen 3/S
2005 NG Quick 8 AWD Unlimited 1/4 Mile Qualifier.
BLACK FLAG RACING
'92 Emerald Green Pearl Stealth RT/TT
3.5L, 15Gs, AEM EMS
For Sale
lethal_vr4 is offline   Reply With Quote
Old Yesterday, 02:53 PM   #67 (permalink)
Certified *** BADASS
superinflamo's Avatar
Drives: 1995 3000GT VR4
Trader Rating: (11)
superinflamo Level 4superinflamo Level 4superinflamo Level 4superinflamo Level 4superinflamo Level 4
Originally Posted by Struggly View Post
In what follows it is assumed that the A/C system has been deleted and that A/C compressor has already been removed from the car.
I read the thread before I read the first paragraph.
HA... probably should have read the first paragraph first instead of last...
Might've prevented me from going "Wtf??"
Vid of My VR4
Click Here
superinflamo is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/modified-accessory-belt-routing-complete-pics-354474/
Posted By For Type Date
just for future referance - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-19-2008 11:28 AM
Compilation of DIY's - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-14-2008 06:18 PM
