LinkBack | Thread Tools |
#11 (permalink) |
Masshole
it could be your iac, isc or whatever the hell its called. I used a cali spec ecu on my fed spec car without issue. I guess it is possible that the opposite wouldn't work.
94 vr4
#13 (permalink) | |
By the power of Grayskull
![]() ChrisEs1984 : theres alot of pushrod lovers Galganaban : i love to push my rod into your mom shawnisworking : lol shawnisworking : 0wn3d |
#14 (permalink) | |
#15 (permalink) | |
25 Spline Snapper
#16 (permalink) |
Oh SNAP!!!
knida off topic..but did you replace your plugs/ wires?
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine** Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!! 1st car with the Enkei RZ-5 18''x8.5'' *534x306* ![]() 1994 Dodge Stealth R/T TT~Pearl Yellow |
#18 (permalink) |
Forum user
I replaced my CAli spec car with a fed ECU. Same thing happened. From what I gathered the only difference between the 2 is the EGR is absent on the FED models. After installing the FED computer the car was only running about 5lbs of boost no other changes. It would sputter and kick around. I installed a MBC and checked out the ECS and found the ecu was bad back there too..pulled it and it the car runs great again (except for the squishy suspension)
1991 Dodge Stealth R/T T/T
234,000 miles and not going strong....For sale needs a bearing... |
