Old 08-14-2008, 07:36 PM   #21 (permalink)
jeettao's Avatar
Drives: '99 3000GT VR-4
jeettao Level 7jeettao Level 7jeettao Level 7jeettao Level 7jeettao Level 7jeettao Level 7jeettao Level 7jeettao Level 7jeettao Level 7jeettao Level 7jeettao Level 7
Default Re: Modding Crossroads
Originally Posted by mess View Post
I have pretty much the exact same setup as you and I run 20lbs of boost on god awful California 91 octane.
I am AEM also + all the supporting mods, etc etc.
Edit: And I made 440awhp a few months ago on the dyno at 108* in the dyno facility. No meth injection or any of that. Plain old "premium" pump.
Damn man. How long/how many miles have you been running that?
jeettao is offline   Reply With Quote
Old 08-14-2008, 08:57 PM   #22 (permalink)
Drives: 95 Green VR-4
Trader Rating: (11)
mess Level 4mess Level 4mess Level 4mess Level 4mess Level 4
I don't know, a year or so? With this new tune from FSR it's been say, 4 months? I am pretty confident in the tune and it's pretty conservative. I don't see any reason you can't run similar numbers with all the supporting mods.
PPS. Josh did my first tune too and he's good people. If he reads this, Josh send me my timing belt covers. :P
mess is offline   Reply With Quote
Old 08-15-2008, 08:12 AM   #23 (permalink)
Drives: An AEM car in -10F
Trader Rating: (9)
MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5
Turn the boost up and tune. With the FMIC and AEM your should have no issues (assuming no operator error).
~Ryan
92 Stealth R/T TT- Not exactly done- 93 RT TT- Not much of a car anymore.
"This is a solution looking for a problem." - Not me
MustGoFaster is offline   Reply With Quote
Old 08-15-2008, 12:00 PM   #24 (permalink)
BOOST!
Nuclearhappines is an unknown quantity at this point
Water injection buys you like 3-4psi
Propane injection buys you about 8 or so psi.
Maybe propane is an option ?
I'd talk to trevor about his quad nozzle WI kit, and how he has that interfaced with the MAP ECU.
Since you have an AEM you can run an injector output to drive the Water Injection with progressive control, you can also probably wire in a pressure switch or an air fuel safety switch to kick the AEM back down to a low psi map if anything happens to the WI where pressure at the nozzle drops or the A/F isn't happy.
If you're really worried about your pistons, it really is a dumb thing to put on smaller less effecient turbos that will have higher IAT's and be maxed out at a lower psi, rather than run a bigger turbo, with a freer flowing exhaust side, making the same power at a lower cooler PSI...
AEM is also really good with knock detection and calibration. I don't know why you're worried ?
1991 Celica GT-T - SOLD
1991 3000gt vr4 BPU - SOLD ...and missing her
2005 C200 Kompressor sport
K&N Filter, Apexi WS2 Muffler, DIY Voltage Stabilizer, Intrax lowering springs, H&R rear 19mm sway bar, EBC redstuff pads, VDO Boost gauge @ 7psi, Greddy Iridium Plugs
TO DO: 15% overboost pulley
Nuclearhappines is offline   Reply With Quote
Old 08-15-2008, 12:12 PM   #25 (permalink)
jeettao's Avatar
I'm worried because they're the same pistons used on the Dodge Caravan. One bad tank of gas, extra hot day, an ant sneezing in the intake, and a cast piston will turn into abstract art.
You're right about the AEM giving me the best chance to run that higher boost without problems. I gave propane a thought, but think meth/water should work fine. In fact, AEM makes a meth injection kit that integrates with the AEM and will send a signal to reduce timing or boost if there's problem or low methanol in the tank, which is why I like the idea of that instead of the propane.
As for the smaller turbos, yeah, that was more of an idea if I wanted to stay at 18-20 psi rather than pushing the envelope to the 22 range with the methanol. At 18-20 a big TD04 isn't too inefficient, but you're right, if I'm going to max out pump/meth, I should stick with the TD05's.
Thank you for your input
Old 08-15-2008, 12:27 PM   #26 (permalink)
is drifting WAY too hard!
Deathsled's Avatar
Drives: only in 1st gear
Trader Rating: (20)
Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7
wow you're running 16Gs at 15psi? what a waste
before you worry about future mods why dont you kick up the boost to 22+ psi first.....
96 VR4 w/ Iridium Intercooler
Deathsled is offline   Reply With Quote
Old 08-15-2008, 02:48 PM   #27 (permalink)
BOOST!
Thumbs up Re: Modding Crossroads
Trevor's insane meth setup...
http://members.cox.net/jtrevor/34.jpg
Trevor's single install progress (pic heavy)
According to his calculations ~220hp worth of meth.
Best of luck with what you decide
Old 08-15-2008, 02:58 PM   #28 (permalink)
jeettao's Avatar
Naw, man, I'm trying to figure out to do with what I've got. I'm a little nervous about trying to max out 16G's on a stock engine is all I'm sayin'. The only mod I'm looking at is a meth kit at the least.
Lol yeah I saw that meth deal. Awesome setup. That's great for the track, but I don't want to have to fill up a 1 gallon meth bottle every half mile I go, lol, this is a street car.
Old 08-15-2008, 03:47 PM   #29 (permalink)
Fool...No man can kill me
JasonY's Avatar
Drives: TT = Design Flaw....
Trader Rating: (26)
JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7
Stop around 500 wheel and the stock engine wont even be working hard. Assuming a good tune. Also, a properly setup and tuned AEM has safety defaults tuned into it incase of knock and all so it pulls timing to protect the engine.
Jason
"Busting your butt doesn't guarantee success but sitting on your butt will pretty much guarantee failure"
01.5 Dodge 2500 Cummins powered - tow rig 4"/Intake/Edge EZ/35's/built trans
Quality Parts and Service from I.P.S.
and Dynamic Racing
JasonY is offline   Reply With Quote
