LinkBack (2) Thread Tools
Old 11-13-2006, 02:43 PM   #11 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: '93 3000GT VR-4
Trader Rating: (22)
AdamVR4 Level 2AdamVR4 Level 2AdamVR4 Level 2AdamVR4 Level 2
Default Re: Modified Accessory Belt Routing Complete (PICS)
That's one less pulley that I currently use. Nice work. I'll do this sometime soon.
I'm all too familiar with the technique required when using that specialty tool. The belt I use with my set up (which uses the stock idler pulley only) is about 1-mm too short, so it makes me hate life every time I have to reinstall it (which always seems to be at midnight-3 am, so I can never go get a different belt, haha).
PEARL WHITE '93 VR-4 // Now running...
E16G's: 10.573 @ 135.01
(Trevor owns me )
E16G's: 11.28 @ 124.7
(Pure pump gas ET record )
14B's: 11.10 @ 127.3
(AWD 14B ET record. Take THAT, Trev! )
9B's: 12.78 @ 107.1
Congrats to the current top 10 members!!
DynamicRacing: US 3S Top 10 Fastest List
10th Amendment: The powers not delegated to the United States by the Constitution, nor prohibited by it to the States, are reserved to the States respectively, or to the people.
GIVE ME LIBERTY, OR GIVE ME DEATH!
AdamVR4 is offline   Reply With Quote
Old 11-13-2006, 03:24 PM   #12 (permalink)
91vr4n00maxima's Avatar
Drives: slow 97 VR4
Trader Rating: (20)
91vr4n00maxima Level 291vr4n00maxima Level 291vr4n00maxima Level 291vr4n00maxima Level 2
nice work. glad 1 of us finished this.
91vr4n00maxima is offline   Reply With Quote
Old 11-13-2006, 03:38 PM   #13 (permalink)
Mod O' Day Pron
Sean Johnson's Avatar
Drives: C5, VR4, 65-Cooper S
Trader Rating: (13)
Sean Johnson Level 2Sean Johnson Level 2Sean Johnson Level 2Sean Johnson Level 2Sean Johnson Level 2Sean Johnson Level 2
As stated, very nice write up.
Sean Johnson is offline   Reply With Quote
Old 11-13-2006, 03:49 PM   #14 (permalink)
4u2nv's Avatar
Drives: FWDTT
4u2nv is an unknown quantity at this point
Thumbs up Re: Modified Accessory Belt Routing Complete (PICS)
Great write up. I'm definintely going to tackle this one before the end of the year.
1998 DOHC 3000GT - FWDTT - 309 FWHP @ 8 PSI
Modifications :
Performance ;
ATX -> VR-4 MTX Swap -> TT Conversion (9b's); Limited Slip Differential, RPS Street Max Clutch, RPS Lightened Flywheel, Short Shifter, MSD Spark Plug Wires and Spark Plugs, Air Intake, Unorthodox Underdrive Pulley, Stillen Downpipe, Rear Precat Eliminator, ATR Single Shot Exhaust, Fidanza Adjustable Cam Gears, Greddy Prfec-B Boost Controller, Greddy Type-S BOV, Nexus Gauges, Eibach Lowering Springs, Solid Motor Mounts, Dyna Batt, Kazera KZ-A Lightweight Rims, Fuzion ZRI Tires.
Appearance ;
Clear Corners
4u2nv is offline   Reply With Quote
Old 11-13-2006, 04:15 PM   #15 (permalink)
It's all stock.
306GTO's Avatar
Drives: a de-badged sleeper
306GTO is an unknown quantity at this point
I thought you were going to keep the idler pulley. Guess not.
Good write-up.
Handing out reality checks to "500HP Hondas" for 8 years and counting.
'92 Sandstone Grey 3000GT VR-4. K&N filter, Spec 5 clutch, NGK plugs/wires, Custom EBC, Greddy E-manage Ultimate, built 6G74 engine (in progress), Turbonetics ceramic ball-bearing T-70, custom intake/exhaust/intercooler piping (still plumbing those), 24"x12" FMIC, Brembo rotors, Stillen pads, E-bay Ground kit, 2nd gen shifter, HKS SSQV, Denso 660's, twin Walbro fuel pumps, GTO center garnish, eK2 EGR block-off plates, Prosport gauges: [oil press, fuel press, manifold press, oil temp, water temp, volts], Toni's interior LED conversion (still installing), forgot the rest.
