#51 (permalink) |
So... Rerouting around the A/C compressor isn't possible with just a shorter belt ?
SRT4 11.94@112mph stock turbo, no nitrous
345whp/407TQ 409whp/505 TQ on the bottle |
#52 (permalink) |
est. sept, 2000
it is. gus did it.
i dont remember what size belt he used though. gotta go trial and error for it.
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98 03 cobra vert. 4 mods=118mph traps 91 stealth TT. td05 18G, heads/cams, 3000lbs 95 montero SR. factory rear locker. 3.5 DOHC ![]() |
#53 (permalink) | |
Racing
or, 5060415 to use the stock tensioner pulley (how i did it, but the belt almost touches itself between the two pulleys to get it tight enough, mine are about .5" apart, but have not given me any problems yet, I believe you can use this method to bypass the ac compressor without even removing it, but don't quote me on that one)
#54 (permalink) | |
est. sept, 2000
gus did it the 2nd way so i guess thats the belt he used. |
#55 (permalink) |
looks good, on my car i replaced the overflow with a black moroso which is fairly small. im going to be deleting the windshield wipers and wiper motor as well, i want a bare firewall. good job on the alty belt
#57 (permalink) |
Wanted: Traction Problems
I just cant bring myself to delete my AC, but its about the only thing left in the engine bay that can be deleted.
Its filled with R12, I live in Florida, and it works great, I just cant do it. how much weight is it all together anyway? Great write-up BTW |
#58 (permalink) |
Just a note for anyone who decides to run just the crank pulley and alternator with modified bracket (i.e. removes the tensioner, idler pulley, and a/c compressor) and has swapped the stock pulley for an Unorthodox underdrive pulley, the belt size you are looking for is 378...(i.e. k040378 which is what I'm using, or a k060378 if they make such a thing?) A 375 is too tight and a 380 is too loose...hope this saves someone the trouble I went to of getting 5 different belts until I found one that would work.
Disclaimer: This is on a 91 NA...should be the same for all other models though, unless Unorthodox UD pulleys are different sizes between 91 and 92-99...Also, car isn't running yet, this is just info for tight belt fitment. |
#59 (permalink) | |
3SX FTL
Clint
The Pansy Patrol
1995 3000GT VR-4 but real niggaz don't give a fuck: V1, comprehensive denastificizzle, vishizzous accessory biznelt mod, K&N, Greddy Profec B S-P-to-tha-izzec II, S-AFC, Walbro 341, DSM 450s, n AEM UEGO; battery relocizzle K-R-to-tha-izzank Vents, EK2MFG fizzle rizzle loop n plenum spaca, lethal_vr4 manual gang bangin' rizzay, SKVR4 AWS delete, polyurethane motor mounts, adjustable control arms, SS brakes lines, n EGR blockoffs; Custom brakes lines wit cockpit-mounted adjustable proportion'n valve, 332mm Stoptechs, Carbotech Brotha Plus/Porterfield Rizzle ATE Pusha Blue, OZ Gang Bangin' F1 Plus 17x9.5 +36mm, Yokohama AVS ES100 275/40/17, Tein Fizzle w/EDFC n SCE Casta/Camba Plates, SCE oilpan, DSM sidemounts, DN Precat Eliminizzles 13G/9B combo (9psi springs), J-spec final drive, RPS flyhweel n Spec II clutch, IPO propane, ATR downpipe, tizzest pipe, n Single Shot1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it ![]() |
#60 (permalink) |
Z15A Tweaker
For future reference....060380 works well with no AC, the timing belt pulley for tensioning, and an unorthodox underdrive.
96 Dodge Stealth R/T TT w/59k
10.396 @ 138.94 (C16+Meth) 10.898 @ 130.00 (91+Meth) ![]() |
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/modified-accessory-belt-routing-complete-pics-354474/
| Posted By | For | Type | Date | |
| just for future referance - Florida's Mitsubishi 3000GT & Dodge Stealth Community! | This thread | Refback | 04-19-2008 12:28 PM | |
| Compilation of DIY's - Florida's Mitsubishi 3000GT & Dodge Stealth Community! | This thread | Refback | 04-14-2008 07:18 PM | |
| Thread Tools | |
