LinkBack (2) Thread Tools
Old 11-13-2006, 03:25 AM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
Default Modified Accessory Belt Routing Complete (PICS)
This thread explains the procedure for modifying the K6 accessory belt routing such that the tensioner and idler pulleys, along with their associated brackets, may be deleted. In what follows it is assumed that the A/C system has been deleted and that A/C compressor has already been removed from the car.
Preliminary notes:
A new accessory belt is needed. Gates/Napa/Carquest #060390 works. Because this modification eliminates the tensioner, the belt must fit perfectly. The next size up, #060400, is too large. Most parts stores will have 390 or its equivalent; it is a fairly common belt. Final belt tension is a touch tight.
Preparatory disassembly
Remove the following:
Driver’s side wheel
Driver’s side inner wheelwell plastic (to expose crank pulley and accessory belt tensioner)
Driver’s side intercooler outlet pipes and hoses where they cross over alternator
Driver’s side intercooler inlet hose
A/C fan (if vehicle so equipped)
Electrically disconnect the alternator
Remove the two bolts securing the power steering cooling loop to the frame rail. It is necessary to push these lines down in order to easily remove the idler pulley.
Primary disassembly
Remove the tensioner pulley and bracket. To take off the pulley, fully remove the center bolt. Then, remove the bracket. There are 3 bolts. Next, remove the idler pulley center bolt and then remove the idler pulley. Then, remove the A/C compressor bracket. It is held in place by 6 bolts
Tensioner bracket
A/C bracket
Note: It is probably possible to remove the A/C bracket and idler pulley together, but that makes for a few awkward reaches and a more awkward piece.
Remove the alternator assembly (alternator + bracket). It is held in place by two bolts near the front valve cover and two bolts on the front (i.e. timing-belt side) of the engine.
Lower the assembly down until it rests on the crossmember. It is not necessary to remove the assembly from the car. Be cautious not to strike the radiator with the alternator.
Remove the smaller bolt and the nut and crosspin holding the alternator itself to the bracket. They should not be difficult to break free and the crosspin should come out easily. However, the bracket may not freely separate from the alternator. Wiggle it back and forth and be patient.
Modifying the alternator bracket
Using an oxy-acetylene torch, severely compromise the structural integrity of the bracket by removing about 2/3 of the boss for the lowermost bracket-to-engine mounting hole. Complete with a bench grinder, making sure to round off the corner beneath the adjacent boss. The belt will ultimately pass very close by here; if you do not remove enough material, there will be interference. Take off a little more, rather than a little less.
Installing and tensioning the new belt
Put the modified bracket back on the alternator and reinstall the crosspin and lower bolt. Leave them loose to allow maximum alternator movement. Install the alternator assembly on the car using only the modified boss mounting hole. The stock bolt will be to long; use a M8x1.25 bolt 20-30mm long bolt (depending on how much material you removed) as a replacement. Leave this bolt somewhat loose as well.
The alternator can now be pivoted down, though the close fit of the alternator bracket and the L-bracket on the head near the dipstick makes this difficult. Use your hands to rotate the alternator down.
Install the new belt (060390) on the crank and alternator pulleys.
Tensioning the belt requires a Mitsubishi special tool (tool number M1366590 Revised Routing Tensioner), as shown below.
Using the special tool, raise the alternator until the mounting holes on the bracket line up with the holes on the L-bracket. Install the bolts.
Finally, reinstall the other alternator bracket mounting bolt and tighten the bolt and the crosspin nut holding the alternator proper to the bracket.
Reinstall the parts listed above under “preliminary disassembly”
Assorted photographs of new belt routing
Additional photographs of alternator bracket
Stock:
Modified:
Parts deleted
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 11-13-2006, 03:29 AM   #2 (permalink)
vehicular thaumaturgist
Multiades's Avatar
Drives: 1994 Stealth TT
Multiades is an unknown quantity at this point
Default Re: Modified Accessory Belt Routing Complete (PICS)
Nice writeup. Minimalist-awesome. I solved the excess crap problem by modifying the AC compressor bracket to the point where it would just barely hold the tensioner on, but left the tensioner; I will have to try this method though.
Multiades is offline   Reply With Quote
Old 11-13-2006, 07:39 AM   #3 (permalink)
never a dull moment
DCIV's Avatar
Drives: 93vr4 & 92vr4
Trader Rating: (13)
DCIV Level 1DCIV Level 1
Dang I want to do this. I bet it looks alot cleaner as well.
