LinkBack (2) Thread Tools
Old 10-31-2009, 03:23 PM   #91 (permalink)
Drives: 3000gt VR-4
13diamonds is an unknown quantity at this point
Default Re: Modified Accessory Belt Routing Complete (PICS)
I just read the thread but i'm still unsure. Which belt could i use to reroute around the a/c compressor since mine started squeeling ? i'm eventually going to fix it but i need to stop the squeeling for now
13diamonds is offline   Reply With Quote
Old 10-31-2009, 03:56 PM   #92 (permalink)
I kill brakes
Highboosted's Avatar
Drives: Other People Around
Trader Rating: (29)
Highboosted Level 1Highboosted Level 1
Usually squeeling is from a too-loose belt or a dirty belt. Since we do not have automatic tensioners, you have to tighten the belt every so often as it ages.
*390 for routing straight to alternator, no other pullies, underdrive crank pulley will use 370.
*400 for routing using timing tensioner as idler, or reversing stock tensioner, underdrive crank pulley will use 390.
pıdnʇs 'ɹǝʌo ǝɯ dılɟ
Official member of the "I upgraded everything in my car and now it's slower than stock" club.
12.8@107, 13 psi @ NG09.
Highboosted is offline   Reply With Quote
Old 10-31-2009, 04:30 PM   #93 (permalink)
Drives: 3000gt VR-4
thanks so if i use a 400 i can reroute the belt for now and when i get a new compressor just replace with a oem belt and have my a/c back?
Old 11-13-2009, 07:16 PM   #94 (permalink)
leesredgt's Avatar
Drives: mitsubishi 3000gt
leesredgt is an unknown quantity at this point
If i use the *400 belt do i still have to cut the Alt. bracket?
93 Toyota Supra TT 6spd-BPU
93 Nissan 240sx Convertible-RB25DET
92 Mitsubishi 3000GT-FOR SALE
leesredgt is offline   Reply With Quote
Old 11-13-2009, 08:08 PM   #95 (permalink)
I kill brakes
Trader Rating: (29)
No, the 400 belt avoids modifying the alt bracket, but you need to use an idler, I use a timing belt tensioner puller and a couple washers in place of the stock stationary idler.
The 390 is for straight routing with stock pulley, but need to modify the bracket. IIRC 370 for unorthadox underdrive and modified bracket, I'll have to check my notes.
Old 11-13-2009, 08:55 PM   #96 (permalink)
leesredgt's Avatar
Sweet.I still have to reverse the stock tensioner dont i?Or do i still just put tension on it by pulling the alternator up with a pry bar?
Also i went to gates website and put in the number and i cant find it.Is there anything else i need to put in to bring it up?
Thanks for your help.
Old 11-14-2009, 01:15 AM   #97 (permalink)
I kill brakes
Trader Rating: (29)
No more stock tensioner, that whole shabang can be removed, along with that heavy A/C bracket. You will save 34 lbs from removing the compressor, bracket, and tensioner, condensor and bolts. Not including the evaporator core, lines, and dryer, which was around 7-10 lbs IIRC with blower assy.
Timing belt tensioner pulley is what will tension the belt, no need for removing the alternator or anything. I'll take a pic tomorrow for ya.
Part number IIRC is K060400. (6 rib, ~40 inch length)
Hidden somewhere in this thread is all the information, I just took notes of everything to keep it organized, but I can't find them yet.
Pic of straight routing courtesy of r1elkins:
https://webfiles.colorado.edu/elkins...ker/belts1.jpg
With a 370 belt and underdrive, stock pulley will use a 390.
Old 11-14-2009, 03:17 AM   #98 (permalink)
Engine Extraordinaire
Mean Green's Avatar
Drives: 93' VR4
Mean Green is an unknown quantity at this point
interesting...I wonder if this can be done and still keep the A/C? I want to eliminate the pulleys as that is probably the only original part on my motor and they are in need of replacing due to squealing pulley bearings.
2001 Green Mitsubishi Eclipse - ASA Mesh Wheels wrapped in BFG's
1993 Panama Green VR4 - Fresh Paint - TE37's wrapped in Nitto NT555 - Fresh Build - Fresh Transmission - Stage 4 Clutch - Brass Shift Bushings - KYB GR2 - Tein S-Techs - Maximal Mounts - Maximal Rear Camber adjusters - Custom Autometer Gauges in dash - Ball Bearing Short Shifter - Greddy Prof B Spec 2 - HKS VPC - DSM Side Mounts - Everything in engine bay is Powder Coated or Ceramic Coated - Kenwood Headunit - Dual Infinity Baselinks - Optima red top - Dejon Y pipe w/ Blitz BOV - Heat Wrapped Intercooler piping - HKS turbo timer - Hot Wired Fuel Pump - Walbro 255 - now just waiting on some terdbo's...heh
My parts forsale thread
My Car Before and After
I absolutely HATE price gougers
Quote from my other half: "Some days you have patients and some day's I don't even see how you can do anything at all because your being sooo inpatient."
Mean Green is offline   Reply With Quote
Old 11-14-2009, 12:53 PM   #99 (permalink)
I kill brakes
Trader Rating: (29)
Nope, without the stock tensioner pulley the belt will not wrap around the A/C compressor enough to spin it, and you'll squeel like mad with the A/C on...
You could eliminate the idler, though, with a bit of grinding on the alt bracket, if you can find the right size belt.
Old 11-14-2009, 07:08 PM   #100 (permalink)
leesredgt's Avatar
Ok so i went out and got the 400* belt and tried it,and even without the timing tensioner pulley on there its not long enough to go around the the stock crankshaft pulley and the Alt.
Should i put the free spinning pulley on and loosen the Alt. up and then stretch it around it and pry it back up into place like he did in the first picture and tighten it down? Im trying to keep from cutting the bracket if possible,i want to be able to put it back to factory if i ever wanted to.
Thanks again for your help,i appreciate it very much.
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/modified-accessory-belt-routing-complete-pics-354474/
Posted By For Type Date
just for future referance - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-19-2008 03:28 PM
Compilation of DIY's - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-14-2008 10:18 PM
