Old 07-10-2008, 01:50 PM   #41 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: '93 3000GT ATX TT
Trader Rating: (178)
BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7
Default Re: Maximal POLY Mounts...
Originally Posted by pearlwhitwin View Post
except that the solid motor mounts have been tested in real cars with real power. solid crank pulleys are on SOHC cars and na DOHC cars making a 15X to the wheels. no one making big power is using a undampened crank pulley. however plenty of them ARE using his solid mounts with no problems.
...that you know of. Who's to say that spun bearing in car X with solid mounts wasn't due to the increased vibration introduced to the engine internals? There are also plenty of people on here that use an undampened crank pulley that make a respectable amount of power.
Trust me, I've seen a lot of vibrational analysis on countless systems before, and the knowledge I've taken from them is that nothing as sensitive as an internal combustion engine should be introduced to the magnitude of vibrations that is sure to come from a purely metallic mount. The math doesn't lie. The additional vibration is only going to add more stress to the motor, and that's the opposite of what people want in their street car. Race car? Probably not a problem.
People making big power are eventually going to have problems no matter what. You can't say that some unfortunate failure in their car couldn't have been even slightly influenced by something like solid mounts.
1993 3000GT FWD ATX TT - daily<------------------->2009 Honda Fit - 40 mpg? Yes pls.
Ground wire GB is back!!!
Old 07-10-2008, 02:28 PM   #42 (permalink)
Verified Asian
Sean3S's Avatar
Drives: 94 TT
Trader Rating: (35)
Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7
Uh... Matt ran UR underdrive pulleys on all of his cars in the past - not sure about his latest builds.
'94 RT/TT
13T's | PTE FMIC - PPE Pipes | 560's | Supra FP w/ 8ga Hotwire | MAF-T 1.37 & LT1 Blow-Through | E-Manage Blue w/ Boomslang Harness | HKS DLI | Stillen Downpipe | Gutted Rear Pre-cat | Borla Catback | Tial BOV | AEM FPR & Rob Beck Adapter | DejonTool Intake Pipes | PWR Radiator w/ IPS Pipes | FAL Fans | MP Motor Mounts | 99 Lash Adjusters | Clevite 77 Rod & Main Bearings | Leatherseats.com Dk. Graphite w/ Red Center Seats | Sparco Flash 5 Black w/ Red Alcantara | Spec Stg. 2 Clutch & 3SX Clutch Line | 3SX Crank Pulley | Bob's SS Shifter & All Solid Bushings | NGK Coppers & MSD Wires | eK2 EGR Blockoffs | eK2 Fuel Line Loop | PST 1 Pc. CFDS | Volk LE37T | Falken FK452 | Tein S-Tech Springs | Adj. Rear Control Arms | Slotted Rotors w/ Hawk HPS Pads | GReddy Profec B | AEM UEGO WB | GReddy PWH Boost, EGT, GReddy OP, FP, Temp | Hybrid Logger | McColluch 5300K HIDs | Shaved '99 Bumper & Turns | VIS Hood
295.7 AWHP / 310.3 TQ @ 1 Bar - BPU @ TX04
Collecting Dust - CM Oil Filter, Setrab Oil Cooler, Snow Stage 2 Meth, Brake Lines, Megan Coilovers
Some Day - ABS Delete, Ducting
WTB - ek2 Harness Cover (above the fuel rails)
Sean3S is offline   Reply With Quote
Old 07-10-2008, 02:38 PM   #43 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7
not that im saying to run one....AT ALL. but trevor also runs one last mod list I saw.
Coop
To many mods to list.
