Old 09-21-2008, 09:24 AM   #1 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (55)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
Default Look! A rear engine 3000GT!!!
Old 09-21-2008, 09:25 AM   #2 (permalink)
92EuroDiamante's Avatar
Drives: Jdm D, D-LS, GTS
92EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 7
Default Re: Look! A rear engine 3000GT!!!
looks good
Godspeed Radiator,Custom Washer Reservoir Delete Cold Air Intake,Pro-Topline Pistons (old aussie co not topline) ,Custom Dual Exhaust,Homemade Resonated test pipe,Unorthodox underdrive pulley, Stock+Aftermarket Air Ride System, Lowered, Active Aero.Beefed up Tranny (long story), Sniper wet nitrous kit (needs to be tuned)
92EuroDiamante is offline   Reply With Quote
Old 09-21-2008, 09:26 AM   #3 (permalink)
H to the izzO
Drives: Recklessly
Trader Rating: (55)
The weight balance is near 50/50, but I was really unimpressed by the performance increase. If anything, the car felt a little bit heavier.
Old 09-21-2008, 09:28 AM   #4 (permalink)
Really now? i always thought putting an engine outside your wheel base would cause handling issues!
Old 09-21-2008, 09:30 AM   #5 (permalink)
H to the izzO
Drives: Recklessly
Trader Rating: (55)
Well, there's a transmission in the blue bin in front of the wheels. I think the added weight there helped.
Old 09-21-2008, 09:40 AM   #6 (permalink)
j sin
gltasn's Avatar
Drives: 95 mitz 3kgt vr4
gltasn Level 4gltasn Level 4gltasn Level 4gltasn Level 4gltasn Level 4
can someone please do a wiki on this mod. ive been waiting for it! j sin
"If I was as slow as you, they'ed bury me!" terry canfield(dad)
gltasn is offline   Reply With Quote
Old 09-21-2008, 09:43 AM   #7 (permalink)
Hubbell86's Avatar
Drives: 1992 Stealth R/T TT
Trader Rating: (7)
Hubbell86 Level 1Hubbell86 Level 1
looks like a very clean install . looks stock haha
1992 Dodge Stealth R/T TT (41,700 original miles!)
Mods: 3sx TP, 3sx DP, Emanage Blue, 15gs installed, Running 20 Psi (Getting Tuned by Predator Performance!) Walbro 255, 450cc injectors, Meth inj.
1992 Dodge Stealth R/T NA
Mods: 3sx DP, 3sx TP, and Ebay Intake
Hubbell86 is offline   Reply With Quote
Old 09-21-2008, 10:14 AM   #8 (permalink)
VR3.9's Avatar
Drives: 93 VR4 & 91 VR4
Trader Rating: (8)
VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7
I'm sure spreading out the weight of the engine by spreading out the parts, has bound to help the balance and feel.
FIPK, Megan Racing DP, Gutted Pre Cats, MBC, Walbro Fuel pump, Ground Controls, Unortodox Racing Flywheel, Slotted and Vented Rotors. Maximal Rear adjustable upper control arms. Poly Mounts
Under the Knife for: JDM motor with 25k. 13T's, 550CC injectors, SAFCII. Rebuilt 5 speed 25spline tranny.
VR3.9 is online now   Reply With Quote
Old 09-21-2008, 10:31 AM   #9 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7
if you got a longer timing belt you could have the block where the back seat should be and the heads evenly spaced in the trunk area that should give an almost perfect balance
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Originally Posted by Stealthee View Post
Seriously. Just like people will talk down to you when you post about getting a ticket.
People on here need to learn when to shut the fuck up and stop being hypocritical.
Colt45_GTO is online now   Reply With Quote
Old 09-21-2008, 11:01 AM   #10 (permalink)
Wanna be Z06
Fbc 978's Avatar
Drives: 19T VR4
Trader Rating: (20)
Fbc 978 Level 4Fbc 978 Level 4Fbc 978 Level 4Fbc 978 Level 4Fbc 978 Level 4
track times please
19T Pump 1/4 Mile-12.8 @ 111 booooost leeaaakkk
Fbc 978 is offline   Reply With Quote
