Old 07-30-2008, 11:17 PM   #11 (permalink)
Drives: 98 sl
98slept Level 398slept Level 398slept Level 398slept Level 3
Default Re: Led needles 101 !!!!!!
Originally Posted by Mitsu View Post
How do you "test the rpm tach signal with a multimeter?"
Do be honest with you. i didnt test it. it was my supervisor/friend. He used some multimeter with some weird fat probe and had it hooked up to either a tach signal or one of the wires off the spark plugs. I dont remember what he did exactly and i believe he had to convert it to rpms throught some calculations. He said i was off by 60rpms, and i believe him since he is really smart. Whether its true or not i dont know. I just know my rpms are not off by much So i assumed im off by 60rpms.
98 SL TWIN TURBO
TT 9b's at 5psi/ 95 TT ecu/Ebay precat eliminators and downpipe/3sx lightweight pulley/k&N intake/Fidanza lightweight flywheel/Centerforce dual friction clutch/walbro 255 fuel pump/MP solid motor mounts/Passport gauges/99 front conversion/l.e.d gauges/needles
98slept is online now   Reply With Quote
Old 07-30-2008, 11:20 PM   #12 (permalink)
Also known as MacGyver
marshallh's Avatar
Drives: 1994 3000GT Base
marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7
I'm wondering also. Thought you'd need a scope or frequency counter for that?
Protip for yall on the LEDs: They are rated by viewing angle and brightness. The viewing angle is the size of the cone of light projected when it's turned on, and the brightness (measured in millicandelas or MCD) is the average light intensity over a certain area of the cone.
A 120deg, 900mcd LED can be the same "brightness" as a 15deg, 10,000mcd LED. The former will get you a wide, diffused light, while the latter is more like a laser beam; very narrow but very bright.
Good call on using surface-mount LEDs!
marshallh is offline   Reply With Quote
Old 07-31-2008, 07:18 AM   #13 (permalink)
I love my VR-4!!!
alex10superman's Avatar
Drives: 1997 3000GT VR-4
alex10superman Level 4alex10superman Level 4alex10superman Level 4alex10superman Level 4alex10superman Level 4
Nice write up. I'll need to do this one of these days!
More Pictures of my car here -> Pics
alex10superman is offline   Reply With Quote
Old 07-31-2008, 09:53 AM   #14 (permalink)
95gto's Avatar
Drives: 95' VR4
95gto Level 295gto Level 295gto Level 2
Great write up, solid info!
95gto is offline   Reply With Quote
Old 07-31-2008, 03:09 PM   #15 (permalink)
Yeeaaahh...
onyxice's Avatar
Drives: '93 ES, too much.
onyxice is an unknown quantity at this point
Well done sir.
Since I got the car I've been wondering how I would make the dash cluster more to my liking... and you just told me. lol
I'm guessing a slight change in the LEDs could retain the illumination and get rid of the projection? I don't really like how it shoots the light onto your dash, I could live with it though... far better than stock imo.
About the measuring RPMs with a DMM... I'ev got a crazy ass DMM, no clue how to use 99.999% of it's functions....
Failure is just a part of life - and specifically part of owning these cars - failure will sucker punch you in the gut, but you have to spit in it's face and kick it in the nuts - the essence of owning a 3/S.
onyxice is offline   Reply With Quote
Old 07-31-2008, 03:15 PM   #16 (permalink)
daddy's Avatar
Drives: BPU 92TT
Trader Rating: (26)
daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7
Right on time I just got my Speedhut gauges, will be doing this too
daddy is offline   Reply With Quote
Old 07-31-2008, 03:57 PM   #17 (permalink)
Hates Gravel
sublime_whatigo's Avatar
Drives: reliable car (nissan
Trader Rating: (24)
sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7sublime_whatigo Level 7
So uh, whats your car redline at now? Sure looks like you hit almost 7400 in that vid to me.
92 3000GT VR4
Black Wheel Mafia - Member 002
Matt
sublime_whatigo is offline   Reply With Quote
Old 07-31-2008, 10:25 PM   #18 (permalink)
Automotive Geek
Drives: 1993 3000GT VR-4
SpikeyGG is an unknown quantity at this point
This is a great writeup. Thanks!
As for the tach being off after removing the needle, I've never had my gauges apart and mine are already off by a bit... I notice the difference in my datalogger. Though now that I think about it, I'm not sure if the datalogger is wrong or the tach is wrong. Oh well.
93 VR-4 K&N FIPK, Eibach Pro Sport springs, MSD 8.5mm wires, NGK iridium plugs, solid polyurethane motor mounts, Sumitomo HTR+ tires, gutted precats, adjustable rear control arms, 99 lifters, underhood and console shifter bushings, aluminum dash vents, clutch vacuum assist delete, GM boost logging, full set of Defi gauges. Always a work in progress...
SpikeyGG is online now   Reply With Quote
Old 07-31-2008, 10:50 PM   #19 (permalink)
Drives: An AEM car in -10F
Trader Rating: (9)
MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5
I wouldn't worry about it much. Do some mods and you can tell it can't keep up with the engine in 1st gear. I've hit my rev limiter while my tach only said 6800 or so. 60 RPM = nothing.
~Ryan
92 Stealth R/T TT- Not exactly done- 93 RT TT- Not much of a car anymore.
"This is a solution looking for a problem." - Not me
MustGoFaster is offline   Reply With Quote
Old 07-31-2008, 10:56 PM   #20 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7
that looks fuckin nice mate you must have the patience of a spider seriously.
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Originally Posted by Stealthee View Post
Seriously. Just like people will talk down to you when you post about getting a ticket.
People on here need to learn when to shut the fuck up and stop being hypocritical.
Colt45_GTO is online now   Reply With Quote
