#21 (permalink) | |
Supporting Vendor
#22 (permalink) | |
Supporting Vendor
#23 (permalink) |
Staying in the Family
Like a few others have stated, thinking outside the box is good to see, but my opinion is that you will have trouble keeping bolts tight along with loading them incorrectly resulting in sheared and bent bolts. If you had a good way to attach to the top and bottom surface with nothing passing through then it would work
![]() 92 VR4 Blacked out with a 98 conversion dr900's Fully forged 3.1L Stage 3 Heads 98 Jeep TJ 37's Locked with all the toys Cheap, Fast, Reliable.... You can only have two |
#24 (permalink) |
Supporting Vendor
Actually I looked into how some other poly mounts were designed and a lot have a bolt compressing the poly and holding them together so I'm thinking this will be less and less of an issue. These are poly which is rather hard (I'm not gonna be running 60A poly in these)....not rubber.
Muscle car poly mounts basically consist of 2 brackets connected with a rod of poly...what I'm doing here is much different except for the fact there is only 1 bracket. |
#25 (permalink) |
Supporting Vendor
Example....some Supra mounts: http://www.bicperformance.com/images...20(Medium).JPG
Somewhat different but you're still clamping onto the poly: http://www.mustangmods.com/ims/u/942/1246/113055.jpg Some e30 mounts that are again clamping down on poly: http://www.vorshlag.com/images/catal...e30_poly01.jpg Yeah, they're all a bit different but at the same time there is something being bolted down on poly and I'm assuming it's not coming apart. |
#26 (permalink) |
H to the izzO
Interesting design. I'd torque the bolts properly before the BRG, run the hell out of the car on the T.O.D., and check to see if the torque specs have change on any of the bolts. While it would be good to get a longterm test of the poly, 300+ curves would be a pretty decent test in a short timeframe.
#27 (permalink) |
TEXAS!! FIGHT!!
Thread locker is a must. Nylock nuts where applicable would do the trick. Good luck Terry.
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01 (Trevor owns me )E16G's: 11.28 @ 124.7 (Pure pump gas ET record )14B's: 11.10 @ 127.3 (AWD 14B ET record. Take THAT, Trev! 9B's: 12.78 @ 107.1 Congrats to the current top 10 members!! DynamicRacing: US 3S Top 10 Fastest List |
#28 (permalink) | |
Supporting Vendor
Yep, Figured some locktight and there won't be any issues. I'm still thinking they might be fine anyways. Oh well, we'll see. |
#30 (permalink) |
when i first got your mounts i had a similar idea. I put rubber in that same spot and tightened her down with some red loctite. Even with the loctite it only took about 4 or 5 days for it to wiggle itself loose. The front mount will probably be fine. That rear mount just takes so much abuse.
