Old 09-19-2008, 06:01 AM   #11 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (55)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
Default Re: Leaking coolant
Originally Posted by aussie_will View Post
I'll remove most of that piping again and take a proper look around the waterneck area.
All the hoses that are *easily accessible* have been checked and are leak free. It's the ones at the hard to reach spots that I haven't checked. And it looks like it's one of those that are leaking. I'll post pics when I track it down.
You might want to remove the plenum too when you check the rear turbo. It only takes about 15 minutes to get it off.
If you find that the turbo line is leaking at the turbo banjo bolt you will want to replace the two crushwashers around the line. If the turbo is new or the lines had just recently been installed with new washers, you may be able to get by by just tightening the banjo bolts. If you overtighten them, however, the banjo bolt will snap (don't ask me how I know ).
Old 09-19-2008, 12:22 PM   #12 (permalink)
Drives: 1994 VR4
jsmack79 is an unknown quantity at this point
I had a post like this in the engine section last week.
Finally found my leak when the hose leading to the front turbo completely snapped and leaked all the coolant out of my system.
http://www.3si.org/forum/attachments...g-img_0356.jpg There's the pic. Good luck getting your fingers in there if that's where it is!
jsmack79 is offline   Reply With Quote
Old 09-20-2008, 04:42 PM   #13 (permalink)
freedom
scoob's Avatar
Drives: now red mk2 gto tt
scoob Level 2scoob Level 2scoob Level 2
i had a bad leak from the rear turbo coolant pipe. got a new set of 13ts' fitted and the mechanic forgot to put the clip back on the pipe where it goes into the rubber hose under the thermostat housing. only noticed it when i saw a damp rusty patch at the hose join.pain in the ass to put a clip back on tho.need small hands
we are all one
scoob is offline   Reply With Quote
Old 09-23-2008, 08:03 AM   #14 (permalink)
Drives: 1990 GTO
aussie_will is an unknown quantity at this point
Ok guys, finally found it. Looks like it was one of the coolant hoses to the rear turbo - at the hardline end.
Attached is a top-down view of the hose - visible in a tiny gap between the TPS and CAS.
Looks like it's going to be a fiddly job replacing it.
Thanks for everyone's help.
aussie_will is offline   Reply With Quote
