Old 05-15-2008, 12:13 PM   #1 (permalink)
lancervnt is an unknown quantity at this point
Default maximum hp on engine and transmission
I have a 500whp Talon and I'm considering buying a stealth TT.
I'd like to run 9s @ 145mph+
I'm wondering what are the weak links in the Stealth TT/3000gt and what year is the best?
I have done a bit of reading and the 2nd gen motor has a forged crank.
I saw some mentions of inadequate oiling and a lot of spun bearings.
Given it is perfectly tuned How much horsepower can a stock 1st gen block handle ? stock 2nd gen?
What is the highest HP possible on a built engine. What fails in higher HP engines ?
What about the transmission, transfer case, axles etc...
I prefer to have answer based on actual experience.
Thanks !
lancervnt is offline   Reply With Quote
Old 05-15-2008, 12:34 PM   #2 (permalink)
alottaboost's Avatar
Drives: 95 Stealth RT/TT
Trader Rating: (6)
alottaboost is an unknown quantity at this point
Default Re: maximum hp on engine and transmission
Thanks !
i think the concensus is (correct me if i'm wrong) is about 600+ whp on a stock 2nd gen drivetrain (forged 4 bolt/ bulletproof six speed) and ~500 on a first gen. if you look at one of the top threads, a dude just put over 1200 to the ground with a built stroker.
alottaboost is offline   Reply With Quote
Old 05-15-2008, 12:35 PM   #3 (permalink)
Indy here we come 06/2010
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2
Go search for an read all of the posts from snakeskinner. That will answer 99% of your questions.
Better late then never? The 2009 3S Calendar
NG07 T-Shirts For Sale * NG08 T-Shirts For Sale
NG08 Stuff from Cafepress
Custom 12x18 poster/photo prints
Alan(3SI#601)alan92rttt@mi3si.org Michigan 3SI.
1992 Dodge Stealth RT/TT
My Snake Eyes, 13g Turbos, 450cc DSM injectors, Walbro 255 Fuel Pump, Autometer Boost Guage, Greddy peak/hold EGT, Apexi S-AFC, K&N FIPK, Clean Cats, 3rd Gen Lifters, JVC SX990 CD/MP3 Receiver, JVC CH-X200 12 Disc Changer.
1998 3000GT SL
Alan92RTTT is online now   Reply With Quote
Old 05-15-2008, 12:56 PM   #4 (permalink)
oohnoo's Avatar
Trader Rating: (203)
oohnoo Level 1oohnoo Level 1oohnoo Level 1
You joined today and started two identical threads in different sections. Thought new members weren't allowed to start new threads? But sersously do some searching and you can find all your answers.
----------------[2007 Ride of the Year.................................. 3.5 Stroker I did. w/DBB DR1000's
oohnoo is offline   Reply With Quote
Old 05-15-2008, 12:59 PM   #5 (permalink)
Searching takes a lot of time and sometimes it's quicker to just ask. I did search and the results I got were unconclusive.
The answers I received above are more constructive.
Old 05-15-2008, 01:15 PM   #6 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 is an unknown quantity at this point
The reason that you got inconclusive results was because there is no conclusive answer to the question. Some people have had problems just putting down 400 awhp while others have put down 600 awhp. It really depends a lot on the car and the condition that everything is in.
When you are searching you'll also find threads about different things that people have tried to get the power which can help greatly when deciding what you want to go with.
If you live in the Delaware, Maryland, or Virginia area check out our 3si chapter forum
andyvr4 is offline   Reply With Quote
Old 05-15-2008, 01:22 PM   #7 (permalink)
The thing is, I know exactly what is needed to make "X" amount power.
I've been modding cars for almost 10 years now.
What I don't know is the durability of that car. What fails at what amount of power. I know the results will differ from one to another.
Some failures might be caused by poor tuning or an pre-existing condition.
To run 9 @ 140mph+ I believe I need to make 700awhp minimum. That means I have to have a built engine I suppose. I know the stock 4G63T can take around 600awhp for a while when tuned perfectly. I was hoping maybe the stock 6G72 could take 700awhp.
I am reading about snakeskinner and he's breaking oil pump gears ?
Axles ?
I'm still reading about that...
Maybe someone could list the failure points of these cars so I know what I'm getting into.
Old 05-15-2008, 01:30 PM   #8 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (13)
SkortchGT Level 1SkortchGT Level 1
Axles ?
Delete this thread.
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, cat back & CFDS, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, PST 1pc CFDS, Borla Catback, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, engine dress up kit, Bigtyla ground wire kit, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset.
--Waiting for me to install: ARC2 w/ 92mm MAS
--Daily Driver: 2000 Malibu, 6cyl, auto
SkortchGT is offline   Reply With Quote
Old 05-15-2008, 01:32 PM   #9 (permalink)
oohnoo's Avatar
Failure points are 1st gen transfer cases of which there are t-case braces available. 2nd gen transfer cases are stronger and made out of cast iron. But strengthening those the weak link is trasnfered to the tranny of which you can make stronger by welding in a plate inside the bellhousing. After that it seems to be the axles but it all depends on alot of factors such as the suspension, tires/drag radials/air pressure andmost important how you launch the car.
Any big hp motor is going to need stronger internals if you want it to last. Slap on some big turbo's and the sky is the limit.
BETTER!
Old 05-15-2008, 01:36 PM   #10 (permalink)
Originally Posted by SkortchGT View Post
Delete this thread.
LOL why ? elaborate please
