Old 09-14-2008, 05:16 AM   #1 (permalink)
Drives: 1990 GTO
aussie_will is an unknown quantity at this point
Default Leaking coolant
Hello gents,
I'm having a hard time trying to find and fix a coolant leak on my first gen, TT GTO.
I get a puddle of coolant directly underneath the transmission, and I can see quite a bit of coolant pooling on top of the transmission. Where is this most likely coming from?
I've just had most of my intake piping out to swap in a new BOV, y-pipe and radiator. Was hoping to find an obvious leak in the process. I'll probably need to take my car out for another run and rip it all apart again while it's still hot.
I'm guessing it's one of the coolant lines from the waterneck to either the heater core or turbos.
Any help would be appreciated.
Thanks,
Will.
Edit: added pics - you can barely see the green pools of coolant sitting on the tranny.
aussie_will is offline   Reply With Quote
Old 09-14-2008, 06:36 AM   #2 (permalink)
Former ROTY :-}
OhioSpyderman's Avatar
Drives: Back and Forth :)
OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7
Default Re: Leaking coolant
Will,
There's a coolant line that runs parallel to the fuel line that feeds the rear turbo (this is coming from my son, Zachary).
This might be a good place to start your search...
Bob.
EDIT....I'm also looking through the CD manual to see if there are any more coolant lines in that area...
95 Caracus Red Spyder VR4
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
SBC-iD Boost Controller (in both!!!)
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
OhioSpyderman is online now   Reply With Quote
Old 09-14-2008, 06:47 AM   #3 (permalink)
Former ROTY :-}
Here's a shot from the manual showing all the coolants lines.
Hope this helps....
Bob.
Old 09-14-2008, 06:58 AM   #4 (permalink)
Drives: 1990 GTO
Originally Posted by OhioSpyderman View Post
Will,
Bob.
Thanks Bob,
Hmmm, bugger, yes I was hoping it not to be one of the turbo coolant lines.
I'll have to poke around a bit more under the hood this week.
Cheers,
Will.
Old 09-15-2008, 09:52 PM   #5 (permalink)
j sin
gltasn's Avatar
Drives: 95 mitz 3kgt vr4
gltasn Level 4gltasn Level 4gltasn Level 4gltasn Level 4gltasn Level 4
could be comming out your overflow? thats where is exits if your are overheating or have something inside amiss. i had a leak i couldnt find for hours. and it was the cooling line to the throttle body. the 1mm slit was hid by a foam heatshield over the hose. j sin
"If I was as slow as you, they'ed bury me!" terry canfield(dad)
gltasn is offline   Reply With Quote
Old 09-17-2008, 07:17 AM   #6 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
If the water neck was out at all recently, that o-ring is super sensitive to being sliced, and will leak in that exact spot ...
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 09-17-2008, 07:39 AM   #7 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (55)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
I'd also look at the rear turbo lines first. Inspect them at the turbo, where the hard line inserts into the rubber hose (half way), and at the nipple on the water housing.
If the rear turbo lines are good, look at the throttle body lines. This should be the easiest to notice any leakage. Under the throttlebody, you'll also find the heater hose. These are larger and shoul be clamped on. Inspect the areas near the clamps for any cracking/leaking. If all the lines are good, then check for seapage around the water housing.
Lawdogg is right about the O-ring. Also, there are two paper gaskets on either side of the water housing. I am not aware of those having a tendency to leak, but it may be worth a look if the hoses are okay.
Old 09-17-2008, 09:04 PM   #8 (permalink)
Member
massstealth's Avatar
Drives: 95 Escort
Trader Rating: (16)
massstealth Level 1massstealth Level 1
Make sure your coolant reserve transfer hose isnt slit like mine was. Big pita to find if your not looking for the leak there.
Bob
Rear ended by homeless drunk driver July 12 04
Please wait 13 seconds..
RPS full face clutch, Fidanza flywheel, ATR downpipe, TurboXS dual stage boost controller, K+N fipk, Turboxs h34 bov, Kormex 25 spline, recall transfercase. 180k service done thanks Clint. Soon>>>Hotwire + fuel pump, water/meth
Image hosted by Photobucket.com
SOLD
Now driving 38mpg Escort
massstealth is offline   Reply With Quote
Old 09-18-2008, 03:47 AM   #9 (permalink)
VR4-mike's Avatar
Drives: 93 VR-4
VR4-mike Level 3VR4-mike Level 3VR4-mike Level 3VR4-mike Level 3
I think we have the same leak my friends. mine accumulates in the same place yours does. I found it to be comming out of the bottom of the thermostat housing where the metal tube connects to it (the tube that runs under the intake manifold and to the water pump) . the little o rings can leak easliy.
VR4-mike is offline   Reply With Quote
Old 09-18-2008, 10:29 PM   #10 (permalink)
Drives: 1990 GTO
Thanks for all the responses guys. I still haven't had time to look into it properly yet - maybe this weekend. I'm pretty sure it's the turbo coolant hoses/clips. I'll look into the o-rings as well. Not going to do a half-arsed job this time. I'll remove most of that piping again and take a proper look around the waterneck area.
All the hoses that are *easily accessible* have been checked and are leak free. It's the ones at the hard to reach spots that I haven't checked. And it looks like it's one of those that are leaking. I'll post pics when I track it down.
