Old 10-03-2007, 01:25 PM   #1 (permalink)
King Detail
ProwlerGT's Avatar
Drives: 95 3000GT Base DOHC
Trader Rating: (11)
ProwlerGT Level 1ProwlerGT Level 1
Red face MirageCorp Hybrid Datalogger; Rear O2 0 volts; Exhaust rich; RPMs no match logger
I've got a 1995 NA Hybrid OBD year DOHC
I have Shiver's 1.0B release of the datalogger for my car (specifically the hybrid year logger). I was just logging and looking at certain things and noticed that the rear O2 has zero volts. Is this normal? Or does it mean my rear O2 is out? or wire short?
Does anyone know of the hybrid logger wigging out on the O2 voltages? I've always thought it was pretty reliable, but just checking to make sure.
How many O2 sensors do I have?
Also, I noticed the exhaust smells really rich and whenever I go to set the basic idle the idle RPMs are ALWAYS about 200 RPM higher on the gauge than on the logger itself. Whats going on here?
I swear the car sounds like its idling at the right RPMs and that the gauge is wrong, but how could the gauge be wrong? I've adjusted the throttle cable and installed a rebuilt TB and everything is adjusted right. I made sure it all reported accurately while hot and running.
I took 2 logs of my idling too if anyone is interested. I don't have a clue what I'd be looking at, but I can learn.
WHERE IS CBATTERS WHEN I NEED HIM !!!!!?!?!?!
INFO LINKS FOR EVERYONE:
 ProwlerGT's Revival Thread | My Service Log | IAC | SENSORS | Hesitation Tracking List | NO3S.com
Lata,
ProwlerGT
"Those who know me, know my real name and more importantly how to say it right."
ThinkAbtIt on AIM | searcherrr on Yahoo IM | Email in profile
ProwlerGT is offline   Reply With Quote
Old 10-03-2007, 01:42 PM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Default Re: MirageCorp Hybrid Datalogger; Rear O2 0 volts; Exhaust rich; RPMs no match logger
My idle doesn't match either.
Sounds like you need a new o2 sensor.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 10-03-2007, 02:34 PM   #3 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
Question Re: MirageCorp Hybrid Datalogger; Rear O2 0 volts; Exhaust rich; RPMs no match logger
Do you know that for sure or you just sayin it sounds that way? LOL - I was just asking cause maybe that O2 in the rear isn't supposed to kick in till I'm cruising or something whereas I did my logging in PARK at idle and revving at times.
You know the kooKie thing about the logs I made is that when I put them in the translator the front and rear O2 results showed up in reverse in the logs. I'm positive it was the REAR as I was watching it log it and it shows in the logs as the FRONT which is not correct unless either the log translator or the logger swapped'em around and I don't know which data is for what O2 sensor?!?!)(%
Old 10-03-2007, 06:06 PM   #4 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (15)
Rear O2 is probably out/short in the wire/disconnected.
Not sure on hybrids, at least 2, maybe more.
Normal stock gauge. Just make sure you don't have the logger set for a faster ECU.
Old 10-03-2007, 06:17 PM   #5 (permalink)
Drives: 99 VR4
Trader Rating: (88)
SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7
The RPMs are supposidly linear in their equation, but that does not seem to be the case. It does seem that below 1000 rpms the logger is off by a bit, the gauge will be correct.
Try swapping o2 sensors and then see if it's still 0 volts. Also try to download the 1.0c beta version on the website to see if that fixes the issue.
SHiVeR-91VR4 is offline   Reply With Quote
Old 10-03-2007, 06:23 PM   #6 (permalink)
L_P
Woot!
L_P's Avatar
Drives: '95 Dodge Stealth TT
Trader Rating: (29)
L_P Level 2L_P Level 2L_P Level 2
Hybrids have two O2 sensors. (front and rear).
Sounds like your rear one is bad, should cycle at idle. My Gauge and logger match so I don't know why yours is off, has anyone ever removed the needle for anything like a white face gauge?
Anyway I wouldn't worry about it going off I would be more concerned about your O2. Get that replaced it can cause problems and foul out your plugs.
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T/E3 16G turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid engine mounts, 3" Straight pipe exhaust single out.
Looks: DCC Conversion, White face glow gauges.
Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU.
Myspace
Must go faster project underway. E85 powered
Front E3 16G installed, next is the rear one!
Equal length headers custom made.
L_P is offline   Reply With Quote
Old 10-03-2007, 06:44 PM   #7 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters Level 2cbatters Level 2cbatters Level 2
Pretty sure all years of DOHC have O2 sensors on each bank. Strong smell of fuel and poor mileage are consistent with defective O2 sensor or bad harness from O2 sensor.
You can determine which sesnor is not working (for sure) by unplugging the oxygen sensor connector which is easily accessible front/center of the engine.
Check wih Shiver - pretty sure there was a bug in at least one of the versions of his SW that caused it to read high.
If engine ius warm, AC off and ISC count is between 1 and 25 counts (indicating the ECU is in control of the idle speed) the RPM should read 700.
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 10-03-2007, 08:48 PM   #8 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
PM'ed you about 1.0c
Old 10-03-2007, 09:00 PM   #9 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
Never removed the gauge needles for different faces although today I did remove the steering collar and underdash as well as do work with the brake pedal stop light switch and pedal height adjustment. I wonder if something tightened up too tight pushing on something it shouldn't.
I have probably driven about 1000 miles or so since I put in new Denso Iridium spark plugs.. do you think the plugs could be messed up in that short of a distance from the O2 being bad?
Old 10-03-2007, 10:22 PM   #10 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
So would this mean I have 3 O2 sensors then? The 2 you said and one plugged into the exhaust pipe underneath? Cause I was thinking the one underneath was the "REAR" O2 sensor since it would be rearmost although maybe whats plugged into the exhaust pipe isn't an O2 sensor... though I wouldn't know what else it is.
You can determine which sensor is not working (for sure) by unplugging the oxygen sensor connector which is easily accessible front/center of the engine.
WHOA! I'll have to look for a diagram of that cause I don't know which one it is.
Check with Shiver - pretty sure there was a bug in at least one of the versions of his SW that caused it to read high.
If engine is warm, AC off and ISC count is between 1 and 25 counts (indicating the ECU is in control of the idle speed) the RPM should read 700.
Clint
Using the logger I've never seen just an even number for RPMs. For 700 I have to play with it till I see a range of 3 numbers: 688, 710, 750 or 6??, 688, 719.... I take the average of the 3 and figure out what its close to. I have an analog voltmeter (is this also known as a analog tachometer?) but I haven't a clue which selection I should turn it to in order to set the idle with it instead of the logger.