'91 Firestorm Red 3000GT VR-4. K&N filter, eK2 poly engine mounts, Seattle Short Shifter, custom MBC, Spec 3+ clutch, Forged crankshaft, Tein S-Tech springs (front only), DNP Y-pipe, TD04H-13T's (with 13T wastegates), amber taillights, gutted pre-kitties, eK2 EGR block-off plates, Prosport gauges: [oil press, manifold press, fuel press, water temp], Megan Racing downpipe, Borla exhaust, NGK plugs, MSD wires, Greddy type-S BOV, Greddy E-manage Ultimate, RC 550 injectors, Denso "Supra" fuel pump, MSD DIS-4, Brembo rotors, Stillen pads, forgot the rest.
'90 Fiji Blue 300ZX TT. Stillen front bumper/nose-panel/wing/control arms/sway bars, Greddy intake/exhaust/clutch/fuel injectors, Super Autobachs strut bars, Brembo brakes, Energy Suspension bushings, Tokico shocks, JWT ECU chip, Bomex rear bumper, Nismo gound kit, NGK plugs, IPS short shifter, Custom interior, forgot the rest.
'92 Black MR2. Wife's car. K&N filter on a custom cold-air intake, some interior stuff.
306GTO is offline   Reply With Quote
Old 11-13-2006, 05:24 PM   #16 (permalink)
Vette
Drives: '92 VR4, '07 C6
Trader Rating: (10)
Slickwheel is an unknown quantity at this point
nice...i can't wait to do this one...thanks for the quality write up...
- matt
'08 Corvette C6
'07 Corvette C6 (Sold)
'92 3000GT VR4 (Sold)
'94 3000GT VR4 (Crushed)
Slickwheel is offline   Reply With Quote
Old 11-13-2006, 09:19 PM   #17 (permalink)
Getting spanked in SM
Juko's Avatar
Drives: 1994 3KGT DOHC
Juko is an unknown quantity at this point
I am not trying to steel your thunder, but here is what I did to remove those heavy brackets. I installed a pulley used to apply tension to the timing belt. You can buy them through 3SX.com. It has an offset hole which allows you to rotate the pulley and apply tension on the belt. The belt still barley fits when the idler pulley bolt is loosened, but once it is turned down, you can apply the correct amount on tension on the belt.
I don't remember what mounted to the hole used to fasten the pulley but it was obviously free. The only thing you have to do is add washers to move the pulley away from the engine block and once tightened you have to make sure the pulley is straight.
94 3000GT
Mods: Cusco rear strut bar, 18x8 OZ F1-Plus wheels, Sumitomo HTRZ II tires, Magnecor KV85 wires, Odyssey Dry cell battery, Quaife ATB differential, Custom Magnaflow exhaust, Tein Flex, Addco rear sway bar.
Autometer 2 1/16" Gauges: Fuel Pressure, Oil Pressure, A/F, Water temp, Volts. Westach dual EGT gauge.
Super AFC, MSD-DIS4 Ignition, 3SX front strut bar, Custom cold air, GONZOPerformance Short Throw Shifter, Denso Fuel Pump, GOZA Recirculating Catch-Can, SX FPR, SX Fuel Filter, SS-Fuel Lines, 350cc injectors, weight reduction mods...
Juko is offline   Reply With Quote
Old 11-13-2006, 09:32 PM   #18 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Trader Rating: (22)
*ALMOST* makes me regret throwing away ~2 dozen of those eccentric pulleys - haha. Great idea by the way.
Old 11-13-2006, 11:39 PM   #19 (permalink)
Wrenchmonkey #839
John Monnin's Avatar
Drives: crappy SHO
Trader Rating: (29)
John Monnin Level 2John Monnin Level 2John Monnin Level 2John Monnin Level 2John Monnin Level 2
You should make a Wikipedia entry about this. 6 months from now this thread will be impossible to find but a Wikipedia entry could be found fast.
For sale 6G74 Modified to install in 3Shttp://www.3si.org/forum/f68/f-s-com...9/#post5613940
John Monnin is offline   Reply With Quote
Old 11-14-2006, 12:51 AM   #20 (permalink)
champas's Avatar
Drives: 99' frc
Trader Rating: (16)
champas is an unknown quantity at this point
clint, what about aftermarket underdrive crank pulley(you have stock right?), is any belt available for it?
sold in 2007: evo3 16g's, PTE 780cc, dual walbros, IPO dual feed setup, RPS cc clutch, aem ems, dr stage 3 heads, dr street grind cams, titan headers, ebay fmic, 3.1l, 8.5:1 ross pistons, pauter rods, APR head studs, gtpro head gaskets, mr gears, 1 piece pst driveshaft, setrab oil cooler, BORLA exhaust, etc etc.
Adjustable Control Arms, TEIN S Lowering Springs, re30.
99' Front End Conversion, VIPER Style Hood, 1st Gen Stealth Sideskirts
champas is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/modified-accessory-belt-routing-complete-pics-354474/
Posted By For Type Date
just for future referance - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-19-2008 03:28 PM
Compilation of DIY's - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-14-2008 10:18 PM
