#13 (permalink) | |
Supporting Vendor
Terry |
#14 (permalink) |
Master Of Disaster
Fucking awesome. Let me know what the sound levels do with the trans gear whine.
1992 3000GT VR-4 #15 of 24. The ORIGINAL Sandstone Gray '99 Conversion. ![]() A slow strangle with your feet on the floor. www.3stech.org - Now with 100% less invite codes! Free Registration! |
#16 (permalink) |
Forest Gump
interested, especially if there is a GB on front/rear.
![]() Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops MAXED out, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, Polished Plenum and Valve Cover, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. Looking for 2nd gen Stealth or 3000GT rear bumper my sideskirts and door caps for sale, PM me. |
#17 (permalink) |
July 2003
Don't mean to rain on your parade Terry, and I like the fact that you're trying something innovative, but I'll come right out and voice some concerns over the design.
I don't like the idea that there is a compressible material governing the bolt stretch of the mounting bolts. As most of us DIY wrenchers should be aware by now, the purpose of torque specs for a specific bolt is actually to approximate the proper bolt stretch needed for the fastener to clamp the 2 pieces together. By placing a compressible substance (the poly) between the interfacing parts, you change this bolts stretch, and even if the bolts are stretched properly (by torquing at higher than spec ft-lbs), there is still the potential of the compressible substance losing it's resilience over time and thus creating slack = loosening bolts. Max
1994 3000GT VR-4. Hobbies... what are hobbies? Oh, those things people do when they're NOT working on their cars?
#18 (permalink) |
single terbow
So you put the poly in between the motor mount and the area that the motor mount will bolt to. and you think that part is going to flex? Either i am way off base here or this is in fact a design that is obviously not going to work. Does anyone else understand what i am getting at? If that motor mount is bolted down like stock i don't see how it could possibly flex even if you had a slab of the softest poly/rubber. all that poly is going to do is getting smashed flat... thats it. In order for this design to work you would need to leave the bolts really loose. I am not trying to bash it is just that this seems so obvious to me.
camera phone pic ![]() |
#19 (permalink) | |
Like a Rat out of Water
1991 3000GT VR-4 - 13T, 550cc, E-manage, Walbro 255, AEM FPR
1991 3000GT VR-4 - These cars are addicting... 1991 3000GT SL - Spare parts/Test car |
#20 (permalink) | |
Supporting Vendor
With that said I'm going with a harder poly so there isn't that much give to it however with it not being solid it will still absorb some vibrations. High grade poly shouldn't break down and permanently lose it's form either but again I'm going to put a decent amount of miles on these things to make sure. I was a little hesitant to post this just since this is a somewhat rough plan however there are plenty of other hype threads floating around so I figured I would join in just to let you guys know I'm working on something. I do appreciate the suggestions though. ![]() Terry |