Coop
To many mods to list.
Old 11-13-2006, 09:49 AM   #4 (permalink)
nduda78's Avatar
Drives: 96 VR4
Trader Rating: (15)
nduda78 Level 1nduda78 Level 1
Have you seen clints engine bay? clean? hahaha... a kick ass ride for sure but lets just say "he doesnt like extra parts"...extra parts mean anything that came stock with the car
Coop
nduda78 is offline   Reply With Quote
Old 11-13-2006, 01:19 PM   #5 (permalink)
Quality nOOb
NoCar's Avatar
Drives: Home from Ray's
Trader Rating: (30)
NoCar is an unknown quantity at this point
"Tensioning the belt requires a Mitsubishi special tool (tool number M1366590 Revised Routing Tensioner), as shown below."
LMAO! Nice
Great writeup!!!
Best regards,
Sean
X-CASE,13T's,EVO VIII's,AEM wideband,Walbro255,Aeromotive AFPR,IPS Y pipe,TurboXS-bov,DSM Sidemounts,DownPipe w/no cats,CFDS,Speeds Polymounts,RP-01's,FMOC,Vac Reduction,Coolant Bypass,EGR Blockoff,True Hotwire & bypass,AEM EMS w/supporting,Dejon Twin Intake,Turbo XS MBC,Cianci pillars,2 serial gauges,Smoking din plate,Smoking shifter ring,Smoking dash vents,Rear Wiper Delete,96 Stealth Spoiler,384/422 TUNED BY THE MAN(Ray)!
NoCar is offline   Reply With Quote
Old 11-13-2006, 01:58 PM   #6 (permalink)
Drives: 92 VR4 & 95 TalonAWD
woovr492 is an unknown quantity at this point
great minimalist mod.
sweet write up as well
92 VR4 = Driveway Ornament
woovr492 is offline   Reply With Quote
Old 11-13-2006, 01:59 PM   #7 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
nice
pics of said engine bay?
R.I.P.
Old 11-13-2006, 02:00 PM   #8 (permalink)
The Speedy Swed
The_Kid's Avatar
Drives: 92 vr4, 02 Wrangler
Trader Rating: (10)
The_Kid Level 2The_Kid Level 2The_Kid Level 2The_Kid Level 2
Did you messure how much weight this mod saved??
Blitz SBC i-D RPS lightweight flywheel and maxseries streetdisc! IPO fpr & filterkit and a Walbro 255 lpm fuelpump. Custom made 3" exaust with 100 cell highflowcat and a rebuilt ATR downpipe no precats
Cosco Oil Catch Tank. Lightweight battery Odessy 680 Accel plugwires. Homemade Alu sparkplugcover with "THE KID" ingraved. Groundcontroll Coilovers. Silver Pro N-1 18" with falken 255-35/18. Veilside frontbumper, Veilside carbonfiber wing and Veilside sideskirt. Ohio spiderman STS, Genuine italien leather shift and e-brake boot.
The_Kid is offline   Reply With Quote
Old 11-13-2006, 02:06 PM   #9 (permalink)
We live here.
VR-4ever's Avatar
Drives: 4.6is X5 w/ blower.
Trader Rating: (13)
VR-4ever is an unknown quantity at this point
Holy crap man, nice job!
VR-4ever is offline   Reply With Quote
Old 11-13-2006, 02:39 PM   #10 (permalink)
|RLII Photography|
VR4Rob's Avatar
Drives: 94 VR-4 - 05 LeggyGT
Trader Rating: (13)
VR4Rob is an unknown quantity at this point
As everyone has said, very nice job. It's refreshing to see someone execute a well thought out process and make an informative post about it. Your "excess delete" threads always make for an interesting read.
1994 Mariana Blue Pearl Mitsubishi 3000GT VR-4
DR-650s and supporting, PST CFDS, Volk GT-Cs, among other things
Feb. 06 3SI ROTM - Best AWD BRG 07 - 3rd Place 2G 07 3/S National Gathering - People's Choice BRG 08
2005 White Pearl Subaru Legacy GT Lmt. Wagon 5MT - TommyKaira shoes
(Hers) 1992 Panama Green Pearl Mitsubishi 3000GT VR-4
VR4Rob is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/modified-accessory-belt-routing-complete-pics-354474/
Posted By For Type Date
just for future referance - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-19-2008 03:28 PM
Compilation of DIY's - Florida's Mitsubishi 3000GT & Dodge Stealth Community! This thread Refback 04-14-2008 10:18 PM
