Old 07-10-2008, 09:52 AM   #31 (permalink)
Drives: 91 3000gt
SilverJester is an unknown quantity at this point
Default Re: Maximal POLY Mounts...
As I think about past poly mounts I've seen....a lot of times they have metal sleeves that press in the the center, and the bolt is inserted through the sleeve. Just a thought.
Performance Mods:
Spec Stage 3+ Clutch x2
South Bend Clutch Stage 3 OFE
300M Output Shaft
Gutted pre-cats
Stillen Downpipe
Slotted Rotors
SS Brakelines
ACPT Carbon Fiber Driveshaft
Prosport Gauges
Aesthetic Mods:
18x9 Weds Sport TC005
99 Sail Panels
99 Rear Garnish
"TWIN TURBO" decals
Tinted Windows
SilverJester is offline   Reply With Quote
Old 07-10-2008, 09:54 AM   #32 (permalink)
Engineering Student
Alex3000GT's Avatar
Drives: 92 3000gt base
Trader Rating: (12)
Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7
Originally Posted by Maximal View Post
Been working on these here and there a bit and figured I'd post a little teaser pic. I just need to figure out hardware size (unless someone knows the size of the stock mount bolts off the top of their head) then I'll be testing them on my car to see how they work. Keep in mind they might change a bit.
Terry
Wow. The weak spot of our mounts has always been where the reamer bolt goes through the rubber (or poly) and eventually tears right through it over time. I never even THOUGHT of putting the dampening material at the base of the mount. That should absorb vibration, some shock, and not degrade over time.
I'm just curious as to how this design will hold over extended periods of time, like say, 5 years.
Have more pics of the mounts from top/bottom/side?
Very smart idea on your part.
NG06 - DOHC NA - ATX --- 16.6 --- 85 MPH
NG07 - DOHC NA - MTX --- 15.7 --- 89 MPH 7.78 sec 0-60 3,044 lbs w/out driver
1992 3000GT
1991 Stealth
Alex3000GT is offline   Reply With Quote
Old 07-10-2008, 10:03 AM   #33 (permalink)
Drives: 91 Stealth base
Trader Rating: (9)
91Stealth89 Negative 3
Weak, maximal solids are for real men, lol JkJk good work terry
1G SOHC part out, aftermarket and OEM Pm Me
91Stealth89 is offline   Reply With Quote
Old 07-10-2008, 10:06 AM   #34 (permalink)
TPW: Promoter
1veryfastvr4's Avatar
Drives: 97 vr4
Trader Rating: (58)
1veryfastvr4 Level 11veryfastvr4 Level 1
its nice to see ppl trying new things its what moves the platform
this is much like the mounts a buddy got for his srt4.... at first i thought they wouldnt work cause i thought at time the poly would work bolt loose....over time i dont think he has da one bit of a prob
if i recall his kit came with 2 nylock washers back to back..... an in instructions they advised thread to use locker
cant waite to see how they work out.. altho i dont see much vibration in the solids
1veryfastvr4 is offline   Reply With Quote
Old 07-10-2008, 10:25 AM   #35 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: '93 3000GT ATX TT
Trader Rating: (178)
BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7
It's a decent idea, but aside from the comments made about probable loosening problems, there will also be a harmonics issue between the engine and the mount since there is nothing in that part of the mount to absorb the vibration. Therefore, you will have some localized vibration transfered back to the motor which could be harmful. It's the reason I've never bought solid mounts and also why even some poly mounts scare me as they simply don't have the same dampening specs as other materials.
I would suggest AT LEAST putting some sort of dampening material in the side where it mounts to the engine. If you wanted to get down-and-dirty you could do a computational vibration analysis to see the difference it would make, but that's probably beyond the scope of this project for you.
1993 3000GT FWD ATX TT - daily<------------------->2009 Honda Fit - 40 mpg? Yes pls.
Ground wire GB is back!!!
Old 07-10-2008, 10:38 AM   #36 (permalink)
Supporting Vendor
Maximal's Avatar
Drives: '91 Stealth "ES"
Trader Rating: (181)
Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7
Originally Posted by 3KGTTusch View Post
My roommate has something very similar in his 68 camaro, and I was really confused what the benefit of them was in this type of application, but clearly it works because its not uncommon through out platforms.
Exactly. Talked to a few people I know who've been around muscle cars for years and they all say they've seen something similar to them.
Originally Posted by wytaco View Post
when i first got your mounts i had a similar idea. I put rubber in that same spot and tightened her down with some red loctite. Even with the loctite it only took about 4 or 5 days for it to wiggle itself loose. The front mount will probably be fine. That rear mount just takes so much abuse.
Using rubber I can see that happen. The vibrations will wear the rubber down and it's much softer. Poly has good resistance to compression so I really don't see it being a problem. If you saw affects in 4-5 days though it doesn't seem like it'll be long before I do if these are going to have a similar issue.
I can get more pics but essentially they're my solids, shortened, and poly underneath them. The front mount has a bottom plate too since it doesn't sit on a flat surface.
Eh, I've been selling the solids for I think 3 years now and have yet to see a problem with them. They're in daily drivers and race cars (Matt M is running them) so I'd say they've proven that those vibrations don't cause any issues.
Maximal is offline   Reply With Quote
Old 07-10-2008, 11:54 AM   #37 (permalink)
BigTyla's Avatar
It's a lot like the dampener debate for the crank pulley. We'll agree to disagree.
Old 07-10-2008, 11:58 AM   #39 (permalink)
Supporting Vendor
Maximal's Avatar
Understandable.
Old 07-10-2008, 12:22 PM   #40 (permalink)
single terbow
Trader Rating: (10)
pearlwhitwin Negative 1
except that the solid motor mounts have been tested in real cars with real power. solid crank pulleys are on SOHC cars and na DOHC cars making a 15X to the wheels. no one making big power is using a undampened crank pulley. however plenty of them ARE using his solid mounts with no problems.
camera phone pic
pearlwhitwin is offline   Reply With Quote
